PSU advice requested
  • i4004
    • Oct 2006
    • 2029
    Re: PSU advice requested
    bad link again..what the hell is
    Code:
    http://cgi.ebay.com/ws/eBayISAPI.dl...em=170406362584
    it'll take you at least 3 tries to link properly....
    and then, buying fans on ebay? is there really no decent store with decent fans in whole of usa?
    • Toasty
      • Jul 2007
      • 4171
      Link doesn't work PCBONEZ...
      "Page Not Responding"
      Something whacked. Try this:
      http://cgi.ebay.com/ws/eBayISAPI.dll...m=170406362584
      veritas odium parit
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Originally posted by PCBONEZ
        Remove fan.
        Install this to PSU but out back of the case.
        http://cgi.ebay.com/ws/eBayISAPI.dll...m=140360662811
        That would be interesting to see on the back of a case.
        • weirdlookinguy
          • Sep 2007
          • 1638
          Nah, it's too drastic. My buddy needs a PSU, so I'll be selling him my AcBel for $15 (he doesn't care about the noise) and buying both the 400w Delta and the 400w HiPro. Whichever one I like best will go in my system, the other will go in the downstairs HP to replace the 7 year old Bestec in it.
          • weirdlookinguy
            • Sep 2007
            • 1638
            Bought the Delta PSU (along with a couple goodies), will keep you guys updated on what effect it has on how loud my system is.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Thanks for the link patch Toasty.
              Drastic? - Me? - nahhhhhhhh.
              Mann-Made Global Warming.
              - Dr Seuss
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Though it's a good idea. Would really only work if you have a newer case with the completely open area for the psu, most of the old cheaper ones out line the fan and the plug covering up the fan's screws.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Not very handy with tools are we?
                  It's called 'trimming'.
                  - Dr Seuss
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    or "dremel time!"
                    sigpic
                    (Insert witty quote here)
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      Caulk, hot glue, duct tape...
                      veritas odium parit
                      • weirdlookinguy
                        • Sep 2007
                        • 1638
                        #31
                        New PSU (the Delta 400w that 370 linked to) comes in Friday.
                        I might do a full recap later on and banish those Ltecs and CrapXons, but for now I will just be happy to have a quiet PC. I'm also kinda discouraged by johnnyguru's article where he recapped a CWT-built Antec and the ripple actually went UP.
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          Well, thats not going to be the case with all power supplies. Just make sure ESR matches or exceeds as well as ripple current. Maybe move up a bit in uf.
                          • i4004
                            • Oct 2006
                            • 2029
                            #33
                            if you're afraid of that, find replacements that are EXACTLY the same(esp. the esr), without the "or exceeds" portion.
                            but there is a "settling-in" factor that that article didn't take into account, ie they didn't wait for those caps to settle in there...
                            so that article is not really a law of physics or alike...heh
                            i just ordered fortron that probaby has capxon, any you know what?
                            i won't be touching it while it works ok.
                            if/when problems occur i'll do something about it.
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              i4004, you're assuming the junk caps were rated correctly at the factory. My guess would be that they were not.
                              If you're going to do that, you need to measure the actual capacitance, and ESR, of the caps out of the unit, when new, and match that.
                              A man convinced against his will is of the same opinion still.
                              • i4004
                                • Oct 2006
                                • 2029
                                #35
                                exactly.
                                i didn't really say one should trust mfrs numbers.
                                time to settle-in aside, that's another error of that test at jonnyguru; there was no test of old vs. new.
                                it really would be interesting to see esr and capacitance numbers for old and new, AND THEN esr and capacitance after few tens of hrs of work(for new caps).
                                i've found a convenient way to measure capacitance (with analog meter on ohm range...it's a matter of comparing readings of few good ones and then writing down the deflection it reaches) and i'll measure some crap caps in this respect, but i think i'll find stuff we already know: if esr is ok, capacitance should be too....if not, capacitance will probably also suffer...
                                ie blown cap probably has decreased capacity.
                                also, given that capacitance tolerance is usually 20-30% one doesn't need to be ultra precise....
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  I just mentioned that article in my last comment.
                                  https://www.badcaps.net/forum/showpo...0&postcount=29
                                  - Dr Seuss
                                  • weirdlookinguy
                                    • Sep 2007
                                    • 1638
                                    #37
                                    The new Delta came in a day early (props to FedEx).
                                    It's.... so.... QUIET!!!! The AcBel was definitely the sole noisemaker in my PC.
                                    And now, to fix the "2-seconds-to-black" Dell E172FPb I found for free on Craigslist....
                                    • acstech
                                      GrumpyModerator
                                      • Jul 2007
                                      • 1432
                                      These would have been cheaper:
                                      http://www.cabelas.com/cabelas/en/te...0027561226688a
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #39
                                        ROFLMAO!
                                        BWAHAHAHAHAAAA!!
                                        veritas odium parit
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          Originally posted by acstech
                                          earplugs?
                                          so much cheaper...
                                          sigpic
                                          • Bloodhoundje
                                            by Bloodhoundje
                                            03-16-2024, 03:12 PM
                                          • Snownomow
                                            PowerMac G4 MDD ACBel Power Supply issues (API1PC36 400W)
                                            by Snownomow
                                            Hello!
                                            First want to thank folks on this forum (Toasty, etc) for the very useful info I've found here that has allowed me to repair a PowerMac G4 MDD Samsung power supply and get this ACBel one working better!
                                            I got a PowerMac G4 MDD for free as it was dead (not booting at all). I was able to confirm it was it's ACBel power supply as another (above mentioned Samsung) power supply works ok with the system.
                                            With this ACBel power supply installed, the system would not boot at all, no power light blink, nothing. I've gone ahead and replaced the "12...
                                            07-18-2020, 04:56 PM
                                          • Jidis
                                            Need T-Con Advice (Vizio P602ui-B3)
                                            by Jidis
                                            I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                            He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                            09-22-2025, 05:10 PM
                                          • zlr8r
                                            Advice on newer EC chip programming eg. MEC5107-LJ BGA
                                            by zlr8r
                                            Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                                            i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                                            09-16-2025, 09:54 AM
                                          • Borse2008
                                            by Borse2008
                                            • There’s
                                            07-15-2025, 04:55 AM
