Panasonic TC-P42S2
  • heavymachines
    • Mar 2011
    • 1028
    Panasonic TC-P42S2
    Hi all been some time since i needed some help been doing pretty good on my own however this set has me miffed atm. OK to get started on the issue with this set it started out as no power on nothing no signs of life no response from power button, so i ordered A board and now i get power on and the panel indeed energizes no menu or a picture it seems to go to service mode but you can't see it on panel i would have to unplug tv to get it to get out of service mode.
    have both the service manual and troubleshooting manual for this set i think the problem is still in A board, could not find exact replacement for TNPH0831 (1) [A]
    so i ended up with TNPH0831(3)[A] as closest replacement and it is a panasonic re-certified replacement A board... any light on this would be great since i am stuck atm.....
    also according to the owner it has some sort of surge however i am finding out these sets have a lot of A board issues and the a board is very pricey want to go more in depth before i send this A board back .
  • heavymachines
    • Mar 2011
    • 1028
    Re: Panasonic TC-P42S2
    any ideas bump?
    no burns no bad caps i believe everything else is fine, no shorts that i can find, will post pic's but don't think it is necessary since manuals are prevalent for this set, however i still have a bit to learn about schematics, and this set is probably the most tricky to figure out......
    • heavymachines
      • Mar 2011
      • 1028
      service manual and training manual... and panel sticker says nothing of vs and va voltages and no labels on any connectors so yeah its fun, but some help with schematic translation would be awesome......
      • heavymachines
        • Mar 2011
        • 1028
        service manual can be had here upload being silly for some odd reason so here is the link
          A glowing panel with no image is often a sign of a bad A board, especially if only the service menu works.
          • tw2005
            • Oct 2011
            • 6458
            Deleted
            I think there's more to the revision of the main board than what you've posted. You can have identical board assemblies but different config and parts used on it depending on the model.
            Was the board you replaced from a 42" model?
            • heavymachines
              • Mar 2011
              • 1028
              well to be more descriptive it seems to be able to go into service mode however it does not show on screen it just unable to do anything once in service mode have to unplug it and plug her back in to get power button to work again....
              • heavymachines
                • Mar 2011
                • 1028
                Originally posted by tw2005
                Deleted
                well according to the listing it is for a 42 inch Panasonic compatible with certain models this one being one of them, however i think you may be correct i may have a board that is not compatible, finding the exact board same revision i just have no luck finding.... the 2 boards look identical except a connector it does not use and its revision new one is revision 3 and original is rev 1 now i suppose there may be a secret way to change firmware however can't see nothing on screen to do it lol.. looks like i may need to send this bad boy back eh?
                • tw2005
                  • Oct 2011
                  • 6458
                  I had a look at SJ website and there are a lot of different versions of TNPH0831. I don't believe the 2 or 3 is what to look for. There is a suffix template on the board and the rev is determined by the placement of a series of jumpers.
                  If you post up some hi res shots of both boards it may reveal some clues of what you've got or check out SJ.
                  These are the revisions on SJ
                  TNPH0831 42S2
                  TNPH0831AB 46S2
                  TNPH0831AC 50S2,50C2,P5032C
                  TNPH0831AD 54S2
                  TNPH0831AE 58S2
                  TNPH0831AF 65S2
                  TNPH0831AG 42U2
                  TNPH0831AJ 50U2
                  TNPH0831AR 42PX24
                  TNPH0831AT 42C2
                  TNPH0831AU 46C2
                  TNPH0831AV 50C2
                  • heavymachines
                    • Mar 2011
                    • 1028
                    okay sorry been super busy however here is some pic's of the boards i cannot find these other numbers other then the ones in pic perhaps i am blind lol...
