Harbor freight Needle picks
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Today, I found this at harbor frieght:
    They also happened to be on sale this week... $2.99 instead of $4.99
    Logically, one would aim for the striaght pick:
    Which can be used like a dentist's pick:
    ... But on most boards will not go all the way through:
    This is a problem... It makes it easy to accidentally push out the hole liners, which can kill a board.
    However, the other picks work better on small holes, this one especially:
    In addition to having a seemingly more gradual taper, they also prevent pushing too far:
    The other non-straight picks also work to varying degrees. The straight pick also works well on larger holes (like on modern dual layer PSU boards).
    I thought I would let the community know that this exists... heck, they work better thent he electronics soldering picks a few Aisles over. They also are a lot easier to come by than dentist picks, which can be hard to source locally.
    Comments?
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Harbor frieght Needle picks
    they look a little big in the pics.....which is why I use the dental picks. Some boards have really tiny holes that I know those wouldn't get through without damaging the through holes....nice find though, worth the beans to try for sure.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      the straight one, yes.
      The tip of the angled one is actually small enough to fit any capacitor hole that i have seen while recapping...
      sigpic
      • c_hegge
        • Sep 2009
        • 5219
        Nice. I used to have a pick a bit like that (only it might have been a bit smaller), but I lost it. I just use braid now.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5044
          • US
          I actually have a set of those EXACT same ones (and a few others). Not good really for that. Too big.
          I use the smallest sewing needle I can find, held by a pair of wide pliers.
          those joints look kinda bad rat. This is why I <3 my hakko 808 so much. After walking a cap out, I (with the hakko turned up to max) just suck that excess shit out after its wetted with good flux and leaded solder. I was doing a video card the other day with TERRIBLE solder and tiny joints. Was one time I had to actually use my hakko more then once on a few holes
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            That Board was a dead one that I had in the junk pile. no caps were actually re-installed on it. The joints look bad because they aren't completed joints. Besides, when I use this style of recapping
            I previously used the needle+ pliers routine for this style recapping, IMHO it sucks. it is too clumsy and due to the local unavilabilty of SS needles (only nickel plated), It is a last resort. Not to mention that the needle snap in half really easily. I don't recommend it at all.
            I don't have the $$$ for a hakko 808. I mainly use braid (now that I have a 60W iron).
            Uranium, if you have a dead board, try the angled pick. it is NOT too big if you use it as I showed. Yes, the straight one is too big, as I demonstrated in post #1.
            The only reason I did this was as a guide for those who don't have the $$$ for a nice professional iron/station or a Hakko 808. I actually think it works really well.
            sigpic
            • Toasty
              • Jul 2007
              • 4171
              Harbor FrEIght even has them....
              veritas odium parit
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                Re: Harbor freight Needle picks
                I just wanted to point out something RatDude said so people who are new to soldering/recapping know it. Stainless Steel is what should be used because solder will not stick to it. Good job with this find RatDude.
                "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
                Mark Twain
                "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
                John Paul Jones
                There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
                Rod Serling
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Fixed. I guess the rule about engineers being unable to spell is true for Engineering students too.
                  I took some more pics, this time using another dead Board:
                  Yes, it had some stupid stuff done to it in the past. I will performing a hole clearing on the hole marked by the silver arrow.
                  After heating the joint with a heavily tinned tip and getting the tip of the pick to go in, we get this:
                  After twisting out the pick, we get this:
                  Which this capacitor:
                  ... fits right into:
                  I see no issues with this method.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    It won't stick to nickel either... the problem is that such needles are PLATED and the plating easily wears/flakes off, revealing plain steel, which solder DOES stick to.
                    I am not sure what the picks' tips are made from but so far I haven't had wicking issues.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I will add a little note to the usage- on some boards the angled pick goes most of the way through with 1mm left. The key is to be close, as the method is about allowing leads to fit, not eliminating all of the solder.
                      sigpic
                      • LLLlllou
                        • May 2011
                        • 201
                        They're also great to use as finger extensions in places you can't get your fingers into. I recently used them to jimmy a cap into a spot behind a heat sink that no human could have accessed without them. Saved me allot of time by not having to unsolder the heat sink, remove the transistors, etc. Pain in the ass, but still a life saver. I love my HF picks!
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          I actually bought a second set of these awhile back... because the first set I abused the crap out of... the old ones still work for soldering but since I was replacing my needle files anyway, I figured I'd grab a fresh set. a fresh set which I have yet to solder with (since the old set is in my desk and right in front of me).
                          sigpic
