What will fit in this dell case?
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Morning everyone. I have a question. Will any after market mobo fit in a Dell OptiPLEX GX180 Tower? I know that I will also need a newer PSU too. Here is a pic of the thing.
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: What will fit in this dell case?
    If it is one of the clamshell cases, I know most of those would use clips instead of mounting screws. Otherwise it should be standard atx, dell is usually pretty good about using standard atx mounting holes.
    Basically if the motherboard mounts using long, thin holes with a clip coming through instead of being normal, you're SOL.
    • washu
      • Jul 2009
      • 310
      I haven't used a GX180 before, but if it's anything like the GX2XX series (and it looks identical) then the MB is anything but ATX. Those all have the MB mount using the clips 370 described and a single screw to a removable tray. The tray then slides and clips into the case.
      You could probably jurry rig something in there. The biggest problem would be the MB back-plate as it's not removable.
      The PS if it's still there is probably ATX, but double check before hooking it up to a generic MB. Some older Dells had ATX connectors with different pinouts. Good chance of frying a normal MB with those. All the Dells I've encountered in clamshells had standard ATX power, so you're probably ok.
      • Wizard
        • Mar 2008
        • 2296
        I have this exact case (Dimension 8300). Slot and hook on a snap on tray. PSU is ATX.
        Look everywhere else for different case or find a good Dell mainboard and recap. Make sure to get the tray if missing.
        Also you need Dell heatsink with odd clips (don't like these) or do a slight modification to the P4 heatsink bracket to clear the row of caps by thinning the section of rail on the P4 bracket. Which is better.
        Drives uses shoulder screws and green rails. You'll need 12 rails if you are utilizing all the drive bays.
        Prefer to get Dell 775 mainboard to upgrade your case instead of P4. I'm using 2.8C and it's showing it's age.
        Cheers, Wizard
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Chassis mod is like customizing a car body.
          You can fit about anything you want IF you are willing to do the necessary surgery.
          Mann-Made Global Warming.
          - Dr Seuss
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            my L933R is like that. the way it is built, the mobo's front edge needs to be the same distance from the holes as the original, it uses clips with a clamp. not to mention a proprietary psu.
            sigpic
            (Insert witty quote here)
            • dan86
              • Nov 2009
              • 35
              I've had a look at a few dell tower servers/desktops and found that the mobo/psu has been designed to fit just the dell stuff and you can't really fit any other atx motherboards in. Saying that you can always size it up and it may fit.
              Daniel
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I've taken old heavy duty AT and NLX horizontal desktop type cases and chopped out the sheet metal to fit in the motherboard pan from a standard uATX or ATX case.
                Simply used pop-rivets and/or solder [as like plumbing or car body soldering work] to mount the standard pan in the non-standard case.
                Sometimes similar mods are needed to fit a standard PSU, sometimes not.
                May have to add a fan or vent holes depending on the case.
                The goal for me was to get a horizontal case which saved some desk space because the monitor or a printer can sit on top of the PC case.
                - Dr Seuss
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  maybe gx 260,270,280 board and tray.how does your front panel hook up?
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Well Kc its in my wifes desk right now and its a bitch to get it out of there. If I remember right it has all the LED's and the power switch in a single plug. I think the pins can be released from the plastic connector. This would let me connect another mobo without cutting anything. The gang plug may also fit a non-dell mobo too. Its a long shot but maybe. The PSU isn't Dell. Its just a POS out of the junk box, and it works well. I don't remember if it was P4 ready. Thats ok because I will have to buy a PSU with more ass if I upgrade in that box anyway. I was thinking that if there is a GX 180 case up at the shop I could just test fit a few junk mobo's and see what hang ups I will run into. This is a long shot too as Vernon hasn't gotten any of these GX 180 units in a long time.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • kleung
                      Dell ultra 7070 ,Foxconn PWM laptop case fan. Spins at 100% speed in failure mode.
                      by kleung
                      I wanted to add to the knowledge base about a PWM case fan that it can fail at 100% speed.
                      On my Dell ultra 7070 (this is a 0.6 L pc so uses laptop parts); I had the case fan suddenly go 100% and I couldn't control it. I disconnected/reset bios and it was only solved when I swapped in a replacement fan.
                      I have tested and there is continuity between the 4 wires pins and the circuit board.
                      That is the extent of my troubleshooting. I took pictures of the circuit board but don't know what component would die (PWM controller?) that could cause this to happen....
                      12-07-2024, 01:45 AM
                    • master3112
                      by master3112
                      07-29-2025, 01:55 PM
                      ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                      This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 10:50 PM
                      ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 11:05 AM
