ICE ICE baby :) (low temperature topic)
  • Shodan486
    • Nov 2009
    • 203
    #41
    Re: ICE ICE baby (low temperature topic)
    Still - having two pieces of CPU chips on a single motherboard is sexier than more cores on a sole die. :P
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    • paul_h
      • Oct 2007
      • 86
      #42
      Yeah, like I said, the dual p3 with some nice HSFs on it looked cool.
      • Scenic
        o.O
        • Sep 2007
        • 2640
        indeed.. got a recapped Gigabyte 6VXD7 here. (Specs)
        maxed out as far as i could
        - 2x 1GHz PIII Coppermine
        - 4x 512MB PC133 Kingston
        - Geforce 6800GT (slightly overkill )
        has 2 Arctic Cooling Copper Silent II TC on the CPUs, and the 6800GT has the Arctic Cooling nVSilencer 5 on it. combined with a 350W Delta w. 120mm fan -> VERY quiet..
        edit:
        edit2: forgot to mention... this board also had the crappy Choyo 25V 330uF that Gigabyte liked so much back then EVERYWHERE except CPU VRM (Sanyo) >.<!
        • paul_h
          • Oct 2007
          • 86
          #44
          Yeah the GB 6vxd7 was the mobo I had. Was OK for the most part, but a little funny.
          One of the caps near the RAM was swollen, one of the caps between the PCI slots was too.
          It was me first attempt at a recap, but ever since I went near it with a soldering iron, it hasn't posted or worked properly so I killed it more or less.
          Just before I killed it I bought 1.5GB SDRAM and 1Ghz CPUs (only had 866mhz CPUs and 756MB RAM before), what a waste.
          • Shodan486
            • Nov 2009
            • 203
            #45
            Hi guys!
            After a while of rapin' my system, I come back to you with my latest findings (and strange behavior). Again, I need to highlight the fact I live in Slovakia, which was supposed to be in a medium weather conditions, meaning no serious temperatures or humidity...but the climax changed and now we have 30 degrees Celsius under shade and 40 right on the direct sunlight. That's just the environmental presumption...
            When we browse this thread (and more from me concerning the VP6), we can see I was able to reach a stable level of operation with my system...I was able to play Fallout 3 on it for 4-5 hours without any glitch, fall, BSOD...under these settings:
            VCore - 1.85v (I'm firmly sure that's OK)
            VCC3.3 - 3.4v
            Vtt - 1.48v
            MPS: 1.4
            SDRAM timing: 2-2-2-5 CL2
            Chipset buffer delay : 0.5ns
            AGP Driving Value : Auto (improves stability when set to the highest values, from 00 to FF, but it depends on the VGA used)
            So these are the main settings which affect the overall stability and performance, mainly the VCC3.3 and AGP driving value. So let's get to the point:
            I'm playing fallout3 for about max 45. min and I get one of these : just a regular windows error, after which I can run the game again and play it for just as long as after the boot up OR just a simple hard reset...Occasionally I get a pure freeze, the game holds still till the reset button pushed - that I can tell for sure is a temperature problem (had this phenomena for a while, suspected some temperature issues, solved by replacing the chipset heatsink). By these experiences, I have the following questions for you, mainly theoretical:
            1. Could I relate this behavior to the rise of ambient temperature? (2 months ago everything was fine due lower degrees) Can I suspect the MX-2 thermal paste having some air bubbles created within it from these temperatures? Or can any chip be overheated from the bottom side (where soldered to PCB)?
            2. Mainly for the best experienced people of you: Can I connect this issue to the caps? Why? Of course due to the sudden temperature/humidity change, though it's relatively dry in Slovakia. OR have I ''raped'' the caps by frequent changes of VCC3.3v/VCore values?