                    • heavymachines
                      • Mar 2011
                      • 1028
                      TNPH0831 42S2
                      TNPH0831AB 46S2
                      TNPH0831AD 54S2
                      TNPH0831AE 58S2
                      TNPH0831AF 65S2
                      TNPH0831AG 42U2
                      TNPH0831AJ 50U2
                      TNPH0831AR 42PX24
                      TNPH0831AT 42C2
                      TNPH0831AU 46C2
                      TNPH0831AV 50C2
                      don't see any jumpers , having tough time telling what revision i have, i see the template for it but interpreting it is not very clear ... and both templates have same markings as far as i can tell if need more pics i will upload em...
                      suffix both look like it's marked as AB....
                      • tw2005
                        • Oct 2011
                        • 6458
                        From what I can make out , neither had the jumpers there and that would make it no suffix which SJ had listed for your model which was the picture I posted from their site. I don't have any more clues at this stage.
                        • heavymachines
                          • Mar 2011
                          • 1028
                          well that sucks... further more shop jimmy is out of stock and i am avoiding ebay get nothing but garbage from there seems like and i paid way too mch for this board that is a very expensive paperweight, could i be have another issue other then main board ? is was a surge that took it out, and this is the listing of the "new" A board which is clearly refurbished by Panasonic according to the box it came in here is listing for that http://cgi.ebay.com/ws/eBayISAPI.dll...=1119421679017 so looks like i burnt on this one i am out of ideas myself.....
                          • tw2005
                            • Oct 2011
                            • 6458
                            The only 2 thoughts I'm having are either the A-board is suspect again or as you said it was hit by a surge so that obviously reached the A board so could have travelled also to either the C buffer boards or SC20 at the SC board via the ribbon cables .
                            what is interesting is the fact you described what sounds like a TV that started normally with a panel that is energised but no image.
                            I have created this very scenario working on my Sc boards but I had sound because the TV had been tuned and it was a working Tv that I was using to test my boards so made it obvious what board caused it.
                            Anyway, I was messing with one of the tiny octal buffer ICs marking C541 which was faulty. I was using scavanged parts but one gave me SOS7, next one everything was normal except I only had a grey primed panel but no image.
                            Once I got a good chip in there it was back to working.
                            It's a possibilty?
                            • heavymachines
                              • Mar 2011
                              • 1028
                              It's a possibilty?
                              will look into that,,, will report back...
                              • Shawn5005
                                • Nov 2014
                                • 1
                                Do you still have the TNPH0831 3A Board?
                                • SlickClick
                                  • May 2011
                                  • 91
                                  just picked one of these up when I got it; it had 6 blink code, opened up found SC board power & ribbon off, reconnected then got a 7 blink code...
                                  Began to disconnect finally got unit to power up w/ no image w/ the SC to A-board ribbon off and the lower buffer ribbon off...
                                  I'm leaning towards bad A-board but could it be a lower buffer & SC board set both bad..? I dont know how to confirm, downloading manuals now too; thanks for those btw...
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    will be most likely shorted TNPA5105AD SC board and or SD/SU boards. check resistance across sc2 and also find Q661 on the SC and see if that's shorted
                                    • h82loseejr
                                      • Oct 2015
                                      • 79
                                      • america
                                      did you ever get this working i need the a board if you were interested in getting rid of it
                                      • kcblack
                                        • Nov 2016
                                        • 3
                                        Hello, New Here
                                        Have 2010 Panasonic TC-P42S2 plasma with the 10 blinking lights. Cannot bring up a menu from the TV or HD digital cable box. When first turning the set on it clicks like normal and then after a few seconds clicks again. Black screen with blinking power light.
                                        Took off back panel and disconnected the board on the left side. Turned the power on and now have 6 blinking lights. This suggests the SC board is bad. Is there a chance it could be the SS board and how do i test to see if the board is malfunctioning?
                                        Thanks for you assistance,
                                        K
                                          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                          by sam_sam_sam
                                          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • boosti45
                                          Macbook pro logic board replacement parts quesion
                                          by boosti45
                                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                          08-21-2024, 05:23 AM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
