Vizio VW37L HDTV20A, No picture but good sound
  • Scev
    • Jul 2013
    • 15
    • US
    I've got a Vizio VW37L HDTV20A that recently stopped showing a picture. Instead, I get a rainbow colored set of lines. I've done a little research, and think it might be a bad TCON board, or maybe the power feeding the board is no good (both complete guesses on my part)? Can anyone suggest some things to test?
    Attached are some pics of the symptoms, as well as the circuit board on the back of the TV.
  • Scev
    • Jul 2013
    • 15
    • US
    Re: Vizio VW37L HDTV20A, No picture but good sound
    Noticed Visio voltage regulators seem to be a common problem, so went through and tested all the ones I could find. Any of these look suspect? Also, when double checking I had all the measurements right, my multimeter lead accidentally slipped between pins 1/2 of U16 connecting them together. So U16 is now 0V on all pins, and so is U44. Did I kill U16 or pop a fuse?
    U15
    1084
    0721CL
    2.08
    3.32
    5.11
    U16
    7805CT
    REH651G
    10.97
    0
    5
    U17
    AMC1117
    F0736J
    2.08
    3.33
    5.11
    U19
    1084
    0721CL
    1.24
    2.49
    5.11
    U20
    1084
    0721CL
    0.55
    1.80
    3.30
    U21
    AMC1117
    F0736J
    0
    1.24
    2.48
    U22
    AMC1117
    F0736J
    2.05
    3.31
    5.15
    U44
    117GC
    1117L
    8.4
    9.64
    10.98
    • manstoblame
      • Jan 2011
      • 85
      First off let me say I am not a TV repair person just a tinkerer. That said I suggest cleaning the ribbons that go to the t-con board for starts see if that works, there is something I have heard is better than alcohol that will keep and help protect the connectors. I personally used a little nail polish remover but recommend(rubbing) alcohol as a quick cleaner just to be safe. a little on a white cotton rag and you'll see the difference. If that doesn't work replace the board.
      I believe that some of the voltages of the regulators are supposed to drop because they route current to other components at least I think so. Hopefully someone else here will have better help in response to if you shorted anything I really can't say!
      • Scev
        • Jul 2013
        • 15
        • US
        Tried cleaning the connector, didn't fix the issue. Anybody have any knowledge on the voltage regulators? Are the values I posted in the acceptable range? Any idea what I broke by touching pins 1/2 together on one of them (see a couple posts above for details)?
        • Glitcher
          • Mar 2013
          • 673
          • USa
          From the measurements you have before you touched the pins I would guess that U16 is the biggest regulator on the board? You may have shorted it out.
          • Scev
            • Jul 2013
            • 15
            • US
            I was thinking that as well (shorted out U16). However, wouldn't one of the three pins on U16 be the input? All three pins read 0V now, so that has me thinking I killed whatever feeds U16, but I have no idea how to figure out what that would be.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              From the previous readings the 2nd pin is reading 0v so this might be ground? Not exactly sure, but then it would kind of make sense if it shorted to ground. The input would go to ground and read 0v? That's just my theory with my limited electrical knowledge lol.
              • Scev
                • Jul 2013
                • 15
                • US
                Glitcher, that sounds about right, but they were only connected together for a second. So something must have blown up, I just don't know how to figure out what that was.
                  That U16 is fed by the 12v from the power supply through a SMD fuse, I see two SMD fuses on that main board close to the white connector that goes to the power supply.
                  • Scev
                    • Jul 2013
                    • 15
                    • US
                    Thanks for the tip budm. I tested each and F2 is open, so that must be the one I blew. So....
                    1) Any place I can pick up a SMD fuse locally (Radio Shack, etc), or do I have to order them?
                    2) Once I fix my mistake, any troubleshooting tips to find the cause of my initial problem (no picture)?
                    Scott
                      You can use standard 3AG body size 3A fuse and the fuse holder from Radio Shack and just solder the two wires from the fuse holder to the SMD fuse's ends without removing the old fuse (if you get the SMD fuse, you can solder the new one right on top of the old fuse).
                      You need to install the new fuse and check the voltages again to see if anything else is damaged.
                      By the way, pin 1 of that 5V regulator is the input pin, pin2 (middle pin/tab) is the ground pin, so you just accidentally ground the 12V to ground through the fuse.
                      The pictures that you shown looks like the T-CON or the panel problem.
                      • Scev
                        • Jul 2013
                        • 15
                        • US
                        Installed a new fuse, all the voltage regulator values I previously posted are still valid...doesn't look like anything else is damaged. What can I test to try and narrow down what the problem is?
                          I would look at the T-CON board next. Pictures of the T-CON?
                          • Scev
                            • Jul 2013
                            • 15
                            • US
                            I believe this is the TCON board?
                            • Scev
                              • Jul 2013
                              • 15
                              • US
                              Bump for any tips on what I can test on TCON board...
                                Have one of the two ribbon cables connected one at time and see what you see on the screen.
                                • Scev
                                  • Jul 2013
                                  • 15
                                  • US
                                  One thing I'm not sure if i mentioned...the first pic in my original post is with no source, the last picture in my original post was with a HDMI signal present. You'll notice the color difference. The below tests are with no source connected.
                                  Right side disconnected...
                                  Left side disconnected...
                                    If you have not already, I would be fiddling with the tab bonds.
                                    • Scev
                                      • Jul 2013
                                      • 15
                                      • US
                                      Fiddle with tab bonds? I'm not sure what this means...
                                        I am curious, If you have a source hook up and per second picture (left cable's disconnected). Will you see normal picture half the screen?
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • maricm
                                          Vizio m65-c1 picture flashing on and off on the screen
                                          by maricm
                                          HI all,
                                          hope someone point to the possible issue before I start buying replacement parts.
                                          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                          Backlight stays on all the time,
                                          Sound works fine.
                                          screen keeps changing form black to full picture in about 1sec intervals.
                                          Picture looks fine with no visible artifacts.
                                          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                          Disconnecting left and right ribbons on...
                                          11-25-2023, 06:32 PM
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
