BigTrolls Tiny Chinese System!
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Okay I built this last year and put alot of thought into it, I wanted to build a system with a really crappy chinese motherboard and see how it would run. for the case I started with the CUK Axiom which is a rebaged realan case and has a 200w psu with cheap caps and really can do about 160w.
    Next the motherboard I chose I found on gearbest, its a generic B75 1155 matx board that has USB3 and 6gb/s Sata. This board does not support TurboBoost so I chose a Core i3 3225 that has the Better HD4000 and no turbo.
    It has a Titan low profile heatsink for the cooling.
    The I/O sheild for the motherboard was also poorly cut so I used a dremel to make sure the USB ports aligned better.
    Now the best part this motherboard has bad caps straight from the factory, NJCON polymers and ChengX eletrolytics never before have I seen such amazing quality.
    I did put in 8GB of crucial DDR3 1600 and a 240GB crucial BX500 so it boots Windows 10 extremely fast. I also have had no stability problems with the unit yet.
    So the real question can the Chinese build a cheap motherboard that works and the answer is YES!
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • 31158
    Re: BigTrolls Tiny Chinese System!
    you do realise that dell (foxconn) and most other big names are made in china too?
    • BigTroll
      • Sep 2010
      • 1317
      • LAMBDA SOND
      Of course but this is a home grown board, probably out of a Shenzhen startup!
      https://www.gearbest.com/motherboards/pp_1715558.html
      here is the board was only $40 when i got it last year, who makes it though is a mystery.
      • lti
        • May 2011
        • 2555
        That ATX power cable is ridiculously long. It looks like it could reach all the way to the expansion slot.
        I also see that they spared no expense on the PSU fan guard - no stamped grill.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          errr yea... by chinese standards yea... the quality is indeed amazing.
          really...? have u tried superpi, prime95 and intel linpack? i stress test my systems very rigorously...
          nope the real question is whether the chinese can build a cheap motherboard that lasts and the answer is still debatable! so thanks for posting. i shall take note of this date and start counting the days on how long it lasts...
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            probably a failed startup years ago if they were releasing them with that chipset (sandy/ivy bridge) era, ~2012
              • 31158
              actually there are a lot of chinese motherboard makers that simply dont export - the home market is big enough for them!
              you often see their boards sold used online though because the internet-cafe's and gaming centers upgrade the boards and not the entire machines.
              so there are shitloads of used motherboard/cpu combo's for sale.
                • Jul 2011
                • 6057
                Have you torcher tested this mother board yet to see how it really works and how well
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Despite using a no-name Chinese board, I think this is still a pretty cool build.
                  Should be plenty for the system.
                  Just make sure it has good caps - especially if it has APFC and has a cheap input cap there, as that is really likely to go out after a few years of use.
                  Lol
                  I wouldn't actually worry about the NJcon polymers, because they are polymers caps after all, and a lot less likely to fail.
                  But ChengX.... yeah, they gotta go - at least the bigger ones or ones that filter any important rails.
                  IDK, maybe the Chinese have improved their quality over the years, but I still don't think they can make reliable caps in the long run. Better stick to the known Japanese brands.
                  Linus tech Tips had a video not too long ago on buying a Chinese X58 board and using it OC an old 1366 CPU. The results were pretty interesting, actually. While the board wasn't a great OC'er, it did support USB 3.0 and m.2 slots - something that IIRC didn't exist on any X58 boards back in the day (well, at least m.2 anyways.)
                  So I wouldn't discredit the Chinese boards in terms of reliability. As long as they followed the Intel design specs, they are probably fine. In terms of reliability, it will be just down to the components they used for the board. Pretty sure MOSFETs and other ICs are fine. Probably only the shoddy electrolytic (and possibly polymer) caps are the ones to beware of.
                  And of course possibly buggy BIOS and lack of long-term support for it.
                  Those "stress-tests" aren't always good in determining if a system is stable.
                  Take for example my Q6600 / EVGA 780i-SLI build: it can run Intel Linpack and Prime95 for hours. I used these to check the cooling performance of my system. But when it comes to stability, I found that certain video-decoding programs (YouTube/Firefox included) will make the system halt to a BSOD in a matter of minutes, if even that. Seems like the varying CPU/GPU load is causing instability, no matter what BIOS options I tried (in regards to voltage control and spread-spectrum) or what video cards I tried (both AMD/ATI and nVidia.)
