Center tapped transformer rectifier question
  • Radio Fox
    • Jan 2010
    • 281
    Re: Center tapped transformer rectifier question
    Originally posted by goontron
    Keep it simple?
    Your diagram shows 2 diodes in series directly across the outer winding of the transformer.
    Something's gonna blow!
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      What do you think of the one I posted then ? Would that work ? It's like starting off by rectifying just one of the windings (with respect to the center tap) and then adding an additional bridge for the other one too so in theory nothing should go boom.
      Wattevah...
        Two more diodes are also connected across the center tap and the top and bottom windings.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8704
          Go with mariushm's solution if you want a common 0V point.
          None of the other ones will work trying to have a common ground point, at best. The halfwave version will work with a common ground point but has awful PF, awful regulation, and will require double sized transformer; and the double bridge solution requires that you keep the two circuits isolated from each other - they must never touch.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Originally posted by eccerr0r
            The double bridge solution requires that you keep the two circuits isolated from each other - they must never touch.
            They don't: one runs the supply, the other runs the fan - I'd say that's pretty separate
            Wattevah...
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #26
              Oh shit.... I need to pay attention better when designing schematics...
              Follow the white rabbit.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8704
                As long as someone doesn't go and think "oh, this GND is black. That GND is black. It'll be just fine if I hook them up together..."
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #28
                  Nobody will tinker with the insides of this power supply and I'll label them Fan GND and supply GND
                  Wattevah...
                  • Radio Fox
                    • Jan 2010
                    • 281
                    There's no need for a bridge for both supplies. You can full wave rectify both outputs with just 4 diodes, and still have a common earth. The attached diagram is similar to the one mariushm posted, except my one has the smothing cap -ve for the higher voltage connected to earth rather than the half-voltage output. (either configuration will work).
                    The 48Vdc output uses the 4 diodes as a bridge. The 23Vdc output uses D3 & D4 with reference to the centre tap to full wave rectify the output.
                    D3 & D4 will therefore be passing the combined current taken from both supplies, so will need to be rated accordingly.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      #30
                      In my case D3 and D4 are built into the bridge rectifier itself, though it's a 50a bridge, so I doubt it will complain.
                      Wattevah...
                      • bauto601
                        KDM 480W PSU upgrade succes! (opinions?)
                        by bauto601
                        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                        A "nice" YoungYear unit? - Badcaps
                        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                        12-26-2023, 03:05 PM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
                      • acedogblast
                        [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                        by acedogblast
                        First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                        Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                        03-01-2023, 08:24 PM
                        ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                        This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 04:40 PM
                        ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                        This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 12:00 PM
