Solve this problem
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Solve this problem
    One I encountered recently. It was my fault, but I fixed it. Here are the circumstances. I realized there are two actual solutions (probably more if I have better software tools). But this was fixed within an hour
    Initial circumstances
    Laptop Windows 10 64-bit UEFI
    Was stepped on, lid and bezel are permanently damaged, and unable to find replacements. Display is heavily damaged. Display cable is damaged.
    You manage to get it up by plugging it into an HDMI cable. Screen is of course blank since it will always init to the lcd screen, until windows boots
    You realize you need to uninstall an adobe service that won't let you unload it.
    You set it to minimum safe mode
    You realize with the generic driver, it will never switch over to the monitor
    I realized later I could go through the msconfig gui in my head. But I used another way. I'm curious what you come up with
    (does not involve getting the lcd screen to work)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Solve this problem
    Well, what was the goal? Data recovery? That would determine the approach I'd take.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      Take off the HDD from the laptop and copy the info. What's the problem exactly?
      Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
      1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        goal is getting it to boot in the original OS because she needs to use it temporary hooked to the 24" monitor
          • 31294
          serves you right,
          always set your bios to mirror the screen to the external as soon as you get a machine.
          if you remove or unplug the panel, the bios wont see the eeprom that has the vid/pid id in it and may default to the external.
          btw, the same principle applies to android phones,
          always enable dev-mode and then enable ADB and OEM-unlock soon as you get one.
          because you wont be able to go in over usb if you dont - and you wont be changing the settings after you break or drown the screen!!
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5045
            • US
            This bios didn't have that option
            it did work before I set it to safe mode
            as I said above I did fix it, just curious if you've figured it out
            • diif
              • Feb 2014
              • 6978
              • England
              Autorun USB stick with a Powershell command ?
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                interesting. Something I didn't consider. Not too familiar with PS. Wouldn't that require administrator level to edit the bcd?
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  Ok my solution:
                  boot to a windows 10 USB drive. I have no screen
                  Plug in earphones
                  Hit ctrl+win+enter. This enables the screen reader (Working in a public shop with some sight disabled people I learned how to use screenreaders to a point, though I never used the win10 integrated one)
                  navigate through the menus. Get to the advanced screen, and windows cmd. Run the command to remove "safeboot" from the bcd
                  i hear her voice say "the operation completed successfully"
                  reboot.
                  windows now boots in normal mode
                  • koris
                    • Aug 2020
                    • 6
                    • usa
                    Originally posted by stj
                    serves you right,
                    Never knew this was a thing. I've seen bios unlock and switch different onboard display options on desktop. I will check every laptop touch from here on out.
                    This has always been my last resort if the function key and screen switch buttons don't work.
                    I do the dev mode but have never heard of ADB and OEM-unlock. Now i have more learning to do. thanks
                    • koris
                      • Aug 2020
                      • 6
                      • usa
                      That's creative as hell.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        That reminds me of using google voice commands over bluetooth to bypass a password lock preventing me from hard-resetting a galaxy tablet I got for cheap at a pawn shop. Only I cheated and read about the trick online.
                        sigpic
                        (Insert witty quote here)
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5045
                          • US
                          looks like a program to send commands to an android phone and unlock it when the screen is dead
                          https://stackoverflow.com/questions/...ne-through-adb
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            Originally posted by Uranium-235
                            Ok my solution:
                            Plug in earphones
                            reboot.
                            I have to admit, that was clever!
                            Team : 49813
                            Join in!!
                            Team Stats
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Yes, I concur.
                              • GardevoirForEver
                                Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                                by GardevoirForEver
                                I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                                Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                                The motherboard of my ASUS...
                                11-15-2025, 04:30 PM
                              • Zeonalbasta
                                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                by Zeonalbasta
                                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                09-13-2024, 01:17 PM
                              • s_specialist
                                Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                by s_specialist
                                Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                07-07-2025, 11:47 AM
                              • Gibon378
                                Problem with stopping audio and video for no reason
                                by Gibon378
                                PC Specs:
                                • CPU: Ryzen 5 1600
                                • GPU: GTX 1080 Palit JetStream
                                • MOBO: ASRock ab350 PRO4
                                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                • PSU: XFX 650W (don't remember what model)
                                • OS SSD: ADATA SP920
                                • OS: Windows 10 21H2
                                Problem description:
                                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                11-19-2022, 09:41 AM
                              • perzyk23
                                Lenovo T580 - LCD Panel problem - error 0288
                                by perzyk23
                                Good morning,
                                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                10-25-2024, 12:42 AM
