Elefw327 won't turn on
  • crdz66
    • Nov 2012
    • 242
    Hi Everyone.
    I need you opinion.
    I have a Element Led Tv with not power on (Remote or push button).
    I already check capacitors, diodes, etc.
    I don't have a standby light.
    Everybody mention about some kind of eeprom chip is the fail on this model, but that is when the standby light is on or either way (on or off)
    Thanks.
    Fuse are ok too.
    I just have presence voltage 3.2v on inverter connector but because is a led it is no necessary.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Elefw327 won't turn on
    Does this model have an onboard power board or a power supply that is external to the TV set? What is the incoming power looking like?
    • crdz66
      • Nov 2012
      • 242
      There are two boards.
      Power Supply/Main Board
      Tcon Board
      Just 2
      • MisterD
        • Oct 2012
        • 668
        I suggest that you use the search box in this forum, type in the model number and compare the voltage readings that you get with others that have been posted, in my case my same model element was a bad EEPROM but I Did have a standby light...Did you check the DC Voltage across the main capacitor?
        • crdz66
          • Nov 2012
          • 242
          No yet.
          I going to check
          • crdz66
            • Nov 2012
            • 242
            168v crossing main capacitor
            • crdz66
              • Nov 2012
              • 242
              The 2 D89 Diodes show:
              1. 0v
              2. Going from 0 to 100v and make a lot fluctuations
              • MisterD
                • Oct 2012
                • 668
                Check the voltage on the red wire at the white connector where the circuit board is marked CN1, connect your black negative wire of the meter to the chassis ground, what voltage do you get there?
                • crdz66
                  • Nov 2012
                  • 242
                  0 volts with fluctuations
                  • MisterD
                    • Oct 2012
                    • 668
                    The next thing I would do is make sure all of the mounting screws for the Power Supply/Main Board are tight to ensure a good ground.especially since you are getting fluctuations in voltage readings.
                    also you may want to make sure your volt meter has new or good batteries.
                      Can we see the pictures of your boards? Shojimmy sells EEPROM for this set also.
                      http://www.shopjimmy.com/element-ele...eprom-only.htm
                      • crdz66
                        • Nov 2012
                        • 242
                        Yes all screws are very tight
                        batteries good conditions on my multimeter.
                        still no standby light
                        pics upload
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          Did you check the voltage regulators UL1 UL51 UL41 and the one next to it
                          and what is the part number of the component on the heatsink opposite side to the bridge rectifier
                          On the back of the board there is a mosfet? QB16 to test
                          Did you try it without the backlight cable and lvds in case there is a short on those.
                          • crdz66
                            • Nov 2012
                            • 242
                            no yet
                            going to check
                            • crdz66
                              • Nov 2012
                              • 242
                              UL 41 AND UL 51 SHOW 0 VDC
                              UL 1 MAKE FLUCTUATIONS BETWEEN 0 TO 135 ON 2000mV SCALE ON MY DMM
                              I DID IT WITH LED CONNECTOR AND LVDS DISCONNECT.
                              MY FRIEND TOLD ME AS SOON HE CONNECT THE TV SMELL LIKE BURN BUT CAN'T FIND NOTHING ALREADY BURNED.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                Ok Sholud reallqy be 3 results for each regulator - all zero?
                                Tested with black probe on ground?
                                Still need part number for item on heat sink and test on mosfet
                                • crdz66
                                  • Nov 2012
                                  • 242
                                  Part number 10100ctp
                                  reading 228 and 230 on the edges. Negative center pin.
                                  Regulators show almost 0
                                  connector cn6 besides cn1 show 3.4.-3.7 volts with little fluctuations on pin 1,2
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    You are going to have to be better at saying what you re thinking and need to state units
                                    volts.ohms whatever
                                    What is reading 228 and 230 volts or ohms
                                    On all pins - volts with respect to a ground screw?
                                    We cant SEE what you are doing
                                    • crdz66
                                      • Nov 2012
                                      • 242
                                      ok. sorry.
                                      The transistor on cold side show 230 ohms on the edges with diode function on dmm
                                      The transistor on hot side looking by front with legs 1-2-3 from left to right readings starting red probe on 1 on negative on 2, etc
                                      1-2 : no read
                                      1-3 : no read
                                      2-1 : no read
                                      2-3 : no read
                                      3-1 : no read
                                      3-2 : 545 ohms
                                      These transistors was testing out from the board.
                                      The regulators was testing with 120 vac connect to the tv.
                                      I was used the voltmeter on scale the 2volts because more volts show 0 all the time.
                                      And yes everything was tested with ground screw.
                                      • PNI E.
                                        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                        by PNI E.
                                        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                        03-17-2025, 04:23 AM
                                      • madsox
                                        Harman Kardon AVR 171S - standby led lights up, does not turn on
                                        by madsox
                                        Greetings!
                                        Thank you in advance for your understanding, I am writing to you through a translator.
                                        A Harman Kardon AVR171S amplifier was given.
                                        The history of the machine is as follows:
                                        It was faulty when I bought it, I want to fix it.
                                        I replaced the HDMI switch and one of the DAC ICs in it.
                                        After that it worked without a problem.
                                        I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                        The cooling was faulty, I will fix this later.
                                        I switched it to standby mode, waited for...
                                        09-24-2022, 10:46 AM
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                      • Doodle43
                                        Samsung LN32B540 - won’t turn on but gets standby power
                                        by Doodle43
                                        My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                        It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                        05-26-2020, 12:02 PM
                                      • Adenitz
                                        Troubleshooting Vestel TV, has standby, but cannot turn ON
                                        by Adenitz
                                        I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                        Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                        Both boards are shown in the attached photos.
                                        What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                        12-27-2023, 03:43 AM
