Has the Dell 1800FP exhibited bad caps?
  • lkvee
    • Feb 2009
    • 198
    When I turn mine on, the power light goes green, and I can't see an image or a backlight. After the customary amount of time has passed, the power light will turn to amber and the backlight will activate. After a few seconds that backlight will go out.
    I can change the behavior of the backlight and power LED by adjusting the contrast. I'm not sure if I can do so by adjusting the brightness.
    I'm aware of an issue with ICE2AS01. During some discussion offline, I was told this circuit essentially regulates all of the power going to the monitor, so if I'm getting SOME power, then the issue could lie elsewhere.
    I just want to confirm the capacitors on this thing are good enough for government. When I opened it up, I failed to find any capacitors whose tops have blown, and I don't believe I found any with electrolyte oozing from the bottom.
    Thanks for reading!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Has the Dell 1800FP exhibited bad caps?
    Often caps will fail without any obvious signs. Some brands have a bad reputation, others are usually OK.
    I am intrigued by your description of the sequence of events. A common failure mode is:
    1. Monitor power is plugged in (signal cable is not connected)
    2. Power LED turns on (green).
    3. Backlight turns on, 'No signal' or similar message appears
    4. Backlight turns off, Power LED remains green.
    5. Power LED goes orange.
    You imply the power LED goes orange BEFORE the backlight turns on. This is unusual.
    Pictures of the circuit board would be a big help, particularly from different directions so we can identify the manufacturers of the caps.
    PlainBill
    • EGuevarae
      • Nov 2008
      • 1336
      PlainBill
      I don't get it either. It sounds like no other thing I've heard or seen. Would be interesting to see what is causing the problem. As per PlainBill suggestion, post some pictures. And to see or know if the caps are good or not so good, their values, series, brand and V rating would help us to help you.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • lkvee
        • Feb 2009
        • 198
        My eyes didn't have the greatest focus, so I may be misdescribing some of the capacitors. I saw:
        KMG at 2200uF and 16V (2)
        KMG at 2200uF and 10V
        SAMWHA/RD at 2200uF and 10V (2)
        PNA at 1000uF and 16V
        SAMWHA/RD at 470uF and 25V
        I don't mind taken this monitor apart again - disassembly was easy enough. I hope the pictures helped.
        • EGuevarae
          • Nov 2008
          • 1336
          None bulged at first sight.
          You should check your voltage outputs at the connector between the PSU and the VBoard, to see what is getting feed to it.
          If replaced, I think that you can change all the 2200uf for 16v ones (you have 10 and 16v).
          Better to wait for confirmation or suggestion from a (more) senior member (PCBONEZ, Toasty, Wizard, anyone there ...?)
          • GeForce GT1050
          • FIXITNOW
            • Jun 2008
            • 128
            Replace IC 901 (ICE2AS01) C907 47uF 50V.
            to check ic901 get data sheet
            Check across the pads of where the zener diode would go (if it was there) next to the ICE PWM chip, I think it goes to pins 6 & 7.
            If you have < 2vdc there, and have ~175 across the large cap, the PWM chip is probably shorted. Remove the ICE chip and check again, you should have ~50vdc with it out if it is shorted.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              also resolder the rectifiers and the inverter switch fet.
              bad solder joints is what pops the ICE.
              i have seen many high esr caps on these too.
              replace ALL lytics.
              • Bobdee
                • Jun 2008
                • 461
                [QUOTE=FIXITNOW]Replace IC 901 (ICE2AS01) C907 47uF 50V.
                If you have < 2vdc there, and have ~175 across the large cap, the PWM chip is probably shorted. Remove the ICE chip and check again, you should have ~50vdc with it out if it is shorted.[/QUOTEHello
                Hello FIXIT
                As it is quiet on monitor forum at the moment,can I ask a question,
                I dont know much about measuring boards with M/Meter when powered up, I have not done it before, you mention above that the big cap is measured AC, I was of the understanding that the bridge rectifier turned AC to DC , so as the big cap is after B/Rectifier it would be DC, but obviously not can you tell me were the AC ends and DC begins, in laymans terms if you have a spare moment
                thxs in advance
                bob
                • FIXITNOW
                  • Jun 2008
                  • 128
                  ~in the case of my note means approxmently (sorry an english electronics term)
                  ie ~ 50v dc (approxmently 50v dc)
                  ~175 dc across the large cap if supply 110v AC
                  if 240v AC nearer 340v dc
                  • Wizard
                    • Mar 2008
                    • 2296
                    A sine sign means AC. Next time use @ for appox symbol.
