Sanyo ce32ld08dv-b lcd
  • efwiofoi
    • Nov 2013
    • 76
    • uk
    I have a sanyo ce32ld08dv-b lcd with a samsung lta320ap06 panel. there seems to be no t con on this there is a ribbon cable between the main board and top of the panel.
    the picture starts with horizontal lines accross all but the top inch, and beelds out to more and more white. if powered off and on agan it starts again.
    it has a vestel 17pw26-4 psu and a vestel 17mb45m-3 main baord.
    i suspect the panel, any chance it could it be the main board?
    Re: Sanyo ce32ld08dv-b lcd
    I would suggest panel, a ton of these newer vestels dying with panel faults. SAMSUNG panel but not made by Samsung, just subcontract by Vestel (I think the glass is made in Korea/China but they tab bond and assemble in Turkey.) I do happen to have a known good main board for this set (well from a "Toshiba" but part # the same) if you'd like to try it but I doubt it would fix the issue.
    I know someone on this forum who was trying to debug a similar problem on a D4000 Samsung which also turned out to be panel issue, traced it down to some components on panel board but never fix it, I suspect the panel fried because it was in fault state too long.
    • efwiofoi
      • Nov 2013
      • 76
      • uk
      i took the bezel off and tried pushing on the ribbons, nothing makes any difference.
      has exactly 12v on the fuse. it looks like some some sort of componet failure on this board.
        Try heating/freeze spraying on parts of panel board..
        • Ahakim
          • Apr 2013
          • 64
          The t-con board must be suspected first. Is the power incoming voltage right (well-regulated)?. Caps on this board? Verify the the tap bonds..
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I have replaced over 5 of these with the same issue, total junk panels !
              Always the panel? Never figured out if it was something on T-con?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                The tcon is built into the motherboard, and I have loads of the boards on hand it is always the panel.
                • nomoresonys
                  • 12322
                  • U.S.
                  good info., I'm never buying a sanyo.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    This tv isn't built by Sanyo its built by vestel which is basically a junk tv company that makes tvs for oems who dont want to build the tvs them selves so they can make more profit. Sanyos actual tvs that they make are good and well built shame that the get a cheap oem like vestel to build there tvs.
                      Vestel produce some of the worst TVs out there and names like Toshiba, Sharp, JVC, Sanyo and Hitachi all rebadge Vestel sets. Disgraceful in my opinion -- but what can you do?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        True.
                        • nomoresonys
                          • 12322
                          • U.S.
                          wonder, is there any way to tell, before you open the back if it's vestel made crap?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Normally by the model number and sticker on the back.
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              Google "model no power supply images" usually brings something up
                              and when you see its a vestel something else ........
                                Usually you can tell by the input plate - modern "fat" Vestel sets only use one of two types and the "thin" ones only have one type of input plate.
                                • Kilroys
                                  • Feb 2014
                                  • 70
                                  • Sweden
                                  Interested to see what models of Sanyo, which has Vestels parts.
                                    Useful info, thanks! Do you have any more info you can share on Vestel? I can upload any manuals, tech notes, schematics on my own site.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Also tom thank you for runing your site its very helpful
                                      • cheeky2
                                        by cheeky2
                                        05-25-2024, 03:27 AM
                                      • lberkani
                                        Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                        by lberkani
                                        Hi everyone,
                                        I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                        The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                        The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                        I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                        - Toshiba 65UL2163DG
                                        - Vestel 17MB180E mainboard
                                        - Panel VES650QNTX-N2-N42
                                        - Version V1.28.100.0 if available
                                        If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                        11-11-2025, 12:37 PM
                                      • advant
                                        by advant
                                        02-03-2020, 12:25 AM
                                      • Bazilwrc164
                                        Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                        by Bazilwrc164
                                        I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                        The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                        I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                        If anyone can provide:
                                        • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                        • Or a compatible EEPROM dump
                                        07-23-2025, 12:15 PM
                                      • hazi12
                                        Vestel main board 17MB140TC
                                        by hazi12
                                        Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                                        Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                                        I can send a dump....
                                        10-01-2025, 01:28 PM