                  Also found the above mentioned issue is not specific to that system. The build I put together with an MSI MS-7778 board and A4-5300 APU had the same problem with video decoding when I used certain RAM on that system (would crash Hynix, Nanya, and certain Samsung sticks.) Yet, it would never crash under harsh CPU or GPU stress-tests.
                  Well, doesn't that apply for any modern motherboard today?
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Especially Kentsfield processors, there's a good chance you got WHEA_UNCORRECTABLE_ERROR BSOD (STOP: 0x00000124) for a bus/interconnect error. You must check the event log for the error type thrown by the Kentsfield CPU.
                    It's likely that you need a bit more FSB termination voltage, with a Kentsfield!
                    And in my experience, relating to bus issues, Linpack is likely to pass, while you can expect blend Prime 95 to reveal the issue!
                    And for video encoding, if you suddenly receive "0x00000124" for "internal timer error", then shut off all the "green" options!-> That means disabling EIST, C1E and "turbo".
                    (For my socket 1366 rig: I never had the dreaded internal-timer-error-related-BSOD again with my Core i7 "Bloomfield" Extreme 965 with my Asus P6T Deluxe, after shutting off all the "green" options.)
                    And with new builds of Windows 10, there is a report of Microsoft changing the BSOD to GSOD!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3264
                      • Singapore
                      as a side joke, its heresy to use japanese caps on a chinese board according to the chinese. hehehe...!
                      • lti
                        • May 2011
                        • 2555
                        I think it applies to the "gamer" or "creator" boards. I feel like the board manufacturers care more about appearance than making something that works, even on the boards for "workstation-class" CPUs like Threadripper.
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          Looks like the same noname china mobo I bought just for fun a couple years back, except yours actually has USB 3.0. Mine was advertised as having it and I asked the seller on ebay if it actually has USB 3.0 and he confirmed that. Ended up receiving a version without it, contacted the seller and they just immediately refunded the whole price no questions asked O.o
                          Not gonna complain about a free brand new mobo
                          Mine works fine, has a 2018 dated BIOS, H61 chipset and has been running stable with a random old i5 (3340 I think it was?) I had lying around in a SFF Acer XC-105 case. Worlds better than the useless E2-6110 APU that was in there originally.
                          Mainly bought it because I was curious about the quality and if it would be stable or turn out to be a nightmare of random problems. And because it was the only available DTX mobo that didn't cost an arm and a leg (DTX = ITX with one more expansion slot)
                            • Jul 2011
                            • 6057
                            I wonder what China design and made mother board are any good I would not mind trying one out on a “I7 CPU but I do not know which one to buy and even where to look ( but I would be looking for some type quality I do not want to buy something that there is no quality at all)
                            And then are all the drivers available and easy to find
                            I like to use the SFF computer style ( because I want to be able to put the monitor on top of it ) for some thing that I not going to stress the hell out of it
                            If I going to stress the hell out of it I want a full size computer case with several cooling fans in it
                              • 31158
                              drivers are not board-based, you just need to go to the chipset makers site.
                                • Jul 2011
                                • 6057
                                This might sound like a real stupid question but I am still going to ask it
                                Where do you find this information on the chip it self and how do you know if you are looking at the right chip
                                  • 31158
                                  just look at what they are close too - or post a picture here.
                                  anything with realtek or a crab printed on it is going to probably be audio or network for example,
                                  the biggest chips are the bridge chip(s) and maybe gpu - probably intel chips.
                                  • glovecaps
                                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                    by glovecaps
                                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                    11-25-2024, 04:23 PM
                                  • Docus
                                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                    by Docus
                                    Hi everyone 😀,
                                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                                    06-10-2025, 04:24 PM
                                  • Archimedes
                                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                    by Archimedes
                                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                    Fans are spinning. Blindly could install windows11 and got the device manager...
                                    07-30-2024, 05:14 PM
                                  • dragon3x
                                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                    by dragon3x
                                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                    power on.
                                    Here are some examples :
                                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                    switching supply area).
                                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                    than 6.3 V.)
                                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                    I replaced capacitors with aluminum-polymer.
                                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                    03-21-2025, 02:46 PM
                                    ASUS P5GC-MX motherboard recap
                                    by momaka
                                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                    So here is what the motherboard looked like with its original caps:
                                    CPU VRM area up close…...
                                    01-27-2021, 11:59 PM
