Corsair HX620 popped
  • ntoskrnl
    • Sep 2012
    • 17
    • Finland
    My trusty old Corsair HX620 blew the fuse today when I tried to power up my computer. The power supply is from 2008 (manufactured in late 2007 according to the stamp on the PCB). There was no audible or visual spectacle at all.
    I opened it up of course, and there don't seem to be any popped transistors, burn marks or other visually obvious failures. All the capacitors seem fine as well (they're quality stuff). The fuse and bridge rectifier measured good, but I found a heatsinked three-legged TO220 component on the primary side that appears to be shorted. My search was by no means exhaustive so there could be other problems as well.
    The shorted component is in a tight space, so I can't read its part number. However, the one next to it might be identical, and it's a 24N60C3 (datasheet). (This review indeed shows there are two of those.)
    What could cause this? If I replace the shorted FET, is it likely to fail again? Or maybe other components are also dead?
    I can't find an exact replacement for the FET, but Farnell stocks a suggested replacement part that would cost me about 6 € apiece. I'm not too thrilled about replacing it though (with great difficulty using a 15W soldering iron) just to find that half of the other components in the PSU are dead too, so at this moment I'm contemplating on ordering a new PSU.
    • 31262
    Re: Corsair HX620 popped
    dont trust farnell, compare the datasheets.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      That is part of the APFC circuit, you could disconnect it since you are in Finland so you run from 230VAC, the PSU should be able to operate fine like this.
      Just don't try to power it from a ~110VAC circuit because the low voltage going to the bulk capacitor will not be enough.
      If you know what platform it is someone should be able to come up with a schematic that is at least similar, so it would be easier to figure out what if anything needs to be rewired...
      This might give a rough idea:
      https://www.badcaps.net/forum/showthread.php?t=50509
      • ntoskrnl
        • Sep 2012
        • 17
        • Finland
        Hmm, I guess a bit more harmonics in the distribution grid doesn't matter that much.
        The review I linked earlier says it's a Seasonic S12. I wonder what I should disconnect; is it enough to cut the legs on the APFC FETs or should I also disable the APFC chip?
        • ntoskrnl
          • Sep 2012
          • 17
          • Finland
          So I did actually find a burnt component. It's a green disc shaped one marked TR301 (an MOV?), and it's sandwiched right between the main filter cap and the main transformer. There's very little room around it. I'm going to try desoldering it now.
          edit: It's a thermistor apparently: http://www.jonnyguru.com/forums/showthread.php?t=11537 I guess something else is shorted as well then.
          edit: There's no way I could find a replacement thermistor without knowing its specifications. Can I just cut the legs of the shorted PFC FETs and replace the thermistor with a jump wire? I guess this will eventually blow the PFC diode; what about jumping the diode as well now that PFC doesn't work anyway?
            Can you still read the number on that NTC? Dia. of that NTC, 15mm, 20mm?
            the power supply may run at 330VDC without the PFC Voltage booster but it will draw more current to maintain the Output power.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Yes.
              The large coil in the APFC should somewhat limit the inrush current anyways, so the lack of thermistor probably won't damage anything.
              Yes, you can jumper the PFC diode as well. In fact, that will be even better for the efficiency of the PSU (one diode drop less on the primary side. Yay!)
              If the PSU runs like that, I say don't even bother fixing the APFC. Just replace the thermistor and be done with the PSU.
              • ntoskrnl
                • Sep 2012
                • 17
                • Finland
                Alright, so I desoldered the burnt thermistor (it was very "crispy" and fell into little pieces when I removed it, so I couldn't read any markings, but it was perhaps around 10mm in diameter), cut the legs of both PFC transistors, and added a jump wire from the anode of the PFC diode to the main capacitor. It works fine now.
                I think I know what went wrong too. I use a power strip with a switch to turn off all computer related devices. I've been hearing a muffled "pop" every now and then when closing the switch, for the last year or so. I thought this was due to arcing in the switch or something, but now that I think of it, it's probably been the thermistor cooking and popping all along. Eventually it decided to throw in the towel and fail open, and when the PFC transistors started switching, the energy in the coil had nowhere to go so it killed one of the PFC transistors.
                Thanks for all your input.
                • TELVM
                  • Oct 2012
                  • 547
                  • Spain
                  Originally posted by momaka
                  ... you can jumper the PFC diode as well. In fact, that will be even better for the efficiency of the PSU (one diode drop less on the primary side. Yay!) ...
                  Momaka you are referring to the APFC boost diode, like the one at the center of this pic, right?:
                  http://www.hardwaresecrets.com/anato...er-supplies/6/
                    There are two Diodes that need to be bypassed, the one on the heatsink is the boost diode.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      http://i.imgbox.com/9SUE0pWO.png
                      Yes, exactly!
                      I would advise *against* bypassing the second diode (i.e. the one that is not used for APFC boosting). That way, current on the primary will only go through the APFC boost coil, essentially serving as a single-mode choke for extra EMI/RF filtering. Actually, with that other diode in there, this won't work too well either, so I guess it doesn't really matter. You can either remove the second diode completely or short it.
                      • reessi
                        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                        by reessi
                        Hello:
                        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                        I started on the ACER:
                        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                        10-29-2024, 11:31 AM
                      • Yanleb
                        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                        by Yanleb
                        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                        D608, good
                        D618 RF101L4S, good (See warning 1 below)
                        D619 RF101L4S, good (See warning 1 below)
                        D865 RF101L4S, shorted (See warning 1 below)
                        IC464 Inverter HA MC74HC1G14, shorted...
                        03-09-2020, 12:00 AM
                      • modtool
                        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                        by modtool
                        Hi to all,
                        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                        04-01-2025, 08:22 AM
                      • BalkanBoy
                        Dead Razer Blade 14 2022, shorted CPU?
                        by BalkanBoy
                        today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                        Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                        I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                        Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                        I removed coil and injected 0.7V, it draw around...
                        09-27-2024, 12:44 PM
                      • barry101
                        Apple 820-3662 VCore shorted to ground.
                        by barry101
                        Hi, Would appreciate some help.
                        I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                        Get charger light but no fan spin or chime. No liquid damage.
                        Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                        Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                        With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                        Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                        06-24-2025, 07:34 AM
