[HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
This is a sticky topic.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Just finished fixing this one. Apparently, this is a common issue with all Asus P5 series boards. I first assumed it's a bad BIOS flash or corrupt CMOS settings, as it would go away once after resetting CMOS, but upon the next reboot it would be there again. Same if i changed any BIOS settings and saved them.
    I read that people have flashed BIOSes to no luck, and someone pointed towards a transistor on another (older) board, so i proceeded to look for a hardware issue. And i found it. See attachments for fix.
    Instructions:
    1. Follow directions in pictures
    2. Clear CMOS
    3. Power board up, redo all BIOS settings
    4. Be happy and have a cold one.
    This should apply to *all* boards that exhibit this behavior, obviously the parts may be in a different location. Follow these directions to find it if your board differs:
    1. Remove jumper cap from chassis intrusion connector (if you're reading this, you already found it's of no use anyway).
    2. With the board powered ON, measure with your voltmeter and find the pin of the chassis intrusion switch connector that has somewhere between 1.7v and 3.3v on it.
    3. Disconnect board from PSU.
    4. Use continuity tester function of your DMM and probe on the SOT23 transistors next to the super IO controller, you should find it beeps on one of them.
    5. Power the board back ON and find a 3.3v supply nearby
    6. Power board OFF, remove transistor, solder drain connection (it's gonna be the single pad, just like it looks in the picture) to 3.3v supply.
    The rest is the same as above.
    I'm also going to tell you what causes the issue to appear in the first place in a follow-up post.
    Last edited by Th3_uN1Qu3; 10-24-2013, 05:29 PM. Reason: edited title for more keywords
    A working TV? How boring!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
    Not getting the issue on my Asus P5QL Pro, knock on wood, even though I'm posting from my Asus Maximus II Gene.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • shadow
      • Feb 2007
      • 732
      Very interesting find! I find it impressive that someone would come up with such a solution.
      By desoldering the transistor and wiring a 3.3V source straight to the drain pin. It seems like you are bypassing the whole Chassis Intrusion circuitry and making the motherboard 'happy' so to speak by saying that there has not been any Chassis Intrusion at any time (tying the relevant IO pin to high).
      I assume the Chassis Intrusion 'feature' will not work anymore with the transistor gone. And I also assume that the real cause of the issue will be either that transistor which you desoldered or some part of the circuitry downstream of that.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        and nobody i know uses the feature anyway.good fix.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Yes, it does not work anymore, but who cares about that again? A feature that was useless to begin with. At least the way Asus implemented it. I promised i'll get into more detail so here goes:
          First of all, there is no other circuitry downstream. The gate of that transistor goes straight into pin 3 of the chassis intrusion connector and that's it. And the drain connects directly to pin 104 of the super IO controller, which would be the 3rd pin counting from the right side, where you see 102 printed.
          And that transistor was just doing its job. It was fine, i checked. The way it was implemented was the problem.
          Now with that settled, let's see just how many wrongs in a row could Asus get...
          1. On most other boards that support a chassis intrusion sensor (switch), there is an option in the BIOS to change the chassis intrusion sensor so that it merely reports that your case has been opened, rather than preventing you to boot up the damn computer. There is no such option with ASUS boards. The mere inclusion of this feature would have prevented all this trouble.
          2. The Super IO controller works with ridiculously low pull-up currents on those pins, i measured 3.3uA (microamps). Merely measuring with your multimeter, or even just TOUCHING them WILL pull the pins down, and make them report false information!
          3. The transistor doing the pull-down when the chassis intrusion switch is OPEN (or the jumper removed for whatever reason), is a MOSFET that conducts at very low gate voltages, and has no gate-source resistor. At 1.5v the transistor already conducts and pulls the pin down on the super IO. You can charge it up to that 1.5v by merely touching the pins of the connector.
          4. Given the very low currents the pins on the super IO controller, just the drain-to-source leakage current as that MOSFET gets old, or simply dust and dirt accumulating on the board, can create enough leakage current to make the IO pin appear as "low" and generate a chassis intrusion message which you can then never get rid of.
            And the icing on the cake...
          5. The chassis intrusion detection is a flag in NVRAM, and it can get set even if power is removed from the board. As long as the CMOS battery is there, the chassis intrusion "feature" will work. Or shall i say, prevent YOU from working?
          Asus deserves a big and for this one.
          Extra bit of fun info: The transistor right next to it will make the board report "New CPU installed!" every time until you clear CMOS, if you touch it or probe it. But at least it lets you boot the system.
          Thanks.
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Yep. That's ASUS for ya.
            Were you expecting them to get it right even after their "USB ESD" problems?
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • cheapie
              null
              • Jul 2010
              • 849
              Why don't you just turn the intrusion detection off? Every board with it that I've seen has that option.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                If you would have actually read my explanation of the issue, you would have noticed that...
                That's right - i'm not "just turning the intrusion detection off" because it cannot be turned off. Trust me, i've looked everywhere in the BIOS setup (and manual too) of that board, the option to turn it off or ignore it is missing.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  good work! while I've never had this problem from an Asus (one of the few quirks I havent had from 'ass backward asus'), thanks for sharing this fix!