            • Scenic
              o.O
              • Sep 2007
              • 2640
              i'd say the system was running very close to it's (thermal) limits..
              the change in ambient temp may have pushed it over the border.. one of the CPUs doing wrong calculations, leading to crashes.. (might even be the chipset or RAM..)
              i've had that happen before with an Athlon XP Palomino 1700+ that ran at the thermal limit (90°C and slightly over) for some time (clogged heatsink/fan)..
              even after cleaning everything, i get VERY strange windows errors or drivers randomly not working..
              i've tried to run Prime95 with that CPU.. sometimes it worked fine for almost 14 hours.. sometimes i get calculation errors after as little as 30mins..
              that CPU is more or less toast. i still have it though.. using it for testing unknown boards as it does work, but isn't quite calculating right anymore due to the overheating.. (Pentium1 FDIV bug anyone? )
              • Shodan486
                • Nov 2009
                • 203
                #47
                Thanks Scenic, you reminded me I forgot to put som temperature readings
                CPUs : 35-45 celsius
                Chipset : lower than 30 celsius
                GPU : 45-55 celsius
                HDD : 40 celsius max
                And I have this stuff inside the HAF932, there are 10 active coolers installed ...I guess the flow of warm breeze won't help either.
                • Shodan486
                  • Nov 2009
                  • 203
                  #48
                  Cause identified - loosened heatspreader on the chipset ...running fine at 172,5MHz all the time...but those 173MHz aren't gonna happen again I guess.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    Originally posted by Shodan486
                    So I've tested this system so far and it seems all OK. By knowing that if aggressive timing settings & high clock frequency is bestowed upon the memory modules, I can say that if there is no single error from the start of the computer, no BSOD, no random reboot - there is nothing to worry
                    Start
                    Successful OS start (WIN XP Professional SP2)
                    Successful Battlefield 2 game start
                    Successful Loading map
                    10 Minutes playing the map
                    End
                    You may be speaking too soon, watch out when you run Prime95! You're likely gonna get an error or a PC crash! Usually, NOTHING beats Prime95!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • Shodan486
                      • Nov 2009
                      • 203
                      #50
                      You're right definitely, but this particular issue involved loosened chipset heatsink, which resulted in immediate hang-ups and so, not even 2 minutes and the system would fail. Now I attached the heatspreder a little more carefully - the results were immediate - no worries, played fallout yesterday for 2 hours - no problems...Even managed to play it at 173,5MHz - finally found the best BIOS combo setting.
                      And now, folks, it's time for some Prime95 - now I feel the machine is ready for this torture .
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #51
                        Prime95 is childs play, try passing the Intel Linpack tests, Linx is a user friendly way to run it;
                        http://www.xtremesystems.org/forums/...d.php?t=201670
                        • RJARRRPCGP
                          • Jul 2004
                          • 6301
                          I seen Prime95 fail at 5 hours or about that, after a short Linpack run. So 30 minutes in LinX don't always equal 24 hours of Prime95!
                          Arc A770 16 GB
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            #53
                            Well, I've had a computer run 48h Prime95 but fail after 15mins on Linpack
                            But you need to use heavy settings in Linpack if it's really going to test the hardware (this is where Linx comes in, makes it user friendlier)
                            • Shodan486
                              • Nov 2009
                              • 203
                              #54
                              SO!
                              Ran some P95 test - it fails within 2 mintues , once even hard-reset. Solution was quite easy - jumping from 1.85v to 1.9v for VCore. That resulted only in one failure (probably caps needed to familiarize with the higher value of voltage), tried once again and held stable for 45min. for the first test...will try more when time available.
                              BTW, been on a LAN party, which provided a great environment for testing (both for logic & hardware) - Playin FEAR combat quite stressed all HW in there and we even had some air conditioning, which I do not have at my place - NO crashes for 1 & half hour when the Vcore was 1.9v, on the other hand too many crashes when 0.05v lower.
                              • Phaihn
                                • Jan 2009
                                • 842
                                I put my PC outside, to my balcony, where it could be like -2 Celsius and the computer acted more stable. So it looks it likes it ...still I don't like the AGP problem - bus frequency raised to 86MHz and its voltage is 3.6v, though cards I'm testing (HD2600XT & N7600GS) only require 0.8v, but anyways the Rialto & HSI chips may go hot very soon, mainly the ATI converter gets pretty hot and eventually hangs up sooner than the GeForce HSI. I only need an 6800 class VGA to prove my self wrong...I'm definitely leaving this problem and solution to mother nature
                                ive done something simular to that i just used bottles to rout air from out side my window to the intake fan on the front of my computer.
                                My Computer.
