asus K52JR not starting. need 4MB bios rom
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3636
    • slovakia
    Have this asus k52jr that have some problems with 3.3v that loks like shorted. but after flash bios it came ok, but not starting. i measure that PM_PWRBTN# signal from ITE 8570 did not some but PWR_SW# did come to them. i think that ITE could be a problem but i can be even BIOS. Have somebody tested BIOS rom for K52JR with 4MB bios file?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: asus K52JR not starting. need 4MB bios rom
    you can read your non-woking bios and i can fix it for you
    Im Back... sort of...
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3636
      • slovakia
      Here u go. Thanks for checking it
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        here you go
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3636
          • slovakia
          thx i will try
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3636
            • slovakia
            bios looks ok but laptop not starting. im missing PM_PWRBTN# from EC to PCH
            • FComp
              • Oct 2016
              • 16
              • Slovensko
              Hi
              Please help.
              I have a laptop K52F and K52F.
              After programming bios programmer through my notebook boots up fine, but I have a problem in that the CPU is overheating.
              After 10-30 sec. I turn off the notebook.
              There are still some special setup or BIOS CPU?
              Thank you very much
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                try this
                same bios only clean me region
                • FComp
                  • Oct 2016
                  • 16
                  • Slovensko
                  try this
                  Now does not start or BIOS.
                  The exact type of laptop is: A52F-SX627D
                  K52F motherboard is a rev 2.0
                  Thank you
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    Pls read and post your backup bios
                    the first and original one
                    • FComp
                      • Oct 2016
                      • 16
                      • Slovensko
                      I do not have original BIOS backup.
                      ASUS K52F 218.bin
                      This is a BIOS that neatly but the CPU is overheating. 30 seconds after the restart.
                      • FComp
                        • Oct 2016
                        • 16
                        • Slovensko
                        Is there any utility or program for editing bin file?
                        I would like to modify.
                        well thank you
                        • FComp
                          • Oct 2016
                          • 16
                          • Slovensko
                          well thank you
                          SST25VF032B - chip bios
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1490
                            • portugal
                            you have HEXEDITOR for editing the bin files.
                            Fcomp he asked for the bin file you got (new and your backup) , he dont need the bios code chip :P
                            • FComp
                              • Oct 2016
                              • 16
                              • Slovensko
                              Chip on board
                              A52F-SX627D_MB-K52F_rev2.0_ver.zip
                              I have now programmed this.
                              Everything works. The problem is LAN / can not run / error in the driver.
                              CPU still has 80 to 90 ° C fan is noisy around 4000 rpm.
                              But notebook is turned off or fall.
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1490
                                • portugal
                                seems to me bad cooler , and only after cooler replacement we will see if fan is still high , if still high , then bios must be with clean region
                                • khaahk
                                  • Dec 2013
                                  • 830
                                  • Estonia
                                  For LAN card to work you need to copy MAC address to new dump. MAC address is printed on a sticker on the mainboard, find it in the old dump in hex and replace. It should be there 2 times sequentially, change both of them.
                                  • FComp
                                    • Oct 2016
                                    • 16
                                    • Slovensko
                                    How do I clean bios region ?
                                    • FComp
                                      • Oct 2016
                                      • 16
                                      • Slovensko
                                      Lan it´s OK. Adding a MAC Address.
                                      Thanks you
                                      • khaahk
                                        • Dec 2013
                                        • 830
                                        • Estonia
                                        if the sticker is missing from mainboard then you are in trouble...
                                        • razor_amd
                                          [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                          by razor_amd
                                          With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                          For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                          I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                          This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • grimacelord
                                          ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                                          by grimacelord
                                          I have spent the last hour on this and I guess this is just over my head, so here I am.
                                          I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                                          The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                                          Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                          by throwaway327
                                          ASUS ROG Ally X - (Handheld Gaming PC)
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                          06-18-2025, 05:52 PM
