Reset Dell N5110 Bios password
  • camelion
    Banned
    • May 2013
    • 35
    • safi
    Reset Dell 15R-N5110 Bios
    1. remove motherboard from you laptop.
    2. connect power and turn on.
    3. short G2201 only one time.its shout down.
    4. remove power and assemble your laptop again
    5. Then go to bios by press F2.
    note: This instructions for help only and for professionals only. general users do not try this.
    Don't short G2201 two times or in even count.it will show you password prompt again.
  • dj_ricoh
    • 2073
    • uk
    Re: Reset Dell N5110 Bios password
    i can`t see nothing there !
    i swear.
    i`m not old but that pic its so small ...
    • camelion
      Banned
      • May 2013
      • 35
      • safi
      i swear.
      Short g point indicat un pictcher
      • cerealx
        • Dec 2013
        • 4
        • mexico
        my motherboard can not find the reset point Might tell me what is in my motherboard I put my photo here
        sorry for my bad english XD
        • kandyan
          • Mar 2013
          • 53
          • Sri Lanka
          this method worked for me. but i did something hes not mentioned.
          01.remove the RTC battery
          02.plugged in Ac adapter and power on
          03.Short those small rectangle pads for single time
          04. turn off
          05. then re-assemble everything with new RTC battery and its working without that annoying password.
          • trebo
            • 514
            • Wales, UK
            04. turn off
            hello kandyan
            I see two pairs of rectangle pads, what pair are you talking about
            the pair pointing up and down or the pair pointing left to right
            • dspok
              • Jan 2014
              • 554
              • Nepal
              he is saying these pads.
              • trebo
                • 514
                • Wales, UK
                thanks
                • kandyan
                  • Mar 2013
                  • 53
                  • Sri Lanka
                  exactly..those are the pads for clearing pw and its clearly mentioned in schematics.
                  • gigabytexxl
                    • May 2014
                    • 1
                    • canada
                    what can i short these with? dont want this to happen!
                    • chermonped
                      • Nov 2014
                      • 1
                      • usa
                      hello kandyan I know this was earlier this year but the post on the reset of the n5110 bios how can you power the motherboard if you take it out i'm the same situation mentioned lost bios pswd or don't i have to remove the motherboard. chermonped
                      • ckelsay
                        • Jan 2015
                        • 1
                        Hello! I can confirm the procedure kandyan suggested. It is a little tricky but with a little time I was able to completely clear the password. I pulled the board out, pulled the bios battery out, plugged it in, clicked the power button, shorted the tiny pads on the board with a flat-head screwdriver once and then turned off the power. Put everything back together, and easily went into BIOS setup.
                        Thank you for the procedure! It saved my computer.
                        • helgahll
                          • Sep 2015
                          • 2
                          • russia
                          Hello there! I really need your help
                          Tell me, please, where on my motherboard are these pads?
                          • neps4u
                            • Aug 2010
                            • 1
                            04. turn off
                            Works fine
                            • sungrief
                              • May 2020
                              • 1
                              • BG
                              Hi guys,
                              Might be unrelated and needing a new topic but here it goes:
                              I have a modded N5110 at home with unlocked UEFI settings.
                              Touched some of them, now black screen upon booting.
                              I am looking for a procedure how to reset the CMOS completely?
                              Assuming shorting the PW pins wont do it in my case...
                              Thanks for the potential help
                              • mohammed mohan
                                • Nov 2017
                                • 210
                                • F12
                                thanks
                                Mohammed Mohan
                                • patrlew
                                  • Jun 2020
                                  • 1
                                  I have tried the above procedure, however, it has still not cleared the CMOS completely. I used an online service to retrieve the master admin password for this laptop, however it then asks for the HDD password. Any additional assistance would be appreciated.
                                  Don't want to trash a perfectly good laptop...
                                  • piernov
                                    • Jan 2016
                                    • 4439
                                    • France
                                    HDD password is on HDD itself. Replace HDD.
                                    • evserv
                                      • Jun 2014
                                      • 365
                                      • Russia
                                      Attach a photo of the password window to this topic...
                                      • unknownuser1138
                                        • Dec 2018
                                        • 1
                                        Thanks to everyone on here - following the instriuctions I was successfully able to remove my forgotten BIOS password from years ago!
                                        • mikeybass
                                          Dell 9010 MT BIOS Update Always Fails
                                          by mikeybass
                                          Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
