PSU advice requested
  • weirdlookinguy
    • Sep 2007
    • 1638
    I've got the famous 550w AcBel powering my rig right now. It's a beast, and has ran my new system flawlessly since this summer.
    However, it's loud. It's not wind-tunnel status, but it annoys me because it makes sleeping with the computer on very difficult, nearly impossible.
    I want to replace it with something quieter, found this on hypermicro:
    http://www.hypermicro.com/itemdesc.a...02045&eq=&Tp=#
    It's a 400w HiPro.
    My question to you guys is, will a 400w be able to run this rig reliably:
    -Core 2 Duo E7500 (75W TDP) (on a Gigabyte EP45-UD3P motherboard)
    -Radeon 4850 graphics card
    -3 case fans, two SATA HDD's
    I know my rig isn't exactly power hungry, but at the same time it's no pushover either because of the graphics card. 400w should be fine, right?
    Also my motherboard is EPS12V, and this isn't an EPS PSU. Would that pose a problem?
  • Krankshaft
    • Jan 2007
    • 2328
    Re: PSU advice requested
    Ever think of replacing the fan in the Acbel with the same or greater CFM but less decibels?
    Blade design is everything with fan noise.
    • Toasty
      • Jul 2007
      • 4171
      That fan must be cranking to be making that much noise. Does it run at constant speed? No variable speed?
      I've 2 in separate rooms and both are dead quiet. The case fans make noise, not the PSU's. Did you have it apart and perhaps not get a connector back together correctly? I did.
      Toast
      veritas odium parit
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        WLG I agree with Krankshaft. Install a nice quiet fan in that AcBel. If it has any age to it recap it while you are at it too.
        I also like HiPro units. Some years ago I took a load of junk parts up to my friends PC shop. A year or so later I needed a PSU for my Dell PIII. I'm up at the shop digging in the junk box and found my old cigarette stinking HiPro PSU with a bent case. "Yes it had been in a PC that I beat to death." Don't worry I'm on Meds now...LOL Brought it home, and took it apart. Spray 9 and water cleaned up the internals well. I did a little fine hammer work to its metal case and its good as new. That PSU has been in the Dell for a year or so now with no problems at all. For a little PIII I'd say it has alot of junk in it. Its a GX150, PIII 1Ghz cpu, 512 megs ram, One added case fan, one after market cpu fan, 128 meg AGP video card with a fan on it, Two DVD Burners, Two IDE/PATA Hard drives, one floppy drive, USB Web Cam, and a USB wireless keyboard /mouse combo.
        I'm going to implement the same cooling solutions that worked up for the PIII on my P4 Dell box. I just need to go up to the shop and get a few odds and ends from a GX150 to make it happen.
        Being that my hearing is blown to shit I can't even hear this P4 Dell run and its only two feet from my face! In the past I had and AMD PC with five cheap fans in the box. I could hear that one! To "normal" people it must have sounded like a Helicopter.
        Mark Twain
        John Paul Jones
        Rod Serling
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          http://www.hypermicro.com/itemdesc.a...002046&eq=&Tp=
          I would spend the extra and go with the delta. I have had this same exact one, sure it's full of ltec, but it is super quiet, runs really cool, and has a pci-e connector (30A 12v rail), no 8pin cpu connector though.
          https://www.badcaps.net/forum/showpo...19&postcount=3
          Theres the internal pics I took.
          • washu
            • Jul 2009
            • 310
            Krankshaft is right, just replace the fan.
            However, 400W is fine. I run a more power hungry system on a 350W and it's fine. Quality is more important than big wattage numbers.
            The EPS12V connector is almost never needed in a single CPU system. The regular 4 pin CPU connector can already supply 192W. Even with VRM losses you need a really power hungry CPU to go over that.
            • weirdlookinguy
              • Sep 2007
              • 1638
              Maybe the fan in my AcBel is running at full tilt? Because it's certainly the loudest thing in my PC. I've never had the unit apart though.
              That Delta looks good.
              EDIT: Hey 370, what brand fan is in that Delta?
              • weirdlookinguy
                • Sep 2007
                • 1638
                I didn't read your post carefully enough (It's a Yate Loon).
                You guys have me thinking now. I'm going to try unplugging all my case fans so that all I hear is the PSU and see what happens. It seemed to me like it was the PSU, but you guys say that yours are dead silent.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  My 550W AcBel's fan is pretty loud, but not anything I "lose" sleep over (though I can sleep right through a nuclear explosion)
                  yay 1500 posts
                  • acstech
                    GrumpyModerator
                    • Jul 2007
                    • 1432
                    Mine makes a slight whirring noise, but nothing too loud. I've certainly had much louder fans than the Nidec Beta SL in the Acbel.
                    One of the reasons I like these units as well as I do is that they come with a really good fan! I would say that about anything you could put in there would be a downgrade in terms of reliability.
                    A while back, maybe a year and a half ago, someone gave me an IBM PS/2 Model 30 286. The power supply in that thing has a Nidec Beta SL. The PSU is caked in dust, but that fan spun right up and ran quietly. Made the same low whirring sound that all the Acbel API4FS06 PSU's I've used have made.
