Philips LCD 32PFL6305 inverter sometimes hard to start
  • PowerAmpFreak
    • 977
    • Sweden
    Re: Philips LCD 32PFL6305 inverter sometimes hard to start
    Made the psu modification according to bulletin. Seems to do the job.
    No problem to start up the inverter, I'm still a little "quiet" and won't shout out any horrays yet, as I've told before this set can work fine over 50 times then suddenly refuse the same number of times. Anyway, my kids will perform this "field test" and we will know shortly if something is not working properly, for sure
    • arkadij
      • Oct 2012
      • 1
      • Russia
      Thank you. I did a revision and it worked perfectly. Sorry for my English.
      • maklD
        • Feb 2013
        • 2
        • Russia
        Thank you
        • maklD
          • Feb 2013
          • 2
          • Russia
          SCC_82202_PSU Rework Instruction_v4.pdf I can not load! help, throw a working link
            Works for me in Chrome...
              Hi Tom, did Ron or you upload the bulletin to your website?
                I don't remember uploading it. If Ron would like to contribute anything it would be much appreciated... he can send me a PM. Currently only I can add documents to the site, it is managed using FTP and text files...
                • vvuk
                  • Mar 2013
                  • 2
                  • Bosnia
                  #28
                  HI, is it possible to order new board for this TV? I`m having the same problem.
                  Thanks.
                  • PowerAmpFreak
                    • 977
                    • Sweden
                    #29
                    Thanks.
                    It's easy to do the service bulletin and it will work!
                    I did this and set starts every time.
                    • kopa
                      • Jul 2013
                      • 1
                      • Estonia
                      #30
                      Thanks, it help me. TV is working now.
                      • guybrushthreepwood
                        • Dec 2013
                        • 44
                        • Italy
                        #31
                        Hello to everyone! I'm new here and I've found this thread while trying to understand how to repair my lcd tv. I own a 32PFL3605H/12 that requires a lot of attempts before being able to successfully turn it on.
                        What happens is that the blue light on the power supply turns on, I can hear the typical arching sound like if the bulbs try to light up but nothing more than that. After a while also the blue light fades out.
                        If I look at the lcd panel in a very dark place, I can notice let's say a round white shadow on the middle right section of the panel, a shadow which disappears in a matter of seconds, nothing more.
                        I was confident it could be an issue related to capacitors from the power supply gone bad but all of them are perfectly fine.
                        I've made a deeper research and I've found out that many deem the IC801 guilty for this kind of issues then I've found this thread along with the very well detailed rework instructions from Ron.
                        Do you believe I could try to make the rework or is my problem something different? My lcd tv was manufactured on April 2010 but I don't know how to find out its manufacturing week nor the one of the power supply unfortunately.
                          • Dec 2013
                          • 44
                          • Italy
                          #32
                          I've to add that both the panel and the television (so I guess its motherboard) work perfectly fine WHEN I succeed in turning the television on and after when I succeed for the first time, then it is simpler to turn it on (less attempts) though it still doesn't happen on a regular basis.
                            • Dec 2013
                            • 44
                            • Italy
                            #33
                            Hello again! There are news, bad ones unfortunately. I don't know if it has something to do with the fact that I've taken out the power supply and left it out of the television for a while to see if I could find the necessary parts for the rework (probably it has though I've handled it with great caution and stored it properly) but today I've tried to put the power supply in place again (without having done anything because I haven't still managed to find all the necessary parts) and now the television has changed his behaviour.
                            I can't see the white round shadow anymore and the screen doesn't light up anymore, no matter how many times I try. The television instead does regularly turn on and when pointing a flashlight on the screen I can see that everything works well, just no backlight.
                            It definitively seems an inverter problem but I don't know if it is linked with the power supply or the backlight lamps. Is it the final sign which tells me that I have to rework the power supply or did the failing power supply damage the lamps and I can throw the television away?
                            I hope that someone could give me at least an hint on some checks to do, I'm desperate.
                            • federalhouse
                              **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                              by federalhouse
                              Hi everyone,
                              I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                              **Background:**
                              I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                              **What I've Tried So Far:**
                              1. I accessed
                              08-01-2024, 07:03 PM
                            • ash91
                              Hp pavilion 15 not detect hard drive
                              by ash91
                              Hello gentelmen .... this is my first post and sorry for my bad english,
                              so my proplem is my laptop keep losing hard drive even if i but the
                              hard disk in the cady (the box that can replace the dvd rom with hard disk)
                              when i turn the laptop on the massage that said no boot media found pop on
                              the hard disk is fine and to be sure i try another hard
                              i also update my bios to the last update
                              the 5 volt is present on the hard connector on the motherboard
                              the dvd rom work fine when i but a windows dvd in it
                              also when i boot from flash...
                              06-07-2023, 01:45 PM
                            • x_orange90_x
                              Vizio E55-E1 bad backlights or bad inverter?
                              by x_orange90_x
                              I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                              I don't know how exactly to test the inverter itself. Is it...
                              01-29-2025, 09:24 PM
                            • madura2010
                              DAY11AM6E0 hard disk drive and optical disk drive not detected
                              by madura2010
                              Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                              i checked the connectivity of ribbon=good communication with hard and motherboard
                              changed hard disk and checked=3f0 error persist
                              sata power=+5v available
                              Then checked data capacitors=all good
                              Then checked data lines path connectivity to pch=all good
                              reflashed...
                              03-12-2023, 09:09 AM
                            • G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                              by G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                              It does power up when pressing the power button.
                              I already try the power button while plugin the plug with no result.
                              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                              Could this be an PSU or eMMC issue ?
                              07-19-2025, 03:43 AM
