Acer AL2216W Resistor ID
  • gagnoja
    deringer
    • 8
    I have a ACER AL2216W LCD monitor that uses the v2 power board. I have only seen this board in one post in your forum.
    I have identified a resistor in the attached picture that was damaged when the monitor failed. It is approximately centered at the top of the picture just to the right of the heat sink, I circled it in red. The picture I attached is not my actual board, it is identical to mine but I'm using it to show the location of the failed resistor.
    When mine failed it burned the resistor and I have no way of identifying the value.
    I'm hoping that someone has the same board and can help me to identify this resistor. I believe it may be a 110ohm high temperature resistor but with mine burnt and the picture not really clear enough to identify the bands I'm not certain.
    The component # on the board is #816
    Any help is appreciated.
    Jim
  • gagnoja
    deringer
    • 8
    Re: Acer AL2216W Resistor ID
    Jim
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      I was going to try and help but you have given far too little information.
      A picture of YOUR board showing the position of the resistor would have been a lot more useful.
      A hint as to which of the other threads mention the board would have been useful.
      I have not the time nor inclination to look at them all to find it.
      A clue as to the board number would have been unbelievably useful.
      • gagnoja
        deringer
        • 8
        The other thread on your forum with the same board was from 9/26/2010 by
        Badcaps Guy
        Titled - Acer AL2216W Dead!! Here we go!!
        I found it when I did a search for AL2216W which is the Model of the Acer Monitor. The other thread as referenced above was one of the results. Apparently the Acer AL2216W used a couple different p/s boards and this is the one I have. I have seen it referenced elsewhere as Ver 2. Not sure if that is official.
        The service manual does not have anything for the power supply board.
        The part number on the board is 79090140.
        My issue is to verify the value of component #816 which is a high temp resistor as mine was charred when it failed and after cleaning we can't identify the code rings. Trying to verify the value of the resistor.
        I've includes additional pictures but as you can see the resistor has already been removed, that is why I initially sent the other picture for easier identification of the component.
        Any Help is appreciated
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          OK That is a lot better - I think the picture you first put up is a different board number
          - cant be bothered to check it out, but if you read this thread you may find something to your advantage
          https://www.badcaps.net/forum/showth...044#post303044
          By the way you need to change probably all those green caps - one looks bulged and leaky?
          • gagnoja
            deringer
            • 8
            Thanks for your help it is greatly appreciated.
            I am replacing all the caps but I wanted validation on the resistor so that I could order them all at once.
            Again thank you for your help.
            Jim
            • jetadm123
              • 2169
              Resistors don't normally burn up like that without help. Looks like transistor Q801 is connected to one end of R816. Try checking it for shorts.
              Also, cap C818 is bulged and starting to leak.
              • gagnoja
                deringer
                • 8
                Will check Q801, I am replacing all the caps.
                Thanks for the heads up
                • UniT3d
                  • May 2011
                  • 43
                  Hmmm .....
                  ILPI-033 resistor R816 should be 100Ohm 5% (brown/black/brown/gold). Hope that helps.
                    Yes, it does look like 100 Ohms resistor from the picture at shopjimmy.com
                    Does the reading show open on that resistor?
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      We established what the resistor was in post 5
                        I just look at the service manual to be sure that it is 100 Ohms, it uses the same board as used in Viewsonic VA2226W. I know I have seen this board before. See page 66.
                        • gagnoja
                          deringer
                          • 8
                          I want to thank everyone for their responses, this is all great. Selldoor help me to identify the resistor earlier today but the other cautions are appreciated. Having the schematic is invaluable.
                          Thank you all!!!!!!!!!!!!!!
                            You need to check that transistor and the Zener diode that is connected to the Base of the transistor. The circuit will work without the resistor/transistor in place, that section of the circuit is used for protection in case the 16V B+ gets too high, then the transistor will start conducting if the regulation circuit has failed.
                            • gagnoja
                              deringer
                              • 8
                              Thanks I appreciate the heads up. I'll check it out.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • Destroyer-Br
                                [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                by Destroyer-Br
                                Hi everyone,
                                I'm working on an Acer Nitro 5 unit with the following specs:
                                • Motherboard: LA-J871P Rev: 1B
                                • Model: Acer AN515-55-59MT
                                • S/N: NHQ7JAL00403906A973400
                                • SNID: 03902728734
                                Initial Issue
                                The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                04-17-2025, 08:18 PM
                              • ugamazing
                                Assistance with identifying resistor value on 820-02918 A2992 board?
                                by ugamazing
                                Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                                I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                                09-06-2024, 08:33 AM
                              • Roman555
                                [Offer] Acer IPIMB-AR (w/o on-board gfx) of Acer Predator G5920 fullflash BIOS
                                by Roman555
                                I'd like to offer an Acer IPIMB-AR Rev: 1.02A fullflash BIOS (cleaned ME region). The model is for Acer Predator G5920.
                                It is a model that is based on Intel Z77 PCH and doesn't have on-board graphics and video connectors.
                                I suppose it doesn't have any restriction about discrete graphics cards (I mean they don't have to be in a whitelist).
                                Please don't mistake this mainboard with a similar model with on-board graphics and based on Intel B75 PCH.
                                Jumper FLASH_OVERRIDE
                                default position: 1-2 - BIOS area protected
                                position 2-3 allows to dump BIOS or write
                                06-26-2025, 05:15 AM