                    A man convinced against his will is of the same opinion still.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      I always use nidec when I can, I believe they are easily the highest quality fans out there. Most of their units are rated for 150,000 hours and feature tons of protection features like OVP and some even feature OTP.
                      Some of the server class NMB fans are really nice too.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        earplugs?
                        sigpic
                        (Insert witty quote here)
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          That's what kills me. I have never before seen a PSU that even comes close to matching the quality of the AcBel. I don't want to get rid of it, solely based on the quality. I know that beast will probably outlive everything else in my machine. I also don't want to change the fan because as acstech said, anything else would be a downgrade.
                          • i4004
                            • Oct 2006
                            • 2029
                            i would consider good sleepin more important than pc or anything you can do with it.
                            i solved that issue by buying laptop...that i now usually keep in other room when dloading over p2p etc.
                            as for you, dunno what's your threshold, but mine is that i wanna have piece when i wanna sleep. and psu noise is not piece, afaik. it has those damn deep undertones that bother me.
                            head over to silentpcreview and find quiet seasonic....if you must keep pc in your room on...or find quieter fan for that one...
                            either way, don't lose sleep over pc.
                            • weirdlookinguy
                              • Sep 2007
                              • 1638
                              I don't lose sleep over it, but it is keeping me from leaving it on overnight. Especially now that my Radeon 4850 is folding (go f@h team 49813!), I would like to run my machine 24/7.
                              Luckily my p2p needs are taken care of by TorrentBox9000, "tb9k", a SFF PIII Compaq machine my friend and I run 24/7 at his house. We slapped a 1TB drive and a SATA card in there this summer and it's been torrenting for us ever since. It just sits in his closet, running headless, P2P-ing it up all day and night. We use the built in m$ remote desktop (better than VNC) and uTorrent WebUI to manage it.
                              • Krankshaft
                                • Jan 2007
                                • 2328
                                Just because one fan is quieter doesn't mean it can't move as much air as a cheaper noisier fan.
                                A quiet fan is a combination of these factors motor design, motor speed, blade design, and vibration dampening.
                                You should be able to look up the original fans model number to find out it's CFM and DB ratings. With that in hand a replacement can be selected.
                                • Junk Parts
                                  Court Jester
                                  • Jun 2006
                                  • 8953
                                  Right On Krankshaft! You post brings to mind aircraft prop design, and limitations. Some of the fastest prop driven aircraft make a pile of prop noise at speed. This is because the tip of the blades are at or exceeding the speed of sound. Think mini sonic booms. Also the thrust from the prop decreases greatly at this point because of air turbulances at the blades. Now I have no explaination as to why the big twin rotor transport helicopters make so much womping noise. Maybe the angle of attack of the blade has to be greater to keep the heavy thing in the air, and its cavitation that makes the womp womp noises. Can a blade/fan/prop suffer cavitation in air??? Don't know. Where are you PCBONEZ. You know the answer. But yes, put a well designed fan in it and the noise should be gone.
                                  Mark Twain
                                  John Paul Jones
                                  Rod Serling
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    Problem is, theres not a fan that can really match the quality of a nidec. Maybe delta but good luck finding a quiet delta.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Remove fan.
                                      Install this to PSU but out back of the case.
                                      http://cgi.ebay.com/ws/eBayISAPI.dll...m=140360662811
                                      Pull fan wires through.
                                      Install quieter 120mm fan.
                                      Or you could put the PC in another room.
                                      - In fact.
                                      With USB card reader & optical drive & long monitor/keyboard/mouse/speaker cables there is no reason you couldn't run wires through a wall so the PC isn't in same room as the desk.
                                      Mann-Made Global Warming.
                                      - Dr Seuss
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Sorry, wrong link, try this one instead...
                                        http://cgi.ebay.com/ws/eBayISAPI.dl...em=170406362584
                                        - Dr Seuss
                                        • Bloodhoundje
                                          by Bloodhoundje
                                          03-16-2024, 03:12 PM
                                        • Snownomow
                                          PowerMac G4 MDD ACBel Power Supply issues (API1PC36 400W)
                                          by Snownomow
                                          Hello!
                                          First want to thank folks on this forum (Toasty, etc) for the very useful info I've found here that has allowed me to repair a PowerMac G4 MDD Samsung power supply and get this ACBel one working better!
                                          I got a PowerMac G4 MDD for free as it was dead (not booting at all). I was able to confirm it was it's ACBel power supply as another (above mentioned Samsung) power supply works ok with the system.
                                          With this ACBel power supply installed, the system would not boot at all, no power light blink, nothing. I've gone ahead and replaced the "12...
                                          07-18-2020, 04:56 PM
                                        • Jidis
                                          Need T-Con Advice (Vizio P602ui-B3)
                                          by Jidis
                                          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                          09-22-2025, 05:10 PM
                                        • zlr8r
                                          Advice on newer EC chip programming eg. MEC5107-LJ BGA
                                          by zlr8r
                                          Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                                          i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                                          09-16-2025, 09:54 AM
                                        • Borse2008
                                          by Borse2008
                                          • There’s
                                          07-15-2025, 04:55 AM