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • cheapie
                    null
                    • Jul 2010
                    • 849
                    Oh.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Neat fix!
                      If only I knew of this fix a few years ago. Someone gave my friend this exact same motherboard since it wasn't working. And because no one could fix it, it just got torn apart for random parts.
                      IMO, ASUS motherboard can be real stupid sometimes. I have an older AsRock S939 motherboard designed by ASUS (at least that's what it looks like), and one of the regulators for the RAM Vcc gets so hot that the PCB has severely darkened around it. And this is not limited to just my motherboard model. I've seen other ASUS boards with this problem as well.
                      • neuron
                        • Feb 2013
                        • 126
                        • Portugal
                        This problem is very common in Asus site and in many forums in Internet.
                        Since I crack many software - Mac and W$n ... I would like your advice and expertise to solve this in the BIOS.
                        Disassemble BIOS - the ROM code and change the jump ... in the code. Not in Menu
                        Anyone test this procedure - Transistor in P5K E
                        Best Regards,
                        Neuron
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Yes this could also be solved thru BIOS modification, but disassembly of a BIOS ROM is beyond my software skills. If you show me a clear, high resolution photo of your board, i could point out where you can check to find that transistor.
                          • neuron
                            • Feb 2013
                            • 126
                            • Portugal
                            Thank you for your quick answer.
                            If we solve in BIOS, many P5K owners ... appreciate this.
                            http://www.asus.com/Motherboards/P5KEWIFIAP
                            Regards,
                            Neuron
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Found a bigger one on the 'net. Check all SOT-23 transistors in the circled area, one of them must be the chassis intrusion detector. There's only 6 of them so it should be easy to find.
                              I could probably learn the knowledge required to patch the BIOS in a few weeks (i've done this before), but my time is very limited nowadays, and also, i don't have such a board to test.
                              • neuron
                                • Feb 2013
                                • 126
                                • Portugal
                                Thanksssssssssssssssssss
                                If you could get me some guidelines - BIOS... since you studied this in past.
                                Regards,
                                Neuron
                                • anomaly7
                                  • Jan 2014
                                  • 1
                                  Thanks for this post. I received my first Chassis Intruded ! alert this morning. I think I'll cheeck back for the BIOS fix mentioned...
                                  • tmiha71
                                    • Apr 2010
                                    • 130
                                    Nice thread, but I see lot of Panasonic's FJ caps...
                                    If there are at the rear USB connectors, I would replace them with Rubycon XYG 8x11 1000uF, even used ones are good for that place...
                                    Reason for replacement - too good caps (??), on wrong place ...
                                    To add, through time, inductive, capacitive, or even resistive bond is created, and is main cause of that behavior...
                                    Most likely some caps died, and can not swallow current... And because they're FJ's - most likely PSU caps took big hit...
                                    • 3d0
                                      • Jan 2014
                                      • 159
                                      • BiH
                                      My friend has an ASUS P5-N32 Sli Deluxe board with the same problem. He can't make any changes in BIOS and save them, because on the next restart the chassis intrusion message pop's up. So no overclocking could be done. We tried everything from flashing the BIOS, replacing all the jumpers etc, nothing helped.
                                      Wish I could find this 7-8 years ago, when it was brand new. It cost around 250-300 euros.
                                      Thanks for the explanation.
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        If you're waiting for *me* to fix the BIOS, i won't.
                                        • playit
                                          ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                                          by playit
                                          my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                                          my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                                          few years back ps2 mouse stopped working, but ps2...
                                          12-23-2024, 06:05 AM
                                        • harp
                                          Howto open schuco rubber plug
                                          by harp
                                          Oh, sadly it has no screw...
                                          What is the proper way to open this so that not destroy rubber?
                                          I feel if go on forward with not knowledge howto open, that it be broken rubber seal on it....
                                          12-16-2022, 02:35 PM
                                        • OKRPKCOMP
                                          B85m-e rev 1.02 chassis intrude error
                                          by OKRPKCOMP
                                          Asus board B85M-E bios is ok, motherboard is ok, everything is fine but i am facing this error at startup
                                          Chassis intrude,pls check yours system
                                          Fatal error, system halted
                                          Remember, there is nothing in bios setup to disable chassis error. Anybody can help me to solve this prob
                                          Thanks in advance...
                                          07-20-2022, 10:12 AM
                                        • vishal24
                                          Lenovo ideacenter B320
                                          by vishal24
                                          I m Having Lenovo Ideacenter B320 all in one.
                                          when i Press F1 for BIOS, Asking for password. after 3 times wrong password, give error Fatal Error System Halted.
                                          i forgot my bios password.
                                          08-10-2021, 03:18 AM
                                        • angelos
                                          LG 42" Plasma TV - Howto invoke AUtO GEN?
                                          by angelos
                                          I got in this beast of a tv of which i am needing advice on how to access the AUTO GEN function so that i can test if my main board is perhaps faulty.
                                          There is a 4 pin plug on the plasma control board but i don't know what to do there and i cannot find any reference on the web to it.
                                          I have added photos to jar your memories...
                                          This is PDP42V8 chassis.
                                          Any suggestions would be greatly appreciated.
                                          Angelos...
                                          06-07-2020, 10:10 AM
