Hisense 50P6
  • viewerau
    • May 2020
    • 315
    Hisense 50P6
    What would you look for first, to diagnose this fault please?
    Many thanks.
    Signature:Seemingly hopeless tv fixer
  • nomoresonys
    • 12328
    • U.S.
    Re: Hisense 50P6
    Inspect for damage and clean and re-seat same cables from t-con board to panel driver boards.
    • nomoresonys
      • 12328
      • U.S.
      Re: Hisense 50P6
      Can also try powering up with just one of those cables hooked up, check display, then do the other side, do all connect and disconnects with tv unplugged to insure against any errant surges or such.
      • viewerau
        • May 2020
        • 315
        Re: Hisense 50P6
        Thank you....I will travel to my friends house and look at those areas.
        • viewerau
          • May 2020
          • 315
          Re: Hisense 50P6
          Thanks for the assistance.
          TV brought to me today.
          I undid and reconnected all the ribbon cables, no success.
          In wiggling each cable from the mainboard, to the tcon, the two ribbons leading from the tcon, and as well as the edge boards, I noted nothing happening to the picture.
          I turned it all off again, took a photo at start up again, as pictured (normal lines)
          I then did as suggested,disconnected the power, removed one ribbon one side of the tcon, restarted, picture attached.
          Powered down, reattached first ribbon and disconnected second ribbon, picture attached.
          Put it all back to how it was, and lines still present in picture.
          POWER BOARD ...RSAG7.820.7748/ROH
          T-CON BOARD.....RSAG7.820.7931/ROH
          MAIN BOARD......RSAG7.820.7970/ROH
          Owner says tv has been good for 5 years, turned it on the other day, and all there was is the lines.
          Your valued directions please, novice status.
          Many thanks
          • Diah
            • Feb 2013
            • 6557
            Re: Hisense 50P6
            disconnect the LVDS from T-CON side and turn on... if the BL come on then follow the test
            - keep the LVDS disconnected from T-CON side.. make jumper wire between the power boards 12V line and feed it direct on F1 ( black fuse ) on the T-CON and turn on see how the screen look.
            if the first point the BL didn't come on... but u still have the 12V on PWB ... do the point 2 but use torch light to discover what the screen displaying.
            • lotas
              • Jan 2016
              • 4848
              • Russia
              Re: Hisense 50P6
              Such a defect can be caused if liquid gets on the screen and gets on the decoder cables in this area where the strip was formed.
              • viewerau
                • May 2020
                • 315
                Re: Hisense 50P6
                Thank you.
                I cannot see any area around the edge boards or ribbons, indicating any dampness
                The owner says she uses a dry lint free cleaning cloth on the screen only, as there are no children in their house
                When you refer to BL, I am assuming that this is backlights
                I am sure there is no problem with them, as when the panel is turned on, and is laying screen side down, I can see lots of bright lights via small holes in the panel area.
                Does this indicate they are ok, or is the test needed?
                Thank you.
                • Diah
                  • Feb 2013
                  • 6557
                  Re: Hisense 50P6
                  i asked if the BL turn on after you unplug the LVDS between main boards and T-CON... if yes then do the test i mentioned... feed the F1 on T-CON 12V from power boards while the LVDS always disconeccted from T-CON side... tell us what do u have on screen
                  • viewerau
                    • May 2020
                    • 315
                    Re: Hisense 50P6
                    Diah...Thank you.
                    I have only completed part 1 of the test, as I am unable to know where to connect things for this part of your test "make jumper wire between the power boards 12V line and feed it direct on F1 ( black fuse ) on the T-CON and turn on see how the screen look."
                    I am just a newbie, with poor abilities.
                    I had the set off, and disconnected the lvds from the tcon. The backlights all came on as they do normally.
                    About 3 seconds after the backlights all turn on (light seen trough holes) I noticed that the red on/off switch blinked 17 times.....it did not blink previous to disconnection.
                    In regards to the tcon, is this the actual fuse area to check to see if it is also getting 12v or similar?
                    Thanks, the help appreciated.
                    • viewerau
                      • May 2020
                      • 315
                      Re: Hisense 50P6
                      I may be on the wrong track here, but is this what you mean me to do?
                      Connect a wire between 12v pin on power board, and ouch it to fuse and see what happens?
                      Sorry for my novice level.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        Re: Hisense 50P6
                        Fuse F1 has a p marked on it its by the connector
                        • Diah
                          • Feb 2013
                          • 6557
                          Re: Hisense 50P6
                          +1 exactly
                          be sure LVDS disconnected from T-CON side... & the pin on PWB are 12V (measure it ) before u make the jumper..
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            Re: Hisense 50P6
                            Originally posted by Diah
                            +1 exactly
                            Diah im following this thread as still learning will this test make the screen show test patterns or something just curious
                            • Diah
                              • Feb 2013
                              • 6557
                              Re: Hisense 50P6
                              no patterns with this kind of T-CON , because failed Firmware section on it... but it will send full puffer to panel to displaying complete / half white depending on ribbon connection. if this happened with complete /n half white then MB are the cause.
                              • viewerau
                                • May 2020
                                • 315
                                Re: Hisense 50P6
                                Thanks...
                                Do I need to buy some of these to do the test ( I don't have any), or do I just find some old wire, strip both ends, and then just hold them in place to do the test?
                                My apology, but as I say, I am a novice, that unfortunately requires me to ask things before I commit to tasks that I have not done before.....SORRY.
                                EDIT.....When I do the test, do I still need the lead (with an 8 pin connector) in place on the power board, that runs between the power board and the main board? (AGAIN SORRY)
                                • Diah
                                  • Feb 2013
                                  • 6557
                                  Re: Hisense 50P6
                                  1- just use one wire to put it in place
                                  2- all sockets should be in place as original... only the LVDS cable disconnected it from T-CON side.
                                  • lotas
                                    • Jan 2016
                                    • 4848
                                    • Russia
                                    Re: Hisense 50P6
                                    In this case, do not forget to screw in the bolts so that there is a ground (GND) with the TV case.
                                    • Diah
                                      • Feb 2013
                                      • 6557
                                      Re: Hisense 50P6
                                      correct.. good point
                                      • viewerau
                                        • May 2020
                                        • 315
                                        Re: Hisense 50P6
                                        My apology for being a bit slow with this reply.
                                        Before I did anything I checked to see if the pin on the PS had 12v when turned on...it did.
                                        I then turned it all off and then put the lead on the 12v PS and onto F1 on the t-con and the screen went bright white with no lines.
                                        • Prott
                                          [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                          by Prott
                                          Hello dear badcappers!
                                          The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                          Backstory:
                                          After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                          If there is a way to narrow down which memory module is faulty it would make my life much...
                                          06-03-2024, 12:05 PM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • Diah
                                          Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
                                          by Diah
                                          this set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
                                          this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which...
                                          11-14-2020, 01:43 PM
                                        • tomketcz
                                          schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                                          by tomketcz
                                          Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                                          10-01-2025, 03:13 AM
