Weird Samsung LN46A550 problem....
  • Honel
    • Oct 2014
    • 4
    So I picked up a cheap Samsung the other day, and lo and behold there was a good reason it was cheap.....so I started trouble shooting. I have not come across another instance like this so I thought I'd post and see what the general consensus was before I started throwing parts at the thing.
    The inverter seems okay, with the TCON disconnected I get backlights just fine. If I connect the TCON, I get dark splotches on the left side which immediately fade, and then the entire screen fades to gray/white (with the left side of the screen always tending toward white). If I connect a source (HDMI or component) I can see a very low contrast version of it. Here's the trippy part - the entire image on the right side of the screen is inverted color.
    Sound works fine, tv is not power cycling, and I scrounged a tcon from another tv and cannot tell the difference in result (same gray screen etc) when switching between the two....I have fiddled with the bonding tabs and cannot see any difference on the screen.
    Any Ideas??
    I do not currently have a camera, so no photos I'm afraid.
    Thanks in advance - Wes
  • Honel
    • Oct 2014
    • 4
    Re: Weird Samsung LN46A550 problem....
    Finally got a photo - sorry for the delay - it was a bit of a process....
    • Shinju
      • Mar 2014
      • 1239
      Possible you have 2 bad t-cons, photos of the boards would be helpful.
      Also looks like it could be a bad panel as well.
      • Honel
        • Oct 2014
        • 4
        I will take some pictures and post them when I get home from work - would both TCONS do the exact same thing though?
        Is there any way to actually test the boards as opposed to just replacing them? I am handy with a meter and soldering iron - though my o-scope is out of commission...
          http://www.shopjimmy.com/catalogsear...msung+LN46A550
          Which one is your T-CON board? AUOPTO?
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • KYBOSH
            Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
            by KYBOSH
            Picked this up to resurrect.
            When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
            I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
            Sometimes the TV would produce an expanding blob on the screen before going black.
            See Video here
            I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
            Did I get another defective board or is there an issue with...
            09-16-2024, 07:48 PM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
