Win XP Pro
  • LAGun
    • Jan 2020
    • 8
    Win XP Pro
    I have a machine with XP Pro that boots up with no icons or start menu.Safe mode is the same.
    I can go into TM and get to everything.
    I have read that to just change the "EXPLORER" name to something else like "EXPLORER2"and it will work.There has got to be something more than that.Maybe in REGEDIT?
    This machine runs some sort of bingo software
    Anyone have any Sane ideas ?
    Thanks a bunch!
  • petehall347
    • Jan 2015
    • 4439
    Re: Win XP Pro
    has it got a partition with repair on it ?
    you could do a repair with xp cd but clone the drive first in case it goes wrong .
    • R_J
      • Jun 2012
      • 9588
      Re: Win XP Pro
      If you can bring up task manager, Can't you choose, file, New task (run) and type explorer.exe
      Check regedit: HKEY_LOCAL_MACHINE -> Software -> Microsoft -> Windows NT -> CurrentVersion -> Winlogon and see if Shell = Explorer.exe
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Re: Win XP Pro
        What happened before this started?
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Re: Win XP Pro
          I suspect he acquired it in that state: "This machine runs some sort of bingo software". It may have been part of an OEMed product -- much like the PC-based cash registers that you encounter at the supermarket.
          His question would then be "How did they hide all the stuff that you would normally expect to see on a WinXP machine? And, how can I unhide it??"
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Re: Win XP Pro
            Ahh, I skimmed that part. Group Policy editor is your friend for fixing this!
            Team : 49813
            Join in!!
            Team Stats
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3264
              • Singapore
              Re: Win XP Pro
              yea thx for explaining george. i first though the OP must have been surfing pr0n or something and ended up having his system infected by malware and viruses thus the empty desktop shell. hehehe...
              • LAGun
                • Jan 2020
                • 8
                Re: Win XP Pro
                Yes I did get this machine in the state it is in. I have been given the task of fixing it.
                I do not have an XP Pro disc.
                This machine runs a digital type bingo machine. The machine runs a dongle that controls the fan motors for the balls,touchscreen and display board.
                It boots up with no errors.I looked at the error log.
                The operators of this are used to seeing the usual desk top and click on the software to start everything.
                The unit shows the XP with scrolling bar. It does give a glimmer of the splash screen before ending with the background color of the default XP fuscia color with cursor just no icons or start menu.
                I do not know what happened before this started.I am third party to this.
                There is no additional partitions on the HDD.
                I am not sure if this unit has been on the web but I believe it is networked to other monitors in the building.
                • petehall347
                  • Jan 2015
                  • 4439
                  Re: Win XP Pro
                  can you login as admin ?
                    • 21626
                    Re: Win XP Pro
                    Do any of you remember Kellys-korner ,that was a great site back in the day with a lot of scripts to fix a ton of problems with xp. The site was closed down but ghacks has an archive of all the scripts: https://www.ghacks.net/2017/04/29/al...ipts-download/
                    • petehall347
                      • Jan 2015
                      • 4439
                      Re: Win XP Pro
                      https://helpdeskgeek.com/how-to/rest...ly-in-windows/
                      • LAGun
                        • Jan 2020
                        • 8
                        Re: Win XP Pro
                        Seems like if I logoff the user I can go in with admin privileges.Nothing I have tried has flagged me yet.
                          • 31199
                          Re: Win XP Pro
                          that is xp-embeded - not xp
                          dont trash it - find the bingo aplication and see if it's corrupt - if not find xp's startup script to see why it's not running it.
                          your NOT supposed to have icons, startbar etc - it's cut down for security.
                          still shit btw - i'v seen loads of xp/win2k based machines bluescreen - and that's just at tradeshows!!!
                          MAKE A BACKUP *IMAGE* BEFORE YOU CHANGE ANYTHING.
                          • Curious.George
                            • Nov 2011
                            • 2305
                            • Unknown
                            Re: Win XP Pro
                            Not necessarily. It's whatever the developer chose to use as their base. E.g., I have a DSO that has Win95 in it (to run its GUI)... do you recall a "Win 95 EMBEDDED" product being offered?
                            +42
                            Esp if you have no restore media (not just for the OS but also for the APP!)
                              • 31199
                              Re: Win XP Pro
                              it's XP-embeded - because it has to be.
                              xp cant have the plug pulled at night, it needs a proper shutdown.
                              the embeded version has a moded file system handler that writes imediatly to prevent drive corruption from pending writes being in the ram when the power goes down.
                              i have worked with arcade equipment for decades,
                              windows based machines always have that filesystem mod and are always a longterm problem.
                              dos based machines are solid, the Linux based ones are also o.k. but the drives dont last so long because of the extra load
                              • LAGun
                                • Jan 2020
                                • 8
                                Re: Win XP Pro
                                If this is the case then why did the owners say that they should end up with icons and menu to start the software.
                                Now with that being said when trying to start it without the login info I see a splash screen with the Bingo co. logo and a menu in the bottom right corner to go to the Bios?
                                I have a feeling that the folks that brought me the machine did not give me all the info on the real use of it.
                                I also have the feeling that the governing software is proprietary to the machine. They have also said that they normally would have to send it back to the manufactures to get repaired.
                                • Hondaman
                                  • Sep 2008
                                  • 1089
                                  Re: Win XP Pro
                                  Make a backup, of course. i'm not sure how you can back up the boot loader though.
                                  Do you have another IDE port on the board? You can always remove the drive from the machine in order to back it up, correct?
                                  Is there a batch file or startup script that got deleted or corrupted? What is the file system on this drive (FAT/FAT16X/FAT32NTFS)? After you back up, perhaps would it be safe to search for stuff to undelete, to a safe place? And then look at what you have?
                                  I don't know how to copy each and every sector, including deleted files. I would have to run my undelete tools on the original drive, which is not good. Someone here will know a tool to copy each and every sector. Use that tool and look for deleted stuff on the COPY.
                                  • petehall347
                                    • Jan 2015
                                    • 4439
                                    Re: Win XP Pro
                                    sure i have copied a whole drive intact onto another .ran nautilus then copy pasted it all . was apple though so might be different with windows ,
                                    • R_J
                                      • Jun 2012
                                      • 9588
                                      Re: Win XP Pro
                                      It would be best to clone the hard drive, then play around with the clone, that way if you screw it up you can just clone it again and start over and the original is still intact the way they brought it to you. The clone will boot just like the original
                                        Re: Win XP Pro
                                        Originally posted by r_j
                                        it would be best to clone the hard drive, then play around with the clone, that way if you screw it up you can just clone it again and start over and the original is still intact the way they brought it to you. The clone will boot just like the original
                                        +1.
                                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • unimatrix93
                                          How to stabilize AC voltage to CNC machine
                                          by unimatrix93
                                          Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                                          I have a CNC machine wired to 3-phase 230V AC.
                                          It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                                          The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                                          I contacted the electricity company but they refuse to help me solve this problem.
                                          So I started to look around for some DIY...
                                          03-17-2025, 05:52 AM
                                        • xdever
                                          820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                                          by xdever
                                          I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                                          01-15-2025, 08:44 PM
