Hitachi LE55U516 Power supply issue
  • 102mm
    • Dec 2013
    • 181
    • us
    Hi All . I have a beautiful Recycle Center rescue that has only 5V output and the Main cap stays at 160v even when powered on. From scrolling through this forum on a daily basis I remember that the problem is related to the PWM so i first replaced that IC (IC9301 - A6069H). When that didn't work I replaced (IC9001 - SSC9512S) and it powered on for about 5 min then back to the same issue. I'm close to the problem but I am having a terrible time figuring it out any help would be appreciated.
    Images attached, the ICs for the affected area are listed in case you cannot see them clearly
    IC9001 - SSC9512S
    IC9301 – A6069H
    IC9101,9102 – 11NM50N
    Craigslist Picks & Fixes
    2 ea - Samsung 52"
    Samsung 60"
    Re: Hitachi LE55U516 Power supply issue
    Since you do have 5V STBY then replacing the SMPS IC9301 – A6069H is not the problem.
    When you work on TV power supply board, you should look at the power supply board and section out the board to know which section is the standby section, PFC section, main switched supplies section and then find out if you do have Standby power supply to run the main board or not.
    you need to do step by step of testing the Voltages:
    1) If you do have standby Voltage then check to see if you do have PS-ON command signal (when power switch is activated) from the main board to turn on the PFC and the rest of the power supply or not.
    2) If the PS-ON is not present then look at the main board, if it is present then you should have PFC boosted Voltage around 380~400VDC between the two legs of the main cap.
    3) Without boosted Voltage, the rest of the power supplies will not be running due to lacking the boosted Voltage even though the PS-ON may be present.
    "IC9101,9102 – 11NM50N" That must be an error. Do you mean Q?????
    • 102mm
      • Dec 2013
      • 181
      • us
      The PSON voltage is there, 2.8V. when i replaced IC9101 it worked fine for a few minutes, then it started blanking out before it finally stopped working again.
      Typo.. Q9101,Q9102
      2 ea - Samsung 52"
      Samsung 60"
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        One of the pins looks as though it's not soldered and the others could be tidied up.
        • 102mm
          • Dec 2013
          • 181
          • us
          A couple of the pins are not connected and this was not my best soldering.
          2 ea - Samsung 52"
          Samsung 60"
          • 102mm
            • Dec 2013
            • 181
            • us
            I measured the voltages on IC9001 - SSC9512S It's getting the following voltages at power on
            1- 13v
            2 - 13V
            3 - .117
            4 - 0V
            5 - 0V
            6 - 0
            7 - 0
            6 - 0
            9 - 0
            10 - 0
            11 - 0
            12 N/C
            13 - N/C
            14 - .37
            15 - .11
            16 - .11
            17 - N/C
            18 - N/C
            2 ea - Samsung 52"
            Samsung 60"
            • 102mm
              • Dec 2013
              • 181
              • us
              any idea?
              2 ea - Samsung 52"
              Samsung 60"
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Did you resolder properly those pins that looked improperly soldered??
                • jason123
                  • Oct 2015
                  • 1083
                  This is an old post, but because I don't have pictures of the boards, I was hoping someone could leverage info here and help me out.
                  I have the same model. Works fine, but there are thin vertical lines (not necessarily all the way from top to bottom - sometimes top to 1/3 or 2/3 of the screen) and these are not always there. They seem to come and go depending on the type of picture, colors,...
                  I always thougth vertical lines are panel issues. Any thoughts?
                  • jason123
                    • Oct 2015
                    • 1083
                    Ignore please.. I started a new thread here:
                    https://www.badcaps.net/forum/showth...761#post953761
                    • Soulzink
                      Samsug washing machine. Power supply DC41-00189a board issue
                      by Soulzink
                      Hi everyone,
                      I am trying to fix a samsung washinmachine power supply main board.
                      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                      The power supply board reference is the following: DC41-00189a
                      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                      04-19-2025, 06:26 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • KYBOSH
                      Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                      by KYBOSH
                      I have a floodlight-security camera that recently died on me.
                      its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                      Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                      07-01-2024, 06:54 AM
                    • Cookybaby
                      Samsung UN60ES6500FXZA Power Supply Issue
                      by Cookybaby
                      Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                      I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                      Make: Samsung
                      Model: UN60ES6500FXZA
                      Power Supply P/N: BN44-00525A
                      Symptoms: The TV was...
                      08-20-2023, 12:26 PM
                    • lp20th
                      Samsung Plasma TV Power Supply Issue
                      by lp20th
                      I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                      11-28-2023, 10:28 AM
