New build
  • washu
    • Jul 2009
    • 310
    Re: New build
    What fan are you ever going to find in a PC that needs 50W? That's insane and completely unrealistic.
    A real 150 CFM fan (Delta AFB 120 mm) uses less than 9 W. It's also way overkill for pretty much anything, so real PC fans would use less.
    stevo will be fine with that 350W. As long as it's not a crappy brand it will do fine.
      master hoarder
      • May 2008
      • 12175
      Re: New build
      How many Amps is the Delta PSU rated for on the 12v rail?
      • c_hegge
        • Sep 2009
        • 5219
        Re: New build
        Originally posted by AudioCraZ
        The only thing I would make sure you get is FANS... A gaming computer can never have enough fans.
        Yes it can. More fans and more airflow = more dust and, if there is moisture in the air, corrosion
        • stevo1210
          • Oct 2006
          • 4156
          Re: New build
          I picked up everything and it's installed, up and running etc... except for the fact that my LAN isn't detected in windows even after enabling/disabling it. I sense a faulty LAN controller... and this board is brand new!
          • stevo1210
            • Oct 2006
            • 4156
            Re: New build
            I found the issue... the onboard LAN was conflicting with my X-Fi sound card... changing it to a different slot solved the problem.
            • stevo1210
              • Oct 2006
              • 4156
              Re: New build
              it's 19A on the 12V rail... and I am mistaken because it is a 300W unit, not a 350W. After several hours of burn in it seems okay and the PSU doesn't get hot so I guess everything is ok.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Re: New build
                run coredamage + furmark at the same time.
                that's how you really push the psu
                • AudioCraZ
                  • Sep 2009
                  • 147
                  #28
                  Re: New build
                  265 CFM Fan on Frozen CPU <-- unrealistic, nope. They exist, why I said it. And yes, I have a buddy with a file server in his closet that has one of these, Noisy, but does an awesome job on all his drives.
                  • washu
                    • Jul 2009
                    • 310
                    #29
                    Re: New build
                    On the specification page you just linked to: "Power: 19.2 Watts"
                    That's a far cry from 50 W.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Re: New build
                      My 160cfm delta AFC0912DE is 12v, 2.5A (for those not too good with math, thats 30W)
                      Even my 300 cfm nidec ta600dc is only 3.9A (again, 46.8W) and this thing could probably put a hefty gash in your finger (172mm roundside, made in the USA )
                      These are server fans, not to be used in your standard desktop and I hardly think stevo is going to use them in his, so I have no problamo saying that a 300W delta is fine.
                        master hoarder
                        • May 2008
                        • 12175
                        #31
                        Re: New build
                        Good.
                        19A should be enough for that setup. Try some games with heavy 3D. If PSU still feels cool after an hour of playing, then you have nothing to worry about.
                        Besides, Delta PSUs are pretty tough. Same goes for LiteOn and HiPro.
                        • AudioCraZ
                          • Sep 2009
                          • 147
                          #32
                          Re: New build
                          Sorry, linked the wrong one. Delta 120mm "Mega Fast"
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: New build
                            Well I found my 350W Delta GPS-350AB PSU today so I put that one into this system.
                              • 31201
                              Re: New build
                              dont forget filters on the inlet fans.
                              • stevo1210
                                • Oct 2006
                                • 4156
                                Re: New build
                                I've got that bit covered by vacuuming the internals every fortnight.
                                  • 31201
                                  Re: New build
                                  wouldnt it be better not to coat your laser & all the other stuff in dust to begin with?
                                  besides, if the fans are as good as you say then it would need to be weekly.
                                  • stevo1210
                                    • Oct 2006
                                    • 4156
                                    Re: New build
                                    well that bit is up to my brother tbh. it's his computer so yeah, he does whatever he wants with it... if he wants filters then he'll pay for them... he vacuums it instead but hey, not my problem lol.
                                    • Dobrowol
                                      Dell Latitude 3520 help with bios build/repair
                                      by Dobrowol
                                      Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                      Steps i done and results:
                                      I exported a clean bios from update file via pfs extract.
                                      1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                      Result: Dead
                                      2. Build clean bios with no changes in ME, new PMC, PCH
                                      Result: Dead
                                      3. Build old bios with clean ME, new PMC, PCH
                                      Result: The same
                                      09-22-2023, 02:43 AM
                                      ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                      This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                      09-12-2024, 03:28 PM
                                    • iotaa
                                      How to build this little device please for my campervan security
                                      by iotaa
                                      You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                      I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                      For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                      The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                      This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                      09-18-2022, 09:52 PM
                                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                      I bought this from an eBay seller but unfortunately they only had one
                                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                      I bought three of from them to also make battery packs with this output power limit in mind
                                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                      04-23-2025, 05:50 AM
