Synology DS109 latest firmware (PAT file)
  • Fireballcz
    • Oct 2016
    • 29
    • Czech Republic
    Hello friends,
    I need the latest firmware for Synology DS109.
    The filename is DSM_DS109_3259.pat (about 170MB).
    Umpossible to download from Synology, because their support for old devices is discontinued as of 2023-05-31.
    Please does anybody have a backup?
    Many thanks in advance.
  • Fireballcz
    • Oct 2016
    • 29
    • Czech Republic
    Re: Synology DS109 latest firmware (PAT file)
    Originally posted by Fireballcz
    Hello friends,
    Tha answer is Wayback machine (Web archive)
    https://web.archive.org/web/20230531...y.com/download
      • 31196
      thats good - grab it fast before synology issues a takedown order.
      they pulled the older firmware because the assholes included licensed codecs from another company that has withdrawn the license from them!
      • Daniel Larsson
        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
        by Daniel Larsson
        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
        During these seconds the function button is not working...
        08-13-2025, 10:29 AM
      • Daniel Larsson
        Firmware file for Marantz NR1501 needed
        by Daniel Larsson
        I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
        After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
        The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
        The content of these seems to be useless as far...
        05-23-2025, 04:11 AM
      • GeckoGreen
        Samsung service bulletin: need firmware file for PN63C550 TV
        by GeckoGreen
        I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
        You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
        The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
        Will you please help me get the [2D63]LOGIC.bin file for my TV?
        05-17-2025, 02:47 PM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Kolecki
        Epson et-2756 Firmware dump file
        by Kolecki
        Hi I need bios or firmware dump file to printer Epson et-2756. Can you help me. My printer is bricked in printer mode and i need reprogram chip on board
        01-18-2025, 11:38 AM
