New SSD hard drive in laptop computer what a difference in boot time
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    #41
    Re: New SSD hard drive in laptop computer what a difference in boot time
    I can't find mention of the 850 anywhere, only the 800
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8694
      Originally posted by clearchris
      Personally, with computers, which are mostly mobile these days, they don't have to design obsolescence in, they break from physcial shock. That said, I don't know who prefers their phone 1mm slimmer (except for phone reviewers, omg a 2mm bezel, that's so 2016!) instead of having a more physically sturdy device.
      Though an argument could be made that these super slim phones are planned obsolescence.
      Yep, the flimsy machines is indeed designed obsolescence in of itself. The fun is that the consumer *wants* the flimsiness so two birds killed in one stone.
      I still use a 10 year old pre-android/apple smartphone. It too is affected by designed obsolescence. Whole bunch of stuff is broken on it, alas I keep on using it, no, I refuse to go to phones that do what the companies want them to do...
      (BTW, one of the many problems of my phone is that its GPS is broken...so at best they could triangulate by cell towers, if there's enough of them in range...if...)
      • clearchris
        • Dec 2013
        • 687
        Impressive. I used my Samsung Galaxy S3 for I think 6 years. Replaced a whole bunch of stuff on it, and my daughter uses it now. Getting ready to do a screen and home button replace. Oven should come in handy for that. My wife's phone is awaiting parts for repair, so I swapped her my oneplus 6 and I borrowed the S3 back, and it's still pretty good for an ancient phone. Helps that I installed lineage though.
        If you do upgrade, just make sure to get a phone with an unlocked bootloader. You can install whatever you want on it then. Smartphones are pretty incredible, my oneplus actually has as much RAM as my laptop.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Originally posted by chegueva
          I had an ADATA Su850 that i bought for 20$. the best 20$ i'v ever spent. Blazing fast and never had issues with booting or whatever. HDD era is gone
          I wouldn't say that yet! SSDs, especially for ones that are less than $60-ish, you're at a higher risk of silent OS corruption. Check the event log for what look like drive-related errors, if you use Windows.
          Check for new corruption errors that suddenly appear out of nowhere! And most SSDs have a notable limitation of the number of writes, especially for SSDs less than 240 GB.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • lti
            • May 2011
            • 2547
            They also want it cheap, which makes it worse. Anything that will actually last a while is "ugly" and "poor value." The cheap form-over-function junk is "better" until it dies, and then the conspiracies start flying.
            I'm still using a Samsung Galaxy S7, and I haven't had to replace anything (even the battery). Since the replacement batteries available are cheap knockoffs that will probably be worse than the old one, I will probably replace the phone completely once the battery dies.
            Back on topic, the first SSD I ever had was a Samsung 970 Evo. That was a nice upgrade from the cheapest hard drive available in 2012. I'm waiting on an Adata SU650 for a computer I don't care much about. It's a really cheap SSD, but it's surely better than a hard drive from 2008 with a few hundred bad sectors. It should saturate the drive interface (and probably cause stability problems, considering the "quality" of the motherboard).
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              #46
              You can work-around the write limitation by overprovisioning (hiding extra capacity that isn't normally visible to the user). But, this adds cost -- which tends to reserve the feature for higher price-points.
              But, there is also a "read disturb" aspect of FLASH in that data can become corrupted just by reading it (or, worse -- reading "neighboring" data). With MLC/TLC/QLC FLASH at ever decreasing geometries, its often the case that you're trying to count JUST "dozens" of electrons to distinguish between data states.
              So, even if you use an SSD as your "system disk" and never write to it (move paging file to another volume or disable paging entirely), the SSD will still need to "refresh" data that you assumed was "read only". So, it must WRITE to other "spare" sectors to restore the integrity of the degrading data.
              At the same time, data sectors that see very little use are having their rewritability "wasted". So, the controller can opt to deliberately move their contents to someplace else so the sectors can be put to use on data that needs to be "refreshed" (written or rewritten).
