Westinghouse L2610NW 26" 16:10 LCD backlite problems
  • rogerk
    • Jul 2012
    • 17
    I know it needs some caps. Wanted to ask if anyone repaired one before I open and start cutting them free.
    Last year (july2011) backlite would go off after 5mins. or so when over 75°. Found all the caps glued down so as not to see their values.
    None puffed, all colored Lt.Brown (like old bad panny's)
    I made some holes, mounted a CPU fan over the main cap. Worked til today.
    Now has the 2 sec. to black and speaker pop. Can read the text w/flashlite.
    Westinghouse L2610NW 26" 16:10 LCD Monitor UPC No: 882777052402
    Made by
    CHIMEI INNOLUX CORP STSP BRANCH
    3 SEC 1 HUANSHI RD
    SOUTHERN TAIWAN SCIENCE PARK
    TAINAN HSIEN, 741 TAIWAN
    Main pcb; APD logo = Asian Power devices inc. model FM-140A12
    There are 26" TV tuner versions; 26H730, VR2680 ect. but are Aspect Ratio: 16:9 Might use same PCB.
    Thanks in advance. I will document repairs.
    Roger
    A side note; Son's old Viewsonic VX1962WM only needed 2- 220mf @35v. caps. C101 and C302 so I have a working monitor.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Westinghouse L2610NW 26" 16:10 LCD backlite problems
    It's interesting to this thread pop up this week. Last week I got the same monitor (Westinghouse L2610NW) on Craigslist for $10. It was advertised as not working, but when I got it home it worked fine. I should note, however, that there was quite a bit of buzzing coming from the inverter. It went away only after I turned the brightness up to and above 90%.
    Therefore, I tore it open regardless just to see if there is anything obvious.
    Mine had brown caps as well - they were all United Chemicon KY series. Those are extremely reliable. If your caps are the same, then I don't think new caps will help it. (Or maybe they will? I don't know for sure since I didn't replace mine either.)
    Personally, I think it's the inverter design that's causing this. For those interested, the inverter uses 6 HV inverter transformers and there are 12 CCFL tubes. The CCFL tubes are grouped in sets of 2 and each set is wired in series to the HV output of each inverter transformer (i.e. 2 CCFL tubes per HV transformer). The circuit that drives these transformers is a single circuit comprising of 4 MOSFETs arranged in full-bridge (the inverter transformers primaries are wired in parallel to the output of the 4 MOSFETs). Now this is a very good design in terms of reliability, but it's too simple and (at least from what I understand) if any of the CCFL tubes or HV transformers becomes bad or degraded due to age, it can throw off the whole inverter. And with that many CCFL tubes and transformers, I think some of them are bound to degrade faster than the others. I don't know for sure if this would be the reason for these inverters to go 2-seconds-to-black, but I think it's a plausible theory.
    So before replacing the caps, I would say try playing around with the backlight brightness to see if that will bring it operational. Since my monitor was working, I wrote down the menu sequence to turn the brightness up/down. There are 6 buttons on the side of the monitor, with button #1 on top and button #6 (the ON/OFF switch) on the bottom.
    To turn the brightness all the way UP:
    1) Press button #5 and wait for about 1 to 2 seconds
    2) Press button #4
    3) Press and hold down button #4 for about 3 to 4 seconds, then release it and wait for another 5 seconds
    4) Turn the monitor OFF (press button #6), and then turn it ON.
    To turn the brightness all the way DOWN:
    2) Press button #4
    3) Press and hold down button #3 for about 3 to 4 seconds, then release it and wait for another 5 seconds
    Note: the number of seconds above is just approximate and you don't have to be very exact.
    Let me know if this works for you.
    • rogerk
      • Jul 2012
      • 17
      Awesome Idea. I will try.
      The fan I added really dinna help above 70° room temp.
      Roger
      • rogerk
        • Jul 2012
        • 17
        was off sence june.
        Now no backlite at all.
        I want to fix..
        • rogerk
          • Jul 2012
          • 17
          Tried again tonight.
          Can just see video as usual.
          Backlite not lite.
          Powering on/off via button 6.
          Did get some internal speaker pops.
