Oh No! AMD adopts Intel's pinless design
  • mockingbird
    • Dec 2008
    • 5484
    http://www.techreport.com/articles.x/19138
    This should be of concern especially after reading this thread.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Oh No! AMD adopts Intel's pinless design
    S775 was still OK and solid, but 1156 and 1366 (and 1155 for that matter).. ugh..
    i thought about trying out AMD again the next time i upgrade because of those crappy new sockets.. seems like i'm fuxx0red now...
    (since my current sys will be kept in use for at least another year. by then, AMD will most likely have adopted those crappy sockets to their desktop CPUs too.. damnit)
      • 31201
      those intel shit, have you seen the rated contact life on them!
      i had some data somewhere - the number of insertions is low 2digit!
      not good if you swap cpu's around for upgrade/testing as much as i do!
      • c_hegge
        • Sep 2009
        • 5219
        NNNNNNNNNNOOOOOOOOOOOOOO! I hate Intel for having pins on the motherboard. Now AMD too
        • kaniki
          • 514
          that is one thing that i hated.. the pins on the board. might make it easier for production, but personally, I feel better knowing that if i bend a pin, that it is on the processor, not on the board. Processor, you can straighten out and reuse, MB, if you dont get almost exactly straight, no connection and possibly have to toss the board..
          just a bad idea all around.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            You do realise on the burnt up boards, that they were pushing HUGE overclocks, which likely just overloaded the socket in terms of pure power draw. The socket and pins were not designed to support 5+ ghz.
            Ludicrous gibs!
            • toastygoodness
              • Jul 2005
              • 813
              get a good quality board. it's always been that way. besides, amd started using LGA for their server boards a long time ago.
              opterons are rock-stable, unless you go crazy OC, nothing will happen. everything else still uses socket S# and AM#.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                i have had no issues with 775... it was inevitable, it would be LGA are a slow cpu the size of a napkin. the reason intel went lga was to allow more pins (775 pins vs 478) without upping the size or maling pins so thin the would be even more fragile. the other reason was to make it morelikey that the board dies as opposed to the cpu, as a cpu costs far more than the board most of the time... which would you rather kill?
                as long as you are't a fucktard with them (dont slap them in), then you should be fine.
                sigpic
                (Insert witty quote here)
                • mattch
                  • Mar 2010
                  • 121
                  to the point. I have never had any problems using LGA 775 and up. As a matter of fact i kind like it. I had so many CPUs come in with pins where boxes are dent resulting in a whole row of bent pins, sure its fixable but i dont like that.
                  Where as a MB the pins are more fragile but are more protected becasue of the surface area of the board and the cover on them.
                  the only issue i ever had was dropping something in the LGA socket bending a pin, couldnt get it straight had to replace it (no rma, physical damage).
                  i would sacrifice pins on cpu for speed anytime, just a little more caution and patients. I dont plan on letting the village 'fucktards' touch my systems or even look at them for that matter or anyone besides me as a matter of fact.
                  • kaniki
                    • 514
                    I have not had too much experience with them but wouldn't (or at least it seems like it would) there be a possibility of the pins loosing connection after a bit of time since they are just touching the processor? that is more where i don't like the idea. it seems that if you had to take a processor out of the socket too much, or even just the pressure over time (lets face it, they are made out of copper?? that they might slightly crush down and if you ever had to replace the processor that they might not make contact because of it? or am i wrong?
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      kaniki; you are quite right, the Intel spec says 20 insertions I believe for S775? (Correct me if I'm wrong)
                      That being said I also have had very few problems with LGA sockets (And I've been through quite a few now...)
                      There was an issue once I must mention, quite recently, was trying to overclock but could not reach speeds I knew this CPU+Mobo combo had done before...
                      I reseated the CPU and then it was all ok, this was abit unnerving since at stock it worked fine, only when I started pushing it did it not want to go as far...
                      • NxB
                        • Feb 2009
                        • 1595
                        No problems with LGA style sockets. I did bend ONE before and bent it back. The PC still worked fine. I can't even count how many processor pins I've bent. They also tend to break when you straighten them out. If it makes the chips cheaper, I'm all for it.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          we had a blind employee at work kill his own xfx board when he tried to put his chip in it (775). I got most of the pins re-bent but he actually shorted it out cause he bend them so much
                          it takes a delicate hand...BUTTERFINGERS!
                          • kaniki
                            • 514
                            i dont know.. i have had a quite a few processor bent pins in the past and cant ever remember one breaking on me. now they are not usually bent to 90 degrees, but were still bent.
                            as for making the CPU's cheaper.. if it is making then cheaper, it is not by much.. they are still pricey..
                            uranium.. i just have one question.. why did anyone let that guy anywhere near a computer to fix it???? and just out of curiosity, what exactly was he trying to do by putting his processor in it???
                              • 31201
                              a pinless cpu would be cheaper to make & cheaper to package & ship because handling would be easier.
                              dont confuse cost to the manufacturer with what we get fucked-over for at the retail end.
                              • paul_h
                                • Oct 2007
                                • 86
                                Where are the savings to the consumer? AMD with CPU pins are still cheaper than intel right now.
                                So drops CPU manufacturing price, but no savings passed on, Increases mobo manufacturing price, increased cost passed on
                                lose/lose for the consumer.
                                I just bought a AM3 system, so won't be upgrading for 3-4 years from now, so I'm right in the mean time.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  Come on... In 1998 I paid $120 for an Intel Celeron and the motherboard cost me about that too. With that kind of money today I can purchase far, far more power.
                                  • NxB
                                    • Feb 2009
                                    • 1595
                                    in 95 a computer was like 2 or 3k. The pins that break are usually from transport/storage. Not from jamming in sockets.
                                    • paul_h
                                      • Oct 2007
                                      • 86
                                      I wasn't refering to the general price of components, but to current AMD vs Intel pricing. IE Intel are making them cheaper now, but still cost more than AMD. And if AMD went to a pinless design, they probably wouldn't reduce there price any, but we would have to pay more for mobos I expect.
                                      • blowing_in_the_watts
                                        • Jul 2010
                                        • 21
                                        intel motherboards cost way more than amd motherboards
                                        intel cpu costs way more than amd cpu
                                        for surfing the internet a defective x3 amd 720 works for me
                                        compared to... either a dual or a quad I# with a $300 motherboard all uselessly tricked out
                                        hell they dont even have a serial port for my programmer!!!
                                        er i mean
                                        PCI IS DEAD!!!
                                        and um... NO IDE? NO FLOPPY???