              This leaves you exposed to the possibility that the data that you thought was read-only and "immutable" might not be available when you need it (slow read) or, perhaps, may not be rewritten, successfully.
              This behavior doesn't seem to be present in spinning rust -- at least not in the same frequency as the medium wears.
              Finally, SSD controller software has been notoriously buggy, over the years, as the algorithms used have to be tuned for the types of FLASH that they will control.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                #47
                I think a lot of this has been mitigated by better management systems built into firmware (mind you generally not cheaper brands). That does even writes across the logical flash
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  #48
                  Yes. But you're still faced with the fact that you're now "evenly" wearing out a medium that has a fixed "durability". You can't hope that the OS (because it isn't being "updated") will be "persistent" and without error.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8694
                    Well actually for cell phones, cheap is good. I see lots of people toting around phones with cracked screens - this is not fault of the design... but sh*t happens and easier to replace...
                    I got to admit that I have deep scratches in my 10 year old phone. Screen's made of plastic so no crack...
                    Incidentally the solid state storage in the phone is still working. I don't know when it will start failing when it runs out of erase cycles.
                    "segwaying" (ugh...hate that term) back on topic... the oldest flash main storage media I have is a 32GB (mPCIe-SATA) in my eeePC. I have no idea how many erase cycles it has on it now as its SMART data isn't documented. Wonder when it will fail, but the SMART field is still 100% ...
                    I also have a 32GB "disk accelerator" SSD in my other laptop which has been disabled and used as swap. It actually has significant wear on it now, surprisingly enough. Still has more than 80% of its life left. I probably should set swap to the laptop's main SSD which I think it still says 100% life left as it hasn't reached 1% of erase cycles.
                    The oldest 2.5" regular SSD I've ever had has 98% of its life left (128GB)... I gave it away but still have remote access to it. That laptop uses it for swap, too.
                    • dmill89
                      • Dec 2011
                      • 2534
                      X2, I never spend more than $100 or so on a phone. I've found that the "cheap" phones hold up much better then the pretty but fragile "flagship" models (with their massive amounts of unprotected glass and internal batteries), and at that price they are essentially disposable so if it does get damaged it is no big deal to replace it. The only time I've broken a screen on one of these "cheap" plastic screen phones is when it fell out of my belt clip while I was changing my HVAC filter (the unit is in the garage attic) where it fell at least 10 ft. onto a hard concrete floor below.
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        #51
                        In consumer devices, there's usually not enough "activity" to wear out the FLASH. I don't do ANY wear-leveling in my current design; the FLASH is only written when the firmware is updated (once a year?) as the products actually execute out of RAM.
                        It also depends greatly on whether its SLC, MLC, TLC, QLC, etc. And, if the "storage device" is internally overprovisioned.
                        Finally, how smart the FTL is in distributing writes and detecting read-wear.
                        [BTW, it's "segue"]
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          #52
                          Just by coincidence, I received a "care package", today, with three 250G Samsung 840EVOs. I may try installing in a couple of my "disposable" laptops to see how they fare.
                          • ChaosLegionnaire
                            HC Overclocker
                            • Jul 2012
                            • 3264
                            • Singapore
                            #53
                            umm dont u frequently overwrite the main drive of those disposable laptops to create a clean copy or clean os installation? overwriting the entire capacity of the ssd with an image may increase the write amplification on the flash and shorten its lifespan esp. since its tlc flash.
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              #54
                              With the existing "spinning rust" drives, that is the case -- each boot restores a fresh copy of the OS.
                              But, I'd have to install that hack in any new "boot media"; so I could choose to NOT install it on an SSD just to get a feel for whether it makes any practical difference in usage. I can always reinstall the rust drive to regain that previous behavior.
