My latest Quadcore......even I need a little help on this one
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: My latest Quadcore......even I need a little help on this one
    He said they're all Thunder K8W's, which are dual CPU - http://www.tyan.com/archive/products...hunderk8w.html
    Ludicrous gibs!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      You need one, even though it has an AGP. They're like poor little shelter dogs, they need a loving home!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Haha.... it'd be faster than my current setup processor-wise... but not in the video department. And I don't have any ECC DDR to put in it.
        Ludicrous gibs!
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          all my ddr is in use... darn... i
          sigpic
          (Insert witty quote here)
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            I'm not sure if it'll run non-ECC RAM, I'll test it and find out. I cleaned the lab last week and found a pile of 1GB DDR1 non-ECC sticks I didn't even know I had.
            Noah, there's still a lot of really nice AGP cards out there, and usually really cheap!
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              those 1gb modules are nice... boy was i happy when i got 4 apida 1gb ddr 3200 high-density sticks for free! they were in original packaging, opened, used once for a quick test (turns out the guy's dell didn't like them so well), this was in the same shipment that i got an ASUS a8n32-sli with a x2 3800+ and 4 512mb corsair ddr 3200 sticks... he gave me the stuff because the cpu had a bent pin... now that i am running 4gb in that 939 board, wow, i'm impressed. all i need now is the SLI adapter and another card (in the works)... then i will be virtually MAXED OUT! watch out kids!
              i bet those boards run just as well. turns out i have the ddr, but not the use... still, how much per board?
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I tested them all before I pulled the RAM out of them, they all ran fine. Passed testing without a hiccup. Caps are UCC's (most polymer), all good.
                How's $80.00 for the board, 2x Opteron 250 (2.4GHz 64 bit) CPU's, HSF's, and IO shield? I didn't pay a whole lot for them, so I can pass that along to you guys if you want them.
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  i'm good... for that much, my 939 will do just fine. i expected it to be high, server equipment is usually co$tly... unless you find it curbside or via a dumbass who cannot un-bend a 939 pin... or by way of an ASUS fanboy who will give ANYTHING for an ASUS board, even a less than average one! that said, i love my 2 asus boards, they rock (AMI bios helps, so you don't have to constantly reset cpu settings after every hard pre-post reboot, as well as being easy to mod!)
                  sigpic
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    Cheapskate.... That's dirt cheap for what you'd be getting.... it's cool though, I don't think I'll have any problem offing the rest of these. Actually, I'm going to keep one and make a server out of it, and send it down to the datacenter....but now I've got to find more RAM for it, since I robbed them all of their memory.
                    I assembled the system last night. I used those 2 WD Blue 160GB drives in a mirror for the OS. The 3ware controller likes them, so atleast they won't go to waste.
                    I ran into one hitch though......When I was installing Windows, it would boot from the CD, get to the point of 'starting windows', and then BSoD with a strange error of "MACHINE_CHECK_EXCEPTION".... I've never in all my years seen that one..... Long story short after googling possible solutions for a couple hours.... Apparently AMD chipsets for this platform can not run more than 6 ranks of RAM at DDR400 speed. To test this, I removed 4GB of the RAM, for a total of 12gb, windows installed without a hitch. If I slow the RAM speed down to DDR333, it runs perfect on all 16gb, so the information I researched was accurate. With 16gb, that makes 8 ranks, 12gb is 6 ranks....so I have a choice, I can run 12gb @ DDR400 or 16GB @ DDR333.... I haven't made up my mind how I want to run it yet....
                    Anyhow, it's alive and breathing. Pics to follow.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      That's not a bad price at all... just, the damn AGP slot... I had a 6800gt (PCIe native, with a bridge chip), but sold it when I got my current setup. The only AGP card I've got around here is a Number Nine SR9 16mb Savage 4 card that I've kept around for testing.
                      Ludicrous gibs!
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        i know its a good price, but for something i do not need or can afford right now, then i will likely not buy.
                        sigpic
                        • c_hegge
                          • Sep 2009
                          • 5219
                          I have one of those in my junk collection too.
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            It'd be a nice replacement for my dual 3.06 xeon system. I got a nice AGP 512mb x1650pro, but I don't have any extra ddr ecc ram or 80 bucks to spare. Dang.
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              The last round of pics.......I hope nobody is on a dialup...... I removed all the motherboard heatsinks and scraped off the crusty heatsink compound and replaced it with fresh goop. Did all the final testing, and away I went!
                              The case has been waiting patiently for a couple weeks...
                              A few shots of the case itself:
                              SAS Backplane from the back side:
                              Midplane with 4x 80mm fans:
                              865W Supermicro PSU:
                              Box-o-goodies:
                              Motherboard test fit & standoffs mounted:
                              Motherboard installed and mounted up:
                              3ware 9550 installed:
                              2x 7600GT's mounted:
                              Those silly WD Blues that the GX620 and Imac didn't like:
                              Drives mounted in the SAS trays:
                              The SM "dummy drives" that come out of those SAS trays sure do make good screw holders:
                              Ready for the acid test:
                              It POST's:
                              3ware says hello to the Blues.....config'd in a mirror:
                              SLI Enabled:
                              Damn, that's a big case!
                              ....AND FOLDING AWAY! SMP client, all 4 cores in use. This should bump my PPD a bit!
                              It's running 16gb of RAM at DDR333 speed (see above post as to why it won't run all 16gb @ ddr400 speed). I may try 12gb @ DDR400 speed and see how it does for with folding....
                              This project is now coming to a close finally...........
                              Team : 49813
                              Join in!!
                              Team Stats
                                • 31091
                                all that blue plastic reminds me of a ps2!!!
                                for the younger people, i'm referring to the ones from IBM, not sony!
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  i want that case
