42" Vizio No Picture has Backlight
  • MisterD
    • Oct 2012
    • 668
    This is a newer LED/LCD TV, has LED for Backlighting and an LCD Display Panel.
    It does power on but has no display, has only a blank grayish screen with no video, I tried hooking up a dvd player as a source but since I can not see any images on the tv screen I can't tell what input mode is selected. with this set is was easier to measure voltages on the small fuses on both the Mainboard and T-Con Board. instead of measuring at the power supply connectors and taking a chance on the meter probe slipping and shorting out.
    It has all dc voltages present, 5 volts, 12 volts and 18 volts. I measured these on both sides of the fuses to ensure the fuses are good as well as voltages being present. I noticed that the processor under the metal shield on the mainboard is generating some heat so hopefully it is working, but the heat sink on the T-Con stays cool even after leaving the set on for over 1 hour. I removed and reinstalled the T-Con board therefore re-seated attached ribbon cables and visually inspected the board. At this point I think the T-Con board has failed and is causing the problem, I do have another posting on this set but could not edit the heading or delete the post and I felt like the heading was misleading. Model Vizio XVT3D424SV. please reply back, your help is appreciated. Thanks!
  • XmouseX
    • Aug 2011
    • 158
    • US
    Re: 42" Vizio No Picture has Backlight
    Pictures of the main board? Also have you checked the Voltage regulators on the main board?
    • MisterD
      • Oct 2012
      • 668
      Being a newer set this main board does not have the typical AMC1117 Voltage regulators, here's some pictures I found on the net of the same exact boards this set uses. I have only checked the voltages on the fuses.
      • MisterD
        • Oct 2012
        • 668
        More Main Board Pictures
        • XmouseX
          • Aug 2011
          • 158
          • US
          Sorry to ask, but can I get a close up picture of the area where the back light cable plugs in. Like a 2 inches perimeter around the connector. Also are all your surface mounted fuses good?
          • MisterD
            • Oct 2012
            • 668
            The backlights are working and they are LED, they are powered directly from the power supply board therefore there's no need for inverter boards. Do you still want a close up picture of where the back light cables plugs in?
            Thanks!
            • MisterD
              • Oct 2012
              • 668
              Okay, I seem to be at a Stand Still with this one, being a newer LED TV, I'm not getting much help. I went ahead and ordered a replacement T-Con Board in hopes that it will fix my problem. Thanks.
              • MisterD
                • Oct 2012
                • 668
                Question: If the backlights are working and the LCD Panel is not doing anything, does it still let the backlight shine through to form a white or grayish screen? in other words does the LCD Sceen have to be working in order to see anything such as a white display with no picture? or is that just the backlight you see on the screen?
                  You can easily verify that by disconnecting the cable to the LVDS cable from the T-CON.
                  http://s807.photobucket.com/albums/y...t=DSCF1912.jpg
                  But the high contrast screen, you may not easily see the glow.
                  • MisterD
                    • Oct 2012
                    • 668
                    bud, can you tell me which cable or cables to disconnect from the T-Con ? here are more pictures from my actual tv I'm working on. Thanks.
                      Not sure if the backlights will still come on if you remove the LVDS cable and the power cables.
                      • MisterD
                        • Oct 2012
                        • 668
                        I also tried to get sound by hooking up a dvd player to the RCA Composite and audio input jacks and pushing the input button on the remote control but no results, but I did notice the brightness change while pushing the remote input button several times.
                          If you have backlights which its job is for the light source only so you can see pictures on the screen, the it sounds like the T-CON may be bad or video processing may be bad, but since you are not getting the sound (not 100% sure) then the main board may have problem, it can be FIRMWARE is corrupted or bad EEPROM. I wish I have the answer.
                          • MisterD
                            • Oct 2012
                            • 668
                            If you look at the bottom of the mainboard just above the RGB Connector there are small black plastic squares the one on the left is labeled "audio" it's a small audio jack the one on the right has a gray cover over it and it is labeled "optical" when I push the input selector on the remote there is a red light behind the gray cover on the optical jack, if I leave the input so the red light stays on the tv will shut itself off in 1 minute or less, I'm not sure why and was also wondering what the small audio jack is for? Thanks
                            • MisterD
                              • Oct 2012
                              • 668
                              The T-CON board I ordered is on the way, I should get it soon, I hope that will fix it, I will keep you posted. Thanks.
                                That is what is called TOSLINK using Optical (light source such as red LED you are seeing) for digital audio. The small 3.5mm AUDIO may be for the PC Audio input which is close to tghe PC VGA connector.
                                http://en.wikipedia.org/wiki/TOSLINK
                                • MisterD
                                  • Oct 2012
                                  • 668
                                  Okay, Thanks!
                                  • MisterD
                                    • Oct 2012
                                    • 668
                                    Hi Budm, After trying different input sources again I did get sound, I'm using a dvd player with composite video/rca jacks/audio in, since there is no video and you can't see what input you select I figured out each time you push the input button on the remote it takes at least 7 seconds to take affect so I actually would do this, push input on the remote wait 10 seconds, push input again and wait 10 seconds, I kept doing this and eventually got the right one and Bingo we have sound. Now I'll be real glad to get my new/used T-Con Board. Thanks again.
                                      How expensive is the T-CON?
                                      • MisterD
                                        • Oct 2012
                                        • 668
                                        $54.99 Free Shipping from E-Bay.
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • maricm
                                          Vizio m65-c1 picture flashing on and off on the screen
                                          by maricm
                                          HI all,
                                          hope someone point to the possible issue before I start buying replacement parts.
                                          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                          Backlight stays on all the time,
                                          Sound works fine.
                                          screen keeps changing form black to full picture in about 1sec intervals.
                                          Picture looks fine with no visible artifacts.
                                          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                          Disconnecting left and right ribbons on...
                                          11-25-2023, 06:32 PM