                              I'm also looking into just putting them in external enclosures and making "big thumb drives" out of them. I suspect that may offer the bigger improvement, for me, given how little I use the laptops and that I tend not to "wait" for a machine to boot (turn it on BEFORE heading off to get a beverage or a trip to the bathroom, etc. -- it's ready-and-waiting before you return, regardless of how long it takes to boot!)
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3264
                                • Singapore
                                #55
                                u could also just do it anyway since the drives are free and see how long they last in the name of science and also to see if they last the claimed 500 or 1000 or whatever p/e cycles as claimed by samsung in their 840 evo tlc datasheet. hehe... i believe ssds have a SMART parameter that records total LBAs written.
                                another thing u could do is to make the ssd read only after loading a boot image on it. is there an ata command to make an ssd read only or by hacking the ssd firmware? i'm really interested in this as well for a personal project.
                                then u can write, as in code, the boot loader to load the entire os image into ram and run off ram like u did with your other job where the flash is only written to and updated only once a year for updates and the os runs entirely off ram.
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  #56
                                  The question will be how much life has been used, already. Even rewriting the entire image on boot would last YEARS, given that I rarely use a laptop.
                                  Or, I could recode the image reloader to only write portions of the image that have changed in the belief that most of the OS (and, thus, the image on the media as well as the image to be restored) won't be "touched" in normal use.
                                  The problem, there, is the swap area (page file). If you disable paging, then you limit what the laptop can do before a panic(). (most laptops have small RAM)
                                  Other project is entirely different. I designed the hardware, I wrote the POST/BIST, I wrote the loader, OS, etc. So, I know EVERYTHING about the system.
                                  By contrast, I don't know ANYTHING about what happens in windows after the disk spins up. All I know is where to put things on the disk so Windows will find them!
                                  • lti
                                    • May 2011
                                    • 2547
                                    I don't think the expensive phones are worth it, but that's because it seems like paying more just gets you more pointless crap that only exists to pad out the marketing and give the manufacturer an excuse to release a new model. Why do I need six cameras?
                                    The cheap SSD I got didn't work out, as I predicted earlier.
                                    It's stable, but it's slower than the old hard drive when it's installed in that computer. I loaded an image onto the drive through a USB converter, and it wrote at the speed I expected. When it's in the computer, the continuous read speed is 19MB/s.
                                      master hoarder
                                      • May 2008
                                      • 12170
                                      #58
                                      I guess I'm joining in a bit late to put down my 2 cents, but here it goes.
                                      Last year when I started at my new job, they didn't have enough new laptops to give out to all of the techs. Since I needed one for my job, I went to the IT folks in our office and picked an old laptop from a box of retired ones - a Dell Latitude E6430 (with a 3rd gen i7, 8 GB of RAM, and Windows 7 Pro.) Anyways, the laptop belonged to a previous tech and had a few issues. Besides being extremely dirty and sticky, and its battery dead, it would also not boot reliably or boot at all most of the time. I took out its original HDD - a 500 GB Seagate - and cleaned its head amp PCB contacts. This got the HDD to boot more reliably, but the laptop was still quite slow.
                                      So, as an experiment (and out of need), I went to my local Micro Center and grabbed the cheapest SSD I could find - an Inland Pro series 120 GB 2.5" SATA SSD for a little over $18 after taxes. Then, I cloned the original HDD to the SSD (after removing a bunch of junk, as the 500 GB had way too much crap on there and would not fit on the 120 GB SSD.)
                                      The results: massive!
                                      The old Seagate HDD would take about 2-3 minutes to boot to desktop and have everything loaded and ready... and sometimes longer. The SSD: 20-35 seconds tops from pressing the power button. Not only that, but loading anything while using Windows is many times faster with the SSD. It really is night and day difference! Also worth noting is that the Inland Pro series SSDs do NOT have cache, so they aren't even that fast compared to other SSDs. But the access/seek time compared to a regular mechanical HDD is still much smaller (a millisecond or two vs. 8-14 ms.)
