asus K52JR not starting. need 4MB bios rom
Re: asus K52JR not starting. need 4MB bios rom
man it was right now i saw that your laptop IS NOT SAME AS ORIGINAL THREAD hence you use different bios
this is the one you need
pls next time open your own theradAttached Filesif you find these attachements useful please consider making a small donation to the site
Im Back... sort of...
Thanks. bios super and cooler super.
Problem is LAN mac address.:pláč:
Please help whit registration mac in flash / hexeditor /
ThanksComment
to add MAC address 92-E5-BA-F9-AD-C4 to bios
create DOS bootable USB stick and copy the BT.EXE to it
boot from the stick and execute commands:
bt.exe -C CNFG /W C2 92
bt.exe -C CNFG /W C3 E5
bt.exe -C CNFG /W C4 BA
bt.exe -C CNFG /W C5 F9
bt.exe -C CNFG /W C6 AD
bt.exe -C CNFG /W C7 C4
bt.exe -C CNFG /W D7 92
bt.exe -C CNFG /W D8 E5
bt.exe -C CNFG /W D9 BA
bt.exe -C CNFG /W DA F9
bt.exe -C CNFG /W DB AD
bt.exe -C CNFG /W DC C4
or write a bat file to save typing in dos.
use your machine's mac address of course.Attached Filesif you find these attachements useful please consider making a small donation to the site
hello everyone I have an asus k52j that I press the power button turns on and off I reprogrammed the bios but nothing in your opinion that I could do thanks a lotComment
FComp. Thanks to Your BIOS image I was able to fix my A52F
My board is K52f rev 2.0
Trying to upgrade my BIOS to last ASUS posted update, I used freeDOS and an old asus flashing utility.
It erased the whole flash and hung at half writing .... because it had not enought data to flash in it , I guess :'(
And no original backup either :'(
Luckly I was able to found badcaps.net, and tryed flashing various images, but most of them ended by CPU fan at maximum power and linux shutting down because a Thermal_zone0 critical temp 97C alert
Your image was the one that worked fine... excepting for the Ethernet card mac address ( ff:ff:ff:ff:ff:ff )
Not a big deal for linux as I put my original mac at network configuration file
At first I was thinking about editing the flash image and change the mac address and reflash ... but I can not figure out where it could be located.
Any clue about this MAC address data location in the BIOS file?
Thank You so much
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by piratiHello everyone,
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
