HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
  • Bloodhoundje
    Hobbyist
    • Mar 2024
    • 10
    • Netherlands
    I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
    I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
    After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
    I have desoldered the bios chip (GigaDevice 25lq128csig) and managed to make a dump of the corrupted bios (using a CH341A).
    So far all has been going accoording to my expectations but I am now running into an issue of which I am not sure of if this is caused by the bios I am using.
    I downloaded the latest bios binary from the HP site for the laptop. I succesfully wrote this to the bios chip and managed to get the laptop to fully boot with the "factory programming mode enabled".
    The new bios was missing all the laptop identifiers so I have manually added those with the "BIOS Configuration Utility", this is the DMI editing for HP as I understand. I managed to check the values I added by searching for them in the old bios binary file.
    So far all seemed to work fine. Except that the laptop only uses the 4GB ram in the dimm1 slot. There is 2x 4GB ram in this laptop and swapping the modules around does not fix the issue.
    When running Aida64 I can see both ram modules are recognized (it shows modules with both their unique serial numbers). Only for an unknown reason the bios is ignoring dimm2 and windows can only access dimm1.
    My asssumption is that the bios is missing a flag that enables dimm2, however I am not certain about this since I do not know the history of this laptop and if this issue was there allready before the original bios was corrupted.
    Attached in the ZIP file I have the corrupted original bios binary, the new HP bios binary and the config.txt which I use to alter the HP bios with DMI information (Feature Byte, build id etc). The HP DATA txt file contains the information I managed to grab from the HP parts site and matches the old bios on identification information.
    I have tried searching through both binaries with ImHex but I am not sure which flag would be used for defining what memory slots are enabled/available.
    Would love to hear if there is anything I am overseeing and if there is any additional steps I am missing to get dimm2 to be enabled again. So far I checked the bios guides and searched the forum for any insight into this issue without luck. Also if there is any information missing please let me know and I will do my best to obtain this as speedy as I can :-)
    Laptop information: HP Pavilion Gaming Laptop 15-ec2523nd
    Feature Byte: 3K6b7K7WaBapaqasawbFbhcbdUdpdqfPfdhZm9.qd
    Build ID: 20WWDU1T604#SABH#DABH
    Serial Number: 5CD129BLB0
    Product Name: 15-ec2523nd
    UUID: 354344313239424C42301AE67705AAE0
    Product Number: 461U2EA
    MAC Address: 1AE67705AAE0
    System Board CT Number: PLFTQ028JFG2AF
    System Board ID: 88DD
    Thank you in advance for your time and patience :-).
    Sincerely,
    Rogier​
  • peste
    • Dec 2016
    • 13743
    • ROMANIA
    try to write it again and see what happens... use one of these programs..
    https://www.badcaps.net/forum/showpo...6&postcount=10
    https://www.badcaps.net/forum/showpo...postcount=7​
    • Bloodhoundje
      Hobbyist
      • Mar 2024
      • 10
      • Netherlands
      AsProgrammer didnt give my any luck, with Neoprogrammer there was some change, After entering Bios i did see 8gb memory listed, however the bios froze, upon reboot I received the corrupted bios message from HP and automatic bios recovery started. After the automated recovery completed the bios listed 4GB again and vendor programming mode was unlocked again. I have new Bios chips on order, will see what happens when I program a new IC instead of the current one. At least it does seem that the issue is bios related and the dimm2 socket is not the issue. I will update once I have the new IC programmed and running.
      • Bloodhoundje
        Hobbyist
        • Mar 2024
        • 10
        • Netherlands
        Update, I have received the new IC's and reflashed the bios with great succes this time. Dimm2 is recognized and working properly now and the laptop is back in fully working conditions! Thank you for pointing me to Neoprogrammer, this seems to be the most stable software I have found so far for reprogramming the IC.
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • trepachka
          BIOS rebuild requested for HP Pavilion Aero 13-be0003ca laptop
          by trepachka
          Hello, I have the following laptop:
          ProdID: 2L7M8UA#ABL
          S/N: 8CG150GPV6
          Motherboard information is below:
          HP Part# M52826-601
          448.ONE04.0011
          203016-1
          It needs BIOS repaired.
          I created a flash drive using HP firmware utility and then had it plugged into the computer. I did the standard WinLogo-&gt;B key-&gt;Power button press. A window appeared and immediately began flashing the bios using the flash drive.
          But I don't think it finished all the way. So, now when I attempt...
          04-21-2024, 10:57 PM
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          Yesterday, 04:04 PM
        • sssssssssssssss
          Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
          by sssssssssssssss
          I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
          Symptoms:
          • Laptop powers on but no display at all (completely black screen)
          • Caps Lock blinks twice with a pause, then repeats continuously
          • F12 LED stays on permanently
          • No POST, no boot sequence, nothing on screen
          Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
          What I've tried:
          • Hardware reset (battery removal, power
          09-04-2025, 06:45 AM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
