Vizio P50 HDTV20A
  • gideon277
    • Jun 2013
    • 42
    Vizio P50 HDTV20A
    Okay this is a 50" Plasma Television. The TV powers on I have sound on all inputs. The Picture though is terrible and transitionally fades into existence only after considerable warm up. The picture when it finally comes up ends up patchy with a fuzzy appearance and sometimes patches are missing other times they are not. The picture is always darker than it should be.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Vizio P50 HDTV20A
    Pictures?
    • gideon277
      • Jun 2013
      • 42
      This is a pretty typical state for the t.v to be in. Caps look okay.
      • PlasmaRon
        • Nov 2013
        • 40
        The caps on the PS look ok? I think I've yet to see one of these P50 sets that doesn't have some puffed up caps on the power supply. I'd still start out by checking the voltages to the panel.
        • patrax
          • Feb 2014
          • 33
          Definitely looks like a Psu cap to me . Even if the look good my bet is there is a bad one on the board. I have repaired two of this exact model and both had a cap that looked fine but upon further testing/replacing it was a Psu cap. Fluctuating voltage causes this condition because of a bad capacitor.
          • mmartell
            • Oct 2013
            • 3189
            Is it my eyes or does the menu look ok ?
            • tw2005
              • Oct 2011
              • 6458
              Looks like failed ZSUS assuming it's LG based panel or xmain if samsung but I'm expecting this is LG.
              • gideon277
                • Jun 2013
                • 42
                okay the tv is in fact Samsung based. No caps appear to be bad as I can tell here are some more photos.
                • gideon277
                  • Jun 2013
                  • 42
                  I did find one bad cap on the xmain a smaller one. I replaced it but it did not fix the problem. I have noted a high pitch noise coming from the powersupply right where another cap is. I guess I am going to start taking some readings to see what my voltage is. Any suggestions?
                  • tw2005
                    • Oct 2011
                    • 6458
                    Check the power to the Xmain and the fuses (1 ceramic, 3 green pico) on that board. There's a Vs and Ve test point on the PCB next to CN4701 where power enters.
                    Edit: Samsung manual added.
                      X-main fault, IMHO.
                      • gideon277
                        • Jun 2013
                        • 42
                        Okay voltages going to xmain are 88.8, 88.8 ground ground 6.3 that is going from left to right on the power supply itself no cable connected. I have tried other settings on my volt meter but get 1 on all pins expect last pin which gives me 14. I am at a loss going back to possible power supply issue.
                        • tw2005
                          • Oct 2011
                          • 6458
                          that's a problem in my eyes, should see Vs or 200v or so not 88v?
                          maybe post#5 is something to consider, watch out for dry joints
                          • tw2005
                            • Oct 2011
                            • 6458
                            What's Vs at the Ymain?
                            • gideon277
                              • Jun 2013
                              • 42
                              At the ymain it is 89.7, 89.7 and 6.4
                              • gideon277
                                • Jun 2013
                                • 42
                                I ajdusted my voltmeter up a bit and now I get 207, 207, and 14 that is for x-main and y-main. I am having problems testing for continuity and have a feeling my meter is screwing up.
                                • gideon277
                                  • Jun 2013
                                  • 42
                                  Okay found a bad inline fuse on the x-main board just did a temporary jumper to test the theory and bingo it worked. I should be able to replace that fuse tomorrow and t.v will be working. I suppose I could just leave the jumper in place but I would rather fix it properly.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Which fuse? Post a picture of it working and definitely get the right fuse in case there is an issue of too much current draw.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      I've seen this before with other meters used in posts. A good quality autoranging meter is a sound investment.
                                      I have a 20year fluke I picked up for $30 and it's excellent, ex government disposal.
                                      • gideon277
                                        • Jun 2013
                                        • 42
                                        This is what the menu is supposed to look like compare to the first photo I submitted on this post.
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • maricm
                                          Vizio m65-c1 picture flashing on and off on the screen
                                          by maricm
                                          HI all,
                                          hope someone point to the possible issue before I start buying replacement parts.
                                          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                          Backlight stays on all the time,
                                          Sound works fine.
                                          screen keeps changing form black to full picture in about 1sec intervals.
                                          Picture looks fine with no visible artifacts.
                                          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                          Disconnecting left and right ribbons on...
                                          11-25-2023, 06:32 PM
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
