LG 55LW5600 Solarized Picture T-Con Board?
  • tvfixer007
    • Feb 2015
    • 86
    Anyone know how to initiate IN-STOP on this TV? Wanted to restore all factory defaults before I make any further progression on this TV. I've done the audio file method but only was able to initiate EZ-ADJ and IN-START.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 55LW5600 Solarized Picture T-Con Board?
    Before doing anything like that I think you should open this puppy up and take some voltage measurements on the T-CON Bd. they are the Vgma voltages.
    • tvfixer007
      • Feb 2015
      • 86
      EDIT included picture of t-con board.
      Got it opened up, will report back soon with voltage readings.
      • tvfixer007
        • Feb 2015
        • 86
        1 16.08
        2 14.02
        3 13.34
        4 12.30
        5 10.31
        6 8.40
        7 8.02
        8 5.91
        9 4.05
        10 3.039
        11 2.372
        12 1.666
        13 .981
        14 .002
        • tvfixer007
          • Feb 2015
          • 86
          After measuring voltages I powered up the TV and now there's just vertical lines all across the panel.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Did you short out any thing? All the cables back in correctly? I think those readings are good, though. Anybody wants to concur on this?
            • diif
              • Feb 2014
              • 6978
              • England
              They don't look right to me, but give me a minute and i'll stick them in that spreadsheet to confirm.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Thank you very much, diif
                • tvfixer007
                  • Feb 2015
                  • 86
                  Here's a picture of the lines present on the display. T-con board still shows the same voltages as what were previously measured. Didn't slip with my probes or see sparks/smoke. Stumped on how this has happened.
                  • tvfixer007
                    • Feb 2015
                    • 86
                    I re-seated all the video ribbon cables lines still present. Absolutely no picture is displaying. I was extremely careful measuring the voltages. Never know though I could have caused a short somehow. Since the problem is now worse than it was it had to be my touch. lol
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      At least no you know you HAVE to get that new T-CON Bd, now....
                      • tvfixer007
                        • Feb 2015
                        • 86
                        I'm thinking my panel is shot. I do have a cracked panel from another 55LW5600 I parted out would it be wise for me to see if that panel displays the lines as well? There was enough picture on the right side of the screen that I believe it can help me rule out if the panel is messed up.
                        • tvfixer007
                          • Feb 2015
                          • 86
                          That other panel wasn't stored in a safe place and has no picture at all now. Guess I'll order the t-con board and cross my fingers.
                          Thank you for the Help Andrew and Diif! Will post back when I get the t-con board replaced! Also have another TV with power supply issue. Will post a new thread for that one.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Yes. Please do appraise us when you get the new T-CON Bd. Good luck.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Did you try disconnecting one side of the panel at a time ?
                              • tvfixer007
                                • Feb 2015
                                • 86
                                I tried that. Just got the new t-con board and the lines are still present.
                                • tvfixer007
                                  • Feb 2015
                                  • 86
                                  I get nothing with either side disconnected.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    are you saying you still get the vertical lines on the side that is disconnected??????
                                    • tvfixer007
                                      • Feb 2015
                                      • 86
                                      It's a bit of a complexity I seem to get different results with only one ribbon cable in. Sometimes right side of screen is white, sometimes the entire screen is just dark. Sometimes there's lines but they are very faded. There's no picture at all though.
                                      Edit: I didn't notice at first but with only the right side connected the left side of screen is a bit brighter than the right side.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        well that's quite a bit different than "I get nothing with either side disconnected." You would be wise to post some pictures of what you are actually seeing with various cable disconnect scenarios to remove any "misunderstanding". Ensure that you are feeding a good signal along with also trying different menu screens to see show as much about what is happening on the screen. My guess would be an SMD capacitor on the bottom edge board might be bad.... but that's going on very little. Where did you get your tcon from? what's history on the set that caused the first post (ie. solarization).
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • shelby5041
                                          Samsung LCD TV no picture backlight on no 12v at tcon
                                          by shelby5041
                                          hi
                                          i have a samsung lcd tv
                                          it powers on with sound and backlight but no picture
                                          all voltages from PS are good 12v 3.3v and 5v
                                          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                          no 12v at the tcon fuse
                                          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                          the odds of having 2...
                                          10-08-2021, 08:21 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
