ICE ICE baby :) (low temperature topic)
  • Shodan486
    • Nov 2009
    • 203
    Do low temperatures (-15 Celsius) increase the computer stability in an OC'd system?
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: ICE ICE baby (low temperature topic)
    Could. I would be worried about condensation though.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      some have the "cold bug" which could kill a cpu.
      http://en.wikipedia.org/wiki/Phenom_II (section "overclocking")
      sigpic
      (Insert witty quote here)
      • toastygoodness
        • Jul 2005
        • 813
        you're using liquid nitrogen? that stuff's dangerous, make sure you have real mitts.
        i don't think all of the CPU works as a superconductor, so extreme cold probably could kill it. besides, there comes a time when temp simply doesn't matter in an OC. if it was made only to the specifications, you're lucky to even get it to OC. i have two athlon II x2 regor cores, one OCs all the way to 4GHz from 2.6, while the other can only go 2.8. its an arctic cooling freezer64 with mx-2 thermal paste.
        • brethin
          • Dec 2008
          • 1907
          Long term "Super Cooling" isn't a good idea, its fine for a short period to try and get a really high OC but in general you want a constant temp for long term use. Changing temps cause expansion and contraction and that isn't good.
          • Shodan486
            • Nov 2009
            • 203
            I put my PC outside, to my balcony, where it could be like -2 Celsius and the computer acted more stable. So it looks it likes it ...still I don't like the AGP problem - bus frequency raised to 86MHz and its voltage is 3.6v, though cards I'm testing (HD2600XT & N7600GS) only require 0.8v, but anyways the Rialto & HSI chips may go hot very soon, mainly the ATI converter gets pretty hot and eventually hangs up sooner than the GeForce HSI. I only need an 6800 class VGA to prove my self wrong...I'm definitely leaving this problem and solution to mother nature
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Yes, colder makes most CPU's faster.
              Yes, condensation can kill it.
              Yes, heat-up/cool-down cycles can kill it.
              We used to dip the end of our cokes in a bucket of liquid nitrogen to have instant coke slushies.
              You had to be fast or you'd have an instant coke cube instead.
              Yes, use N2 gloves, goggles, and an apron.
              Mann-Made Global Warming.
              - Dr Seuss
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16955
                Seems an awful lot of work just to squeak a couple extra MHz out of a couple cumines on a VP6. I understand the desire to be a little 'different' than all the sheep following the shepherd in the newer hardware realm, and I'm all for experimentation.....but when you're contemplating refrigeration type cooling in attempts to do it, that's going a little too far.....kind of trying to beat a few more miles of travel out of the dead horse....
                FWIW, back in the P3 days we tried all kinds of interesting things to OC cumines, including various types of refrigeration. It never worked effectively save for a few benchmarks then kaput.... Water cooling on a lapped cumine was always the best way to keep one cooled and reliable.......and keep in mind, this was before water cooling was just something you could buy. We had to make our water blocks, pumps, and radiators ourselves. My first water cooled system used a heater core from a mazda pickup, a copper block with passages cut into it, and a pair of 120mm 6000RPM A/C powered fans. it was loud and obnoxious, but was effective.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • brethin
                  • Dec 2008
                  • 1907
                  Ha those were the days. I skipped water and used a small Dorm (Mini) Fridge as a case, it worked damn nice and condensation wasn't a issue unless I put ice trays in the freezer drawer. :P
                  • Shodan486
                    • Nov 2009
                    • 203
                    Thanks Top for extending the problematics - the first statement is true, it kinda doesn't mean much to squeeze such a small performance, but this is the how I started, small steps... The shepard theory definitely counts here with me.
                    And thus the question is: what (a particular component) actually likes these temperatures and helps it to run stable? On the contrary to Topcat's experience, at these temperatures I was able to use my machine for 4 hours without a single reboot, playing games and running everest for 2 hours and that's enough for me. I'm pretty sure it would last for much longer.
                    • Shodan486
                      • Nov 2009
                      • 203
                      I definitely think it's the HSI / Rialto chip thing. Will have a 6800 series card soon, this should (perhaps) resolve the issue...At least I think it's in this temperature stuff...
                      • Shodan486
                        • Nov 2009
                        • 203
                        Do you guys think the VP6's chipset heatsink (the black one glued on it) has low heat transfer rate, or any?...Mine is very cool, but I have it under serious airflow. I mean does the paste from the factory working good? I tried to identify the hot spot on this board and the only chip I cannot touch is the chipset, coz it has its heatsink - can I trust it?
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16955
                          Nope. those heatsinks with their cheesy sticky tape on the back are hideous and utterly useless. Remove the sink and put something beefier on there. If not going with something bigger, atleast remove the tape and attach it better.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            swap the tape for cpu paste, and glue on a fan.
                            sigpic
                            • Shodan486
                              • Nov 2009
                              • 203
                              Bought this: Click here
                              I think I can use the ''Few seconds'' glue with a Cooler Master MX-2 cooling compound - that is my last resort and my last suspicion. Will try this ASAP and let you know of the progress, if any.
