I have just acquired two of these monitors and they both power up and show the floating test box until I plug in the VGA cable then all I get is a black screen with a floating box with "Not optimum mode Recommended Mode: 1280 x 1024 60Hz ". I appreciate this is a recognised problem of the Novatek IC1200 chip on the IC board with some fixers claiming that a 50 Ohm resistor soldered to two adjoining pins (nos 5&6) on the chip cure the problem. I have tried this without success but have no idea apart from 50 Ohm what other characteristics the resistor has to have - or whether there is another fix or cause now been found.
Anyone able to help on this?
Regards
Johnboy183
Regards
Johnboy183
