Philips 40PFL4908/F7 Dead
  • HMRG123
    • Jun 2017
    • 20
    Have this set and the customer said it just would not turn on one day. Q601 is shorted, R611 and F602 are open. I do not see anything else as bad. Does anyone know of anything else I should check before replacing these parts?
    OOPs, just rechecked and found D653 shorted...same question: Does anyone know of anything else I should check before replacing these parts?
  • neilc6
    • Nov 2015
    • 1550
    Re: Philips 40PFL4908/F7 Dead
    The power supply on this model is probably similar design.
    https://www.badcaps.net/forum/showthread.php?t=72916
    • Unspun01
      • Jun 2011
      • 349
      You will want to check and replace at least the following parts:
      F602 (fuse, 2.5A, 250V),
      Q601 (MOSFET transistor, N-channel, 7A/600V),
      D608 (zener diode, 36V, 1Watt),
      R611 (Fusible Resistor, orange, black, silver, gold = 0.3ohm, 5% tolerance, 2 watt),
      D653/D655 (Schottky Diode, SB3A0 = 3A, 100V),
      D607A (zener diode, 27V, 500mW)
      Q602 (2SC5344SY = BJT NPN transistor, 800mA, 30V, SOT-23)
      D607A and Q602 are small surface mount parts on bottom of board.
      See attached service manual.
      • kew1701
        Philips taw6205 ambilight speaker STM32 mcu dead
        by kew1701
        Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
        04-09-2025, 03:59 AM
      • Rubenlily
        Philips 50PUS6503 - dead panel? Picture
        by Rubenlily
        Hey,
        I gave up on my last TV and got a new one to try.
        Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
        Is this fixable in any way or should I just give up on this one too?...
        08-21-2023, 01:07 PM
      • double_DD
        How can I be sure that my EC chip is dead?
        by double_DD
        As the title suggests, how can I be sure that my EC chip is really dead?
        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
        03-12-2025, 07:47 AM
      • Sharpa
        Repair attempt Philips 55OLED804/12
        by Sharpa
        I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
        The symptoms when bought: Philips logo appears then tv turns off
        Things tried so far:
        1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
        2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
        Today, 08:30 AM
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
