Phillips 42PFL5432D/37 problems
  • Jesnjonbond
    • 12
    I have a 42" Phillips that is constantly blinking on then off. The green power button stays in though. I've removed the back and everything on the board looks to be normal.
  • Jesnjonbond
    • 12
    Re: Phillips 42PFL5432D/37 problems
    Button stays ***ON.
      The first step is to share us some pictures of the internals of the unit.
      The second step is to tell us how many times the light blinks. This indicates a specific fault. The light will blink N times, then pause, then blink N times, and it will repeat this indefinitely.
      • Jesnjonbond
        • 12
        Light does not blink it stays on and solid until I hit the power button
        • Jesnjonbond
          • 12
          Power supply board
            You have at least three bad capacitors on the power supply.
            This is a very common fault with this power supply.
            The ones which have a bulge in the vent are definitely bad, but the other lone one at the top of the image should also be replaced.
            What is written on each of these capacitors?
            ***WHATEVER YOU DO, do NOT use RadioShack or Fry's capacitors. They are not suitable for power supplies.***
            • Jesnjonbond
              • 12
              All three are CapXon 1500uF35V and the one on the left is 2200uF16V
              • Jesnjonbond
                • 12
                Is this bad as well?
                  That part is fine.
                  If you want to confirm that it is those capacitors you may heat them with a hairdryer. Often, this will give them a little extra life. Demonstration with a Samsung I repaired:
                  https://www.youtube.com/watch?v=Ggn_ggaPvc4&t=2m35s
                  CapXon rears its head again -- I have replaced more CapXon than any other capacitor.
                  Replacement parts:
                  http://www.digikey.com/product-detai...2409-ND/613770 (x3)
                  http://www.digikey.com/product-detai...0257-ND/266266 (x1)
                  +$3 shipping
                  Check the diameter is correct.
                  • Jesnjonbond
                    • 12
                    Ok I've replaced the bad capacitors and the tv will now come on but it is all black and white. Have I messed something up or did I forget something?
                    Thank you for your help so far.
                    • Jesnjonbond
                      • 12
                      Any ideas? Anyone!
                      • gilly1984
                        • Jun 2012
                        • 751
                        Picture fine but just in black and white?
                        Turned colour up in settings?
                        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                        • MisterD
                          • Oct 2012
                          • 668
                          As Gilly said: Use Menu, go into settings and adjust the Color Level. Have you done this yet? Results?
                          • Jesnjonbond
                            • 12
                            Yes I have done this with no result. The picture is slightly checkerboard. It's only noticeable when you get close.
                            • Jesnjonbond
                              • 12
                              Could I have messed up something on the power board to cause this?
                              • Mark369
                                • Jul 2009
                                • 163
                                maybe you need to reseat the cables
                                • Jesnjonbond
                                  • 12
                                  What do you mean?
                                    The checkerboard patterning indicates that colour is not being demodulated from composite video correctly.
                                    Check HDMI, component, other modes.
                                    • Jesnjonbond
                                      • 12
                                      I am an idiot thank you guys very much
                                        Care to share more?
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • unimatrix93
                                          Inexive (Vestel) TV constantly blinking after plugging in
                                          by unimatrix93
                                          Hello everyone, I have a constantly blinking Inexive LED TV.
                                          Display is: VES390UNVA-2D-N01
                                          Mainboard: 17MB97​
                                          PSU: 17IPS71
                                          The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help....
                                          03-26-2025, 08:36 AM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
