Center tapped transformer rectifier question
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I'm going to use a center tapped UPS transformer for a project and would like some advice on how to rectify its output. The two windings are 18v each and I already use those on the AC legs of a bridge rectifier to get around 40v out which is fine (the center tap is floating at this point), however a separate part of my project requires a lower voltage of just 18v, so how can I achieve that ? Obviously I could just place another bridge rectifier between the center tap and one of the legs, but that's not very space-efficient, so I was thinking of using 2 diodes on the center tap and other 2 already inside the rectifier....complicated I know, so I put together the rather horrible schematic to try and explain how I see it. Is this correct ?
    Wattevah...
    • 31256
    Re: Center tapped transformer rectifier question
    follow your current paths - boom.
    your shorting the windings with the diodes!!
      Build it and find out for yourself if your theory is correct.
      Look real close at your drawing.
      • fester
        • May 2017
        • 158
        • Slovakia
        you cant achieve that,only if you have separate grounds for every voltage and you dont plan to connect it together. Maybe the simplest thing will be using of some voltage regulator with higher allowed max. voltage on input
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          It's obviously wrong given that two people so far have sarcastically suggested trying it out, so I'm not gonna do it - can't really afford to scrap components like that Let's take it step by step then, since my brain hurts when working with center tappers like these....step one: rectify the 40v output - no problems here, I'm positive....pun intended
          Wattevah...
          • fester
            • May 2017
            • 158
            • Slovakia
            Or if you accept more ripple on output,you can make two separeted half-wave rectifiers with lower winding as a ground
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Then I guess the only option is to have 4 diodes (a full bridge rectifier) for the other winding as well (can't mix them together): AC side of said rectifier goes to the center winding and one of the remaining ones and the output will be 18v DC.
              Wattevah...
              • fester
                • May 2017
                • 158
                • Slovakia
                something like this
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Originally posted by fester
                  something like this
                  I have seen that before, but I believe that's a half wave rectifier.
                  Wattevah...
                  • fester
                    • May 2017
                    • 158
                    • Slovakia
                    yes it is but if you dont need big current,it is also the solution..
                    • mariushm
                      • May 2011
                      • 3799
                      Something like this would probably work :
                      Note that with two 18v windings you get 36v AC and that's rectified to DC voltage by the bridge rectifier and you get 36 x 1.414 - 2 x voltage drop so actually you'll have a DC voltage with a peak of ~ 50v
                      Also note that it's probably a 230v to 36v transformer, but here at around 3-4 am where there's small load on the network, i get up to 245-248v at the mains socket which is still legal (it's 230v +/- 10% in Romania and most of Europe, so up to 253v is legal)
                      The point is with 245v at the input, you're not gonna have 36v you may have 48-40v ac , and you may have 50-55v peak dc voltage. So for example, use capacitors rated for 63v or with higher voltage rating.
                      As for your 18v requirement ... you'll have 18v rms , if you rectify it to dc you'll have much more. what voltage you actually need? And more to the point, how much current you expect you're gonna need?
                      If it's just let's say 50-100mA for some opamps or something, you could just use a LM317 HV (which works up to 60v input voltage) adjustable linear regulator to and get it over with .. 40-50v in (since i doubt you're gonna install 100000 uF) , 18v DC out at 100mA means it would only waste (~40v-18v) x 0.1A = 2.2 watts of heat, which can be doable with a heatsink. Or, you can use a 3-5w resistor to drop some voltage before the regulator and then some power would be dissipated on the resistor and some on the regulator ... the regulator would only need around 2v above the output voltage to work.
                      For lower currents you could even use a zener diode... see App Note AN954 page 6/14 Resistive Transformerless Power Supply : https://cdn.badcaps-static.com/pdfs/...5df14516be.pdf
                      ... change the zener diode to 15v one or 18v or whatever you're happy with, change the resistor to the value matching your peak current (keeping in mind that you'll have ~ 36v AC and not 110v/230v AC) and everyone should be happy.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        The "high" output of the transformer powers one of those ebay power supply modules and I also need a lower output voltage to power a DC-DC converter which runs a cooling fan for the thing...won't go into too many details on how I built this, but I tested it extensively with a variable laptop power brick which goes up to 24v and it works as it should, regulating the output to the fan based on temperature (nothing WOW there), so the voltage, while not too critical, I wouldn't dare let it go beyond 24v either. Current draw ? I'd say around 1A absolute maximum, if that (perhaps if the fan stalls or jams, worst case scenario).
                        Wattevah...
                          • 31256
                          big clive would run the fan from mains with a capacitive dropper!!
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            That would work too, but the amount of components required to do so outweighs the benefits of using the unused winding like I want to do, plus it's isolated and "to standard" so to say
                            Wattevah...
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              Keep it simple?
                              Follow the white rabbit.
                              • petehall347
                                • Jan 2015
                                • 4442
                                • United Kingdom
                                Originally posted by goontron
                                Keep it simple?
                                is the 9v plus or minus ?
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  ^ Positive.
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    It seems i forgot C3 between the 18v rail and 0v rail.... Ooops.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      How does THIS looks ? It's actually the original idea I had and I then thought I could simplify by omitting two diodes. One of you guys posted something similar, but the values were off, so THIS is what I believe it should look like.
                                      Wattevah...
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8703
                                        mariushm has the only workable solution as far as I can tell - only 4 diodes needed and though his drawing only has 7.5V windings, you can use full 12V (24V/CT). A lot of these other "solutions" don't quite work because the two windings are not isolated from each other. If there is a need for isolation of the two GNDs (i.e., 0V potentials), then you'll need two isolating switching converters to get this done or another transformer that has isolated secondaries...
                                        Also note that the capacitance on the output legs will need to be fairly large to filter the higher voltage output...
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • acedogblast
                                          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                          by acedogblast
                                          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                          03-01-2023, 08:24 PM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
                                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 12:00 PM