                                      To confirm the results from my experiment above weren't due to the flaky Seagate HDD, I also cloned the OS to a Toshiba 320 GB HDD that had good SMART parameters. The results with the Toshiba HDD weren't much different from the Seagate HDD.
                                      So in conclusion, even that cheap Inland SSD was well worth my money, given how much booting time and battery life it has saved me (FYI, I changed the original 6-cell battery to an extended 9-cell battery, as the original would not hold even for 5 minutes, while the 9-cell did about 2 hours when I first installed it.) It's also worth mentioning here that I boot my work laptop 2-5 times per day... and sometimes even more (up to 10 on busy days.) Thus, I've put a lot of read cycles on that cheap SSD. It's been a year more or less since I put it in the laptop, and it's still holding up OK.
                                      Lately, however, I've been noticing that Windows will sometimes load a bit slower on boot (take an additional 10-30 seconds) or load certain programs more slowly than before. Not sure if the SSD is starting to wear out or what. I also had my first "soft crash" yesterday, where the laptop just didn't want to load anything and was just sitting there. Of course, this could also be due to the interface, because even without an HDD/SSD, sometimes this laptop would sit at a black screen and never get to POST or would freeze on HDD detection in POST (and I've seen some other Dell Latitudes from that era have had this problem too.) So it may or may not be my SSD at fault here. In any case, I'll probably clone its current image soon again, just so I have a recent backup. (And maybe do a defrag on the SSD to "refresh" some of its cells?? Sounds reasonable??) Coincidentally, when the whole slowness at bootup started, we also had a bunch of software updates that week for our VPN software. So that may have something to do with the slowness too. While I do have MS Windows updates off, our work laptops do have Symantec AV, which seems to like hoard quite a bit of the HDD activity.
                                      In any case, even if that SSD dies on me, I will happily go back to the store and get another one. There is just no way I can go back to old mechanical HDD in a laptop - or at least on my work laptop with all of the company bloatware on there. (Though in all fairness, our company is pretty mild compared to many others, so I shouldn't complain too much here.)
                                      Now on the desktop side, I don't mind the good old mechanical HDDs. Of course, my desktops are for my personal use, and they don't have automatic updates, anti-virus, or any other software that updates automatically and slows down the bootup times. So because of that, most of my desktops boot quite fast (especially the ones with single-platter 250 GB WD Blues - about as fast as my work laptop with its SSD.)
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #59
                                        No, a SSD has a seek time of sub 0.1ms, that is their advantage, i.e. they are an order of magnitude faster than mechanical HDD's at random seeks.
                                        No, you should not do a defrag on an SSD, it is determinal to its life, an SSD does not become faster by having the data in a continuous block:
                                        That is for mechanical HDD limitations to not have the read arm hunt back and fourth thus incurring the multi millisecond latency in the first quote above.
                                        What you should do is just use a driver (AHCI) that supports the SSD TRIM command, that way the SSD will keep track of this itself.
                                        Some SSD's do become slower with age because their lookup table becomes really complicated, and this is worse on a SSD without cache.
                                        The cache is NOT for speeding up data writes, it is a cache for the lookup table of where all the data is spread out.
                                        A way to fix it is to use some SSD manufacturers tools that can "prime" this buffer, Intel calls it something like SSD optimization in their toolbox software,
                                        but anyway even if your SSD does not support that you can do it in a manual way:
                                        After having done that backup do a secure erase and then write back the backup, that will take care if it a "brute force" way.
                                        There is also a less "brute force" way by using the software "diskfresh"
                                        You can read this article for some more in-depth details, albeit aimed at Samsung it is also valid for other brands too:
                                        https://www.techspot.com/news/65661-...msung-ssd.html
                                          master hoarder
                                          • May 2008
                                          • 12170
                                          #60
                                          Yup, you're right. I just looked at some of the benchmark tests on my test PC, and indeed most are 0.1 ms or thereabouts. Even a very old 6 GB 2.5" laptop IDE/PATA SSD of mine had sub-1 ms seek.