          Roger
          • rogerk
            • Jul 2012
            • 17
            PCB pics added.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Pictures are poor too much flash. You need to work out what are the secondary windings on the 6 inverter transformers. I cannot find your transformer -They could be as in this
              http://www.lcdparts.net/TransformerD...ProductID=4175
              or as in this
              http://www.lcdparts.net/TransformerD...ProductID=2796
              Power off meter on 2000 ohms you need to measure S1>S2 S3 >S4 for each
              transformer. and post the results
                This form factor transformer may have pin out like this:
                http://s807.photobucket.com/albums/y...t=DSC00191.jpg
                • rogerk
                  • Jul 2012
                  • 17
                  selldoor your links are inop.
                  Any of my TMS92859CT's ?
                  Going by budm's pic
                  pin1 1350 ohm
                  pin2 .8
                  pin3 .8
                  pin4 1340
                  Xfomers OK ?
                    All of them read like that?
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      And it does.
                      I uploaded some pictures of when I took mine apart. Just used that monitor last week for an hour or so and it still works, though it was quite loud (lots of buzzing from the inverter).
                      As I mentioned before, I suspect that the design of this inverter is not the best when the CCFLs and inverter transformers become unevenly worn. I think the only 2 possible solutions are to either replace the CCFLs/inverter transformers or tweak/fiddle with the feedback circuit (and maybe disable some of the CCFLs after doing this).
                      **EDIT**
                      Just found a note from when I measured the secondary sides on my inverter transformers. Starting with the transformer on the right and continuing left (on that first topside picture):
                      5.14 KOhm, 5.21 KOhm, 5.13 KOhm, 5.22 KOhm, 5.14 KOhm, 5.13 KOhm
                      • rogerk
                        • Jul 2012
                        • 17
                        Thanks for the Pics. Way better than what I took.
                        Still to repair
                        Roger
                          "5.14 KOhm, 5.21 KOhm, 5.13 KOhm, 5.22 KOhm, 5.14 KOhm, 5.13 KOhm" That is big different from rogerk readings.
                          • rogerk
                            • Jul 2012
                            • 17
                            Yes, but not sure of pin outs.
                            I went to like, pin 1 to last acrost top for 1st. Like a IC.
                            And so on for the other 3.
                              You did it correctly, I never seen that high (>5K) resistance for 26" TV.
                              But since all your transformers reading are within 3% from each other, then we need to look somewhere else for the problem, I just hope it is not the lamp problem, but you will need to verify them.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                Can you do a close up of the caps on the inverter board.
                                With it all connected up can you unplug all but the first lamp lead switch on and see if it flashes. its difficult but try and remember how bright and if it has any colour. Switch off
                                Unplug that lead and plug in lead 2 Switch on and see if it flashes etc. Switch off.
                                Repeat for all six and report result. High voltage 1200v so remember to switch off.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  Yes, I'm surprised too.
                                  To be honest, though, I don't remember how I tested these transformers. I *think* I tested between the 2 HV output pins, but I really do no remember any more. Will need to tear it down to test it again, but that's not exactly something I want to do unless I really have to (I get highly impatient with prying LCD monitors open).
                                  They are all Chemicon KY on my board. His seem the same too. Overall, this PSU board is built quite well IMO.
                                  • rogerk
                                    • Jul 2012
                                    • 17
                                    momaka's ohm reading for any xformer I think is posted wrong.
                                    I was using my old Fluke 23 multimeter.
                                    Which Caps that be? looking for bottom seal expanding?
                                    I will try your lamp idea.
                                    Just so you know, at power up is no CFL backlite.
                                    • rogerk
                                      • Jul 2012
                                      • 17
                                      Just got 6 trade in retired 17" LCD's. With no use for.
                                      Thinking why not use one to test the CCFL's one at a time.
                                      To comfirm if prob is in display or the FM-140A12 PCB.
                                      Any thoughts before begin ?
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        You said originally that it was 2 seconds to black are you saying now that it
                                        just doesnt come on at all.
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • alro7779
                                          Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
                                          by alro7779
                                          Hello, guys!
                                          I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
                                          Alex....
                                          10-03-2025, 05:49 PM
                                        • jean luc ferre
                                          display screen problems after changing motherboard
                                          by jean luc ferre
                                          First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                                          I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                                          Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                                          Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                                          09-11-2025, 10:28 AM
