Seiki SE39UY04 Red standby light, not powering on
    Re: Seiki SE39UY04 Red standby light, not powering on
    Thermal expansion due to heating and cooling can over a long period of time causes hairline cracks in the soldered joint resulting in an intermittent connection or even a burn up which is what you have , all you need to do is re solder the transformers pins with some fresh solder to prevent this happening again.
      Well the power supply fixed the TV and now I have a working 4K TV for 29.00
        Thanks for the follow-up on the repair.
          You are most welcome. Thank you for all the help you have given me on even more than this one TV. I do appreciate your time and efforts.
            I have a problem with these symptoms: Seiki SE39UY04 Red standby light, not powering on
            I will start a new thread because I think that's what I'm supposed to do. But first I have to post my first post as a new member. That's what this is.
