My first TFT repair - Nec LCD1703M
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    As you can see there are 3 Hermei caps bad.
    I am wondering if the power supplies of TFT displays in general use same esr caps as computer power supplies.
    Then I suppose I could replace the 2x 1000uF 16V Hermei caps with 2x Rubycon YXF 1000uF 16V or Nichicon HD....
    And another thing that I need some help is about the 470uF 16V Hermei caps. Will it hurt if I replace them with 1000uF 16V ones?
    Thank you very much for your help
  • smason
    • 1652
    Re: My first TFT repair - Nec LCD1703M
    I'd try to keep the replacement caps close to the original values.
    Perhaps Willawake can suggest a supplier in Greece.
    What's the symptom? That design looks vaguely familiar.
    I'd check the transistors in the inverter section for shorts.
    • goodpsusearch
      • Oct 2009
      • 2848
      • Greece
      I haven't connected it on ac yet... I found it some hours ago.
      Can you show me the inverter section? I have no experience with tft...
      • retiredcaps
        • Apr 2010
        • 9271
        It is the left hand side of the power board where PT201 and PT202 sit. smason is probably talking about Q209 through Q212.
        --- begin sig file ---
        --- end sig file ---
        • b700029
          Banned
          • Sep 2010
          • 640
          There is no harm in doing that. There are filter caps and rising of capacity can't make trouble in this case.
            master hoarder
            • May 2008
            • 12160
            • Bulgaria
            They do, more or less.
            The only difference is that the power supplies of LCD monitors don't have large toroidal coils on the output rails like PC PSUs do. Therefore, you can actually go with much lower ESR capacitors if needed. I still recommend staying close to the specs of the original capacitors, though. The only exception to this rule is if the original capacitors are rated for 85C - never put 85C caps in a LCD PSU because they just won't last very long.
            By the way, make sure to replace all of the caps, not just the few bad ones. The only cap you don't need to replace is the big 400v one on the primary side because those very rarely fail.
            • goodpsusearch
              • Oct 2009
              • 2848
              • Greece
              I wish I could afford replacing all of the capacitors..
              Judging from the pcb discoloration, the 4 output caps are the ones that get very hot.
              Thank you for your help! I am waiting for replacement caps. I think I'll use Rubycon YXF 16V 1000uF.
                master hoarder
                • May 2008
                • 12160
                • Bulgaria
                I guess I should have been more specific - replace all of the caps on the PSU only. There's actually only 3 more (1 is the small start-up cap, and the other 2 are the blue ones for the inverter).
                Yes, but the 2 blue ones in the middle of the board (extra filter caps for the inverter input) have also likely taken a beating after the 4 outputs caps failed since they are connected in parallel.
                • goodpsusearch
                  • Oct 2009
                  • 2848
                  • Greece
                  I see 4 extra caps....
                  Very useful info! What exactly an inverter does, how many volts it takes as an input and how many volts it outputs? Thanks!
                  • PlainBill
                    • Feb 2009
                    • 7034
                    An inverter steps the inverter supply voltage (in this case, probably 12 volts) up to the 700 volts required to light the CCFLs. It also adjusts brightness and protects against broken or aged CCFLs. Datasheets for the inverter controller will give many more details.
                    PlainBill
                    • Lumberjack777
                      • Dec 2010
                      • 464
                      Another thing the inverter does is to change DC to AC. In this case 12v DC would be converted to upwards of 700v AC. The inverter performs the opposite function of a rectifier.
                      The interesting thing about an LCD power supply/inverter is that it takes the source AC current (120v or 240v) and converts it to DC. Then the inverter section turns around and converts the DC to AC. The frequency of the AC can thereby be specified for the CCFL lamps.
                      • Rtech
                        • Jul 2010
                        • 1095
                        An Inverter to me,prior to getting into Monitors, was also called a Variable Speed Drive up to 250KW,which was powered by 3 phase mains,and the voltage was changed to DC and then back to AC,via Thyristors.Some of the DC became again 12volts and this was used in the Controller Board to vary the output freqency,so speed could be adjusted from 0-100hertz,therby slowing or speeding up the Motor .This was used in lots of ways for example,Coca Cola used one to vary the speed of the cans going along conveyor belts,use in 'Carbon Black' manufacture,and the one I liked ...to vary the speed of the motor the pulled the coffin through the curtains,and no doubt will be used when its curtains for me.Although they say, that only the good die young,so I have a long way to go...I hope.
                        • goodpsusearch
                          • Oct 2009
                          • 2848
                          • Greece
                          You can't be lucky every time...
                          I replaced 6 caps...
                          2xHermei 1000uF 16V LE (General Purpose Low ESR) -> 2xRubycon YXF 1000uF 16V
                          2xHermei 470uF 16V LT (Lower ESR) -> 2xRubycon YXF 1000uF 16V
                          2xHermei 150uF 25V LZ (Ultra Low ESR) -> 2x Panasonic FM 220uF 35V
                          ..only to find out that the lcd is broken
                          Anyway thanks for your help!
                          I consider it a training session for the next time.
                          • alexanna
                            • Mar 2010
                            • 1346
                            Re: You can't be lucky every time...
                            Ya really gota be realy careful with this stuff,It almost like eating potato chips you can't do just 1!
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2640
                              i'd still keep it. just wait for another 17" LCD with f*cked up electronics (like some of those Samsungs which always show "out of range" or something) and retrofit the panel into the NEC..
                              i did something like this a dozen times.. always worked fine if the resolution of both panels is the same..
                              • goodpsusearch
                                • Oct 2009
                                • 2848
                                • Greece
                                Is that possible with Nec LCD1703M and Samsung Syncmaster 710V????
                                (https://www.badcaps.net/forum/showth...843#post264843)
                                • Rtech
                                  • Jul 2010
                                  • 1095
                                  i have replaced faulty screens with panels from othe rmakes and models with no problem,for example 17" to replace a 17" etc.It can be not a simple as that, but it is worth a try if you have a possible replacement,.
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2848
                                    • Greece
                                    And how you do it? Is there a step by step guide? I have no experience in this...
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      Well, hopefully the whole panel ie the lights and screen are the same dimensions as the original, and the whole unit just replaced.
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2848
                                        • Greece
                                        This IBM L170 monitor was the panel donor that helped me bring this NEC TFT back to life
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • SwedishDiesel
                                          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                                          by SwedishDiesel
                                          Howdy folks,
                                          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                                          10-30-2021, 12:47 AM
                                        • Paxman_Swede
                                          Identifying caps on an old Zoom 9000
                                          by Paxman_Swede
                                          Hello!
                                          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                          I have studied the board and...
                                          01-14-2025, 09:51 AM
                                        • iMic
                                          Vintage AT Power Supplies - Selecting Capacitors
                                          by iMic
                                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                          02-19-2023, 06:45 PM
                                        • edith
                                          Caps and how to find one to replace
                                          by edith
                                          Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
                                          Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
                                          Thank you!
                                          06-11-2023, 05:00 PM