                                AMD APU A4-3300 2.5ghz 1mb cache
                                Motherboard GigaByte GA-A75M-S2V
                                Kingston HyperX Blue DDR3 8GB (2x4GB)
                                SB Audigy 2 ZS [B800] Sound Card
                                500GB WD Caviar® Blue™
                                1 Terabyte WD Caviar® Black™
                                2 Terabyte WD Caviar® Black™
                                • Shodan486
                                  • Nov 2009
                                  • 203
                                  #56
                                  Okay, that's enough!
                                  Just finished my testing. To summarize my findings briefly, I'll just provide very simple info extracted from my thorough testing procedures:
                                  -solidly usable under heavy stress at 172,5Mhz FSB
                                  -unusable under any stress at 173,5MHz FSB, although normal usage is OK.
                                  -ROCK SOLID stable at 166MHz FSB
                                  How I determined rock solidness ? Playing games solely isn't sometimes much of a stress, but running Prime95 + playing is quite reliable when speaking of legit results - the best combo (and playable ) seems to be P95 and Flatout2. Flatout isn't a stresser at all, can play it FullHD with highest details at 45FPS, but adding some pressure to CPU or to the whole motherboard showed BSODs, hang-ups, WIN errors etc.
                                  So right now I'm using the rig at the 172,5MHz normally, playing games, running videos, youtube....all ideal unless some HEAVY math stress tests with SuperPI / P95.
                                  So what's wrong? Well definitely Sanyos are quite strong caps and sustain a lot of raping , but I think I've crossed the line - seems the electrolyte is not as good as it seemingly used to be, 10 months ago it was easily possible to run anything at 173,5MHz, now I cannot fully rely on 172,5MHz, but it's working so far, but I guess not for long.
                                  Solution?
                                  R.E.C.A.P
                                  • Shodan486
                                    • Nov 2009
                                    • 203
                                    #57
                                    Well Need to say I've failed...aaaand this is a nice one to admit.
                                    The research done upon all the failures causing various behavioral occurrences and / or the BSOD / cold reboots was a bit preliminary as expected. Simply put I jumped into the complex stuff before doing some basic checks. What I mean is that I've found the core problem - the machine was behaving differently at distinct places (my flat, workplaces, the balcony) and also erratic behavior has been observed rather in summer than winter. So this lead myself to conclude the fact that it still should be the temperature issue, not the caps condition, ripple or ESR...it wasn't it, it was the temperature. And it still has been the temperature - I'll try to make a shot o my RAM modules and point directly at the responsible part for all of my problems. It's some sort of a chip down on the RAM stick and it fires up when games hungry for memory are run. I was just browsing the mobo with my index finger and trying all the chips on it - found none. Then tried the memory when I suddenly got burned by this bug, so I tried putting a huge 90mm fan on the 2 of my sticks just for the hell of it.
                                    Not only I've managed to acquire TOTAL stability (173,5MHz) at my workplace (we don't heat up), but experienced 40 minutes of playing fallout NV at FSB 175MHz, then somebody cranked up our radiators. Anyways I got IT! I bought some AC heatspreaders, so they should eliminate the need of the fan usage.
                                    Guess that's all, this is my Christmas present this year, just wanted to share a little of progress I've made. Happy New Year everyone and best of luck!
                                    Me
                                    • Shodan486
                                      • Nov 2009
                                      • 203
                                      #58
                                      Solution?
                                      R.E.C.A.P
                                      Please ignore
                                      • CapLeaker
                                        AcuRite 5 in 1 temperature sensor replacement repair
                                        by CapLeaker
                                        Got a new victim:
                                        AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                        A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                        B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                        Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                        04-15-2025, 01:32 PM
                                        Surface Mount Fuses Fundamentals Datasheet
                                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                        10-07-2024, 06:07 AM
                                      • asdas09
                                        Temperature to remove chips from motherboard
                                        by asdas09
                                        What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                        I have device Sugon 202. I'm used also normal flux and rosin flux.
                                        09-12-2023, 12:44 AM
                                      • Dreigas
                                        ISL95880HRTZ desoldering temperature
                                        by Dreigas
                                        I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                        Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                        09-13-2024, 10:59 PM
                                      • jm1234
                                        9V relay temperature 40C
                                        by jm1234
                                        Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                        I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                        05-09-2024, 03:03 AM