                    Cheers, Wizard
                    • mladen82
                      • Mar 2009
                      • 39
                      • Montenegro
                      i think possible problem is in eeprom or mcu on main a/d (scaler) board
                      • severach
                        • Aug 2007
                        • 1055
                        The Dell UltraSharp 1800FP has at least 3 flaws including some bad caps.
                        1) Diode solder connections break
                        2) Bad caps on display board
                        3) Bad caps on power supply
                        On the LG 6870T445D10 power supply the output diode array D906 and D903 solder can break which burns out the ICE2AS01 PWM. Some have mentioned there is a missing zener diode ZD902 that would protect against this but so far no values have been put forth though it seems quite easy to do. Add a half volt to the max value on the data sheet. Measure the working voltage to ensure that we aren't already above the max.
                        I resoldered power supply D906, D903 and the input cap C905. My ICE2AS01was not damaged. Some recommend removing all existing solder before resoldering.
                        On logic board L1800FPK 6870T573A62 L1800F containing chips THine THC63LVD823 and Genesis gm5120, the SamYoung SMD caps with the 3 point swirl logo C739 and C207 10uf 16v K3L K3o K3α are bad. On the first logic board which I eventually burned out, they measure 10, 20 ESR ohms out of circuit. On the working eBay replacement they measure 1.6, 3.6 ohms in circuit and 8.5, 8.6 ohms out of circuit so the replacement board wouldn't have lasted long. They are the same type and size as the two 10µf 16v C604 and C507 caps found on the infamous 1702FP BN41-00101A AD video board which cause a blank/black screen and flashing leds. Fixing that board is what gave me the idea to check them here on the 1800FP board guessing that they might be from the same bad batch. The logic board SMD caps are all grounded on the negative side so are easy to test and they test fairly well in circuit. Attach one probe to any ground then hit each positive with the other probe. None of the caps test to be in parallel so if any are bad the board has lost some important function and will not display an image.
                        I replaced video board C739 and C207 with some 10uf 50v non SMD caps commonly found in junk ATX power supplies. C817 had a suspiciously high ESR in circuit but tested fine out of circuit.
                        Had I not broken the first logic board with too much testing on a bad power supply, replacing C739 and C207 might have repaired it. At first it was able to light the power led yellow/red/orange though no logo ever showed. By the time I learned that the unsafe and unfixed LG power supply required servicing, my testing killed the the logic board completely. The burned out logic board does not light the power led at all.
                        Eventually I figured out that the 5v caps in the LG power supply were no good. They were not bulged or leaking and had decent ESR at 0.11 ohms. The way I figured it out was to measure the output voltage with and without a top quality capacitor in parallel. Without the extra cap the 5v line measured 4.71v running on the SamYoung 10v 2200uf group, a stretch for 10% tolerance. With my motherboard grade cap the 5v line measured 4.92v. After replacing the three 5v caps the final was 4.96v. The PWM reducing the voltage tells me that the ripple was too high and my good cap cut the ripple down so the PWM could raise the average voltage measured by the DVM.
                        I replaced power supply C907 and C924 in the PWM section. I replaced C918, C915, and C914 on the 5v rail. I replaced C913 on the 12v rail. Sam Young C911 and C921 on the 12v rail tested fine.
                        Though I have no proof I suspect that the 1800FP LG power supply is a poor design and the slightest amount of bad ESR in the 5v caps sends the voltage of death into the logic board just like any good Bestec would do to an unwary eMachines board. Fix all power supply problems before testing anything.
                        I had no problems on the high voltage inverter. This 1800FP is definitely UltraSharp.
                        Dropping a good cap in parallel with the rest is a fast way to troubleshoot circuits that are partially working. Just as with different ohm resistors in parallel, the cap with the best ESR in a parallel circuit takes the lion's share of the load. If the circuit springs to life you have found the problem.