                                          I know, but I was hoping the defrag would at least move (i.e. write/re-write) some of the files around, making the HDD faster again. I didn't do it, though, since it crossed my mind it probably won't do anything.
                                          Thank you for that information!
                                          I will give this (diskfresh first... then a full secure erase + clone) a try when I have some more time off from work. I already cloned the SSD (onto another SSD ).
                                          However, the more I look into the problem, the more I'm starting to think it may not be related to the SSD. In particular, if I start Outlook and close it down, then try to open it again... it won't work. Doesn't matter if I kill the Outlook.exe process or not. It just won't ever start a second time. Same goes for the proprietary monitoring software/program we use for work (which uses Net Framework and/or Visual C++ libraries, IIRC.... and it's a buggy piece of turd at best.) IDK, does that sound like a possible SSD problem? The only way I can see this to be so is if these programs have some data moved from memory into the Windows pagefile (which is on the SSD), and then data getting corrupt there??
                                          Anyways, don't mean to hi-jack this thread with my work laptop's problems. Perhaps I'll just try the cloned SSD and see if anything changes.
                                          • anton brunner
                                            Having a hard time dumping BIOS - Lenovo Ideapad Duet 3 (11IAN8)
                                            by anton brunner
                                            I'm having a hard time dumping the BIOS of a Lenovo Ideapad Duet 3 (11IAN8). The chip is a Winbond W25R256JVEN, directly soldered to the board in a WSON8 package.
                                            Since there are lots of tiny components near the chip, I was hesitant to desolder it using hot air. Instead, I soldered thin wires directly to the chip's pads and connected them to a CH341A programmer (photos attached).
                                            The chip is detected correctly in both NeoProgrammer and ASProgrammer, but I'm unable to get a consistent dump. I've tried over 15 times — shortened the wires to...
                                            05-15-2025, 01:01 AM
                                          • privato89
                                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                            by privato89
                                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                            Let's begin:
                                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                            03-26-2024, 06:37 AM
                                          • turborex
                                            HP Envy 15 AS-105 random shutdown. (Core I7-th gen 2017)
                                            by turborex
                                            Hello folks.
                                            I bought this machine brand new. It ran fine for nearly 6 years. Lately, it has been plagued with random shut downs without warning and I have nearly pulled my remaining hair out trying to troubleshoot the issue.
                                            I have no electronics knowledge though if anyone can guide in the right direction this would be awesome.
                                            Description:
                                            ----System will randomly turn off. There is no specific timing. Sometimes it can run normally for a couple of days without the issue but once it starts; it becomes more frequent, and then it sort...
                                            09-19-2023, 12:51 AM
                                          • eltano4i20
                                            [HELP] SAMSUNG NP270E4E-K01AR
                                            by eltano4i20
                                            1) Error trying to enter the BIOS
                                            --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                            Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                            BOOT PRIORITY ORDER (img-05)
                                            1- Windows Boot Manager
                                            2- SATA HDD
                                            3- NETWORK
                                            4- Debian
                                            2) Error trying to access the BOOT MENU
                                            --> I restarted the notebook and pressed [F10] but the BOOT...
                                            07-04-2025, 12:39 AM
                                          • woj
                                            Aspire V 17 Nitro (VN7-791G-77NA) startup failure
                                            by woj
                                            Last year I "inherited" a colleague's laptop (see model in title) that initially worked fine. (I put in a 500GB NVME SSD and had to set the BIOS in Legacy mode to make it work.. I think I had also updated the BIOS at the time.)
                                            Unfortunately the laptop developed an issue that got worse over time: When powering up, the laptop would sometimes just stay dark (no backlight and/or BIOS splash logos - though the fans where turning on and off). It would take repeated power off/on to eventually make the laptop boot into Windows. Once the boot reached Windows, the laptop seemed...
                                            05-19-2023, 10:30 AM