                              • Shodan486
                                • Nov 2009
                                • 203
                                Job's done! I think I may leave this board for now, as it seems so far that the cooler helped get rid of the issue - it was the chipset heatspreder's ineffectivness people said, but I thought it was in the glue compound...So I used the one above with MX-2 cooler master (cooling paste) and I could easily play some games at 178FSB but with the easiest memory settings, which suxx...so I stayed with 173,5MHz and the most aggressive memory setting I could research at this speed, which gave me approx 1350MB/s bandwidth over the FSB and DIMMs. Now I'm about to test it on a very unstable and many times patched / drivers install&uninstall XP proffessional and let's see if it ALL was just in the stupid chipset heatsink replacement, which I neglected from the beginning, convincing myself that it could not be a problem at all, coz it was always quite cold, no matter what the FSB frequency...that made me suspicious...now it makes me cry
                                • Shodan486
                                  • Nov 2009
                                  • 203
                                  So I've tested this system so far and it seems all OK. By knowing that if aggressive timing settings & high clock frequency is bestowed upon the memory modules, I can say that if there is no single error from the start of the computer, no BSOD, no random reboot - there is nothing to worry and only little time needs to be spent for clarifying computers stability status. All of this applies ONLY when every cooling problem is solved - that's what I have just achieved. What I'm trying to say that I just tested as following:
                                  Start
                                  Successful OS start (WIN XP Professional SP2)
                                  Successful Battlefield 2 game start
                                  Successful Loading map
                                  10 Minutes playing the map
                                  End
                                  I know it's ridiculous to test a rig under such pressure by just doing exactly ONLY this, but it has proven to me many times: This game is very ''fat'', it consumes much memory and can engulf all the free space of a 256MB card - that just suxx...
                                  So far I was able to do this 2 times in a row for a 175 & 176MHz FSB/DIMM setting, Memory Timings 2-3-2-6 CAS2, AGP frequency reaches 88MHz and PCI up to 44MHz - I guess this is very nice
                                  I will perform stressful test in the future, not able to test properly so far...
                                  So the final setup is this:
                                  ABIT VP6
                                  Dual 1GHz PIIIE @ 1320MHz Core, 176MHz FSB
                                  2x 512MB Kingston ECC PC133 @ 176MHz CAS2 2-3-2-6
                                  AGP Gainward N7600GS 256DDR3 - GPU:400MHz RAM:1100MHz @ GPU:600MHz RAM: 1500MHz
                                  USB Sound Blaster EAX
                                  Realtek 8129RTLD NIC 100MBit
                                  Chinesse Brand SATA/PATA/USB2.0 PCI
                                  80GB PATA WD
                                  Fortron Epsilon series 700W
                                  Cooler Master HAF 932 Case
                                  The maximum clock setting for the FSB is 178MHz, which requires me to lower from CAS2 to CAS3 and ease the memory timings, which is unacceptable, just FYI.
                                  • NxB
                                    • Feb 2009
                                    • 1595
                                    Don't want to be a downer but....
                                    You're putting a lot of work into hardware that can be beaten by a $200 emachine at this point.
                                    The ram in your video card is leaps and bounds ahead of the ram on your motherboard and runs about as fast as your CPU. Not just that, you're missing out an the new instruction sets, 64 bit, etc from the last 10 years.
                                    Even if you got both chips to 2ghz with LN2, they would still be P3s and your ram would still be PC133.
                                    • Shodan486
                                      • Nov 2009
                                      • 203
                                      True point, but that´s not the point. The purpose is to OC a DUAL CPU system, not a single and so far there are few such systems with OC availability, there is a limited list of boards I want to tune up, namely the VP6 (done), Iwill MPX2 (next) and MSI K8N Master2 (when I get one). The last one will be cooled by water, the rest remains air environmental.
                                      Yes, the VGA is a bit leap, but would you believe that it is still slow for this system under these conditions? Radeon 2600XT AGP still performs much better, so it means the AGP bus still has some space left . Next, I may be missing out some instructions and stuff, but I my cpus are for about under 60% constant load, both of them, some peaks, nothing serious.
                                      Well, for games it doesn´t quite matter if it´s dual P3s or Core2 duo, my P3s still got some breath. And my RAM si PC175 right now - symmetric overclocking, pal. And I don´t think that SDRAM would go so much higher.
                                      • AudioCraZ
                                        • Sep 2009
                                        • 147
                                        Condensation is going to be the biggest monster. If you want to keep the cpu happy, and not worry about it, keep it around 20 c. I have ran liquid cooling for years, not to overclock, but to make my system run at optimum performance at standard clocked speeds.
                                        • CapLeaker
                                          AcuRite 5 in 1 temperature sensor replacement repair
                                          by CapLeaker
                                          Got a new victim:
                                          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                          B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                          04-15-2025, 01:32 PM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • asdas09
                                          Temperature to remove chips from motherboard
                                          by asdas09
                                          What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                          I have device Sugon 202. I'm used also normal flux and rosin flux.
                                          09-12-2023, 12:44 AM
                                        • Dreigas
                                          ISL95880HRTZ desoldering temperature
                                          by Dreigas
                                          I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                          Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                          09-13-2024, 10:59 PM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