                        I fixed a bunch of IWE1100-A access points this way where the 48v POE to 5v converter board wasn't working. The output voltage was about 1.7v and the LEDs were dim or dark. Most worked with an alternate 5v supply in the power port. After about an hour of testing that didn't reveal much other than that nothing was burned out in the voltage converter and it should work. Out of frustration I placed a new cap across the output caps. The green power L.E.D. lit up and the WiFi unit would have been functioning if it hadn't started at a brain dead 1.7v. A few caps later and they were all fixed. There are 5 of the same brand bad caps on the IWE1100, 2 on the POE converter and 3 on the main board. The voltage converter caps see more heat so wear out faster. The mainboard caps should fix problems with unit lockup. The voltage converter caps were hard to get out and even harder to insert so I placed long lead Rubycon 2200uf caps in the cavity where the old caps were and surface mounted the leads. Those units should have a long life now.
                        sig files are for morons
                        • gyeap
                          • May 2009
                          • 6
                          I am rapairing a DELL 1800FP display. The problem is that when VGA signal is connected, the backlight randomly turns on/off about half to several seconds apart.
                          The logic boad has two caps with high ESR: C739 and C207 as noted by severach. I added parallel capacitors to fix them. However the probelm still persist. C739 measure good 5.0V.
                          All caps in the power supply board measure good ESR.
                          The backlight will turn on persistently if the VGA cable is unplugged. This showed that the inverter board is OK. I suspect the logic board thinks that the VGA signal is bad and blanks it at random. When the backlight is on, I can see good VGA image.
                          I notice that the 5V supply of C739 feeds into U703 (74F14, Schmitt Trigger). My next step is to measure the signal with a scope.
                          Any hints?
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Any hints?
                            Check the BLON signal to the inverter to see if it varies with the on/off behavior. If it does not, the problem lies on the inverter. If it does, start looking on the signal board.
                            • GeForce GT1050
                            • gyeap
                              • May 2009
                              • 6
                              eguevarae,
                              I guess you meant pin 8 of the signal that goes from the logic board to the inverter. The signal will go hi/lo with the backlight on/off. I had figured out that this was the signal that turns on/off the backlight.
                              When the VGA cable is unconnected, the signal and backlight will stay on. So, the fault should be in the logic board. The pin 8 signal traced to pin 40 of the GENESIS gm5120 chip (pin name GPI0). So, I think the chip is sending the random backlight on/off signal.
                              I don't have a HDMI signal source to check if this is also affecting the HDMI port. I can't seem to find the schematics of the logic board.
                              • Bobdee
                                • Jun 2008
                                • 461
                                eguevarae,
                                Hello Gyeap
                                This link has the same power supply for your monitor but I am unsure about M/Board, you can check it out, it might be yours.
                                bob
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  eguevarae,
                                  Yes. I didn't know which pin, but that's the BLON signal.
                                  Agree. I have some monitors with that chip and they make random things.
                                  So what you are telling is that w/o VGA signal, the backlight stays on for the unit to display the "help me! I need signal!" roaming banner? I had a Samsung 17" that did that and it was a small cap on the PSU. Will check my notes and will post back with more info.
                                  • GeForce GT1050
                                  • LCDrepairllc
                                    • Jul 2009
                                    • 2
                                    Replace the eeprom ATMEL AT49F001 If you have no video, lamps but no picture or some other weird symptoms it is bad or corrupt. YOu can take it off and read the code and then program into a new one.. Usally we see this bad after the power supply fails and takes out the eeprom prob due to voltage spikes or dirty power. They sell the chip already programmed at www.lcdrepair.us
                                    • EGuevarae
                                      • Nov 2008
                                      • 1336
                                      Advertising is against the forum rules. Read them if you haven't already.
                                      • GeForce GT1050
                                      • drewcam888
                                        EE Nerd
                                        • Oct 2009
                                        • 46
                                        I have the same problem as gyeap. My backlight works no problem. It is just the the screen turns on and on for a second with VGA and HDMI. My BLON flickers with the LCD. So the logic board is the issue. Was your problem a cap on the power supply or a problem with the logic board?
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • huzo
                                          DELL Latitude 3500 no image, fan max speed, caps lock frozen
                                          by huzo
                                          Dell latitude 3500
                                          Board BOLT-L UMA MB
                                          17938-1
                                          FW8G6$LA
                                          when i press the power, fan goes full speed, power button lights up , and caps lock light is on, the screen polarises, goes dark,no backlight...All voltages present, except PL4701, but that's probably for GPU power later....
                                          I've tried a few dumps from posts, it always acts the same, so i thin it's not a bios issue...
                                          No shorts found on the board...
                                          What should i try next?
                                          10-06-2024, 02:15 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
