Win XP Pro
    master hoarder
    • May 2008
    • 12175
    Re: Win XP Pro
    Originally posted by R_J
    It would be best to clone the hard drive, then play around with the clone, that way if you screw it up you can just clone it again and start over and the original is still intact the way they brought it to you. The clone will boot just like the original
    +1
    That's how I would suggest to proceed as well.
    Then, on the cloned drive, diddle around and see if you can run a System Restore - preferably one that was fairly recent. If that doesn't work, try an older one until maybe you find a restore point that works... that is, if System Restore was enabled in the first place.
    I don't usually enable System Restore on my test PCs. But on my main PCs that do have the space, I do keep it enabled, as it's saved me a few times. Most recent one was the PC I'm typing this from - it decided to randomly corrupt the registry on the HDD after a normal power down. I thought I'd have to reinstall to get that PC running again. But 5 minutes later, using the "Last Known Good Configuration" from the F8 boot menu got everything running quickly again.
    • diif
      • Feb 2014
      • 6978
      • England
      Re: Win XP Pro
      I'd image the drive then scan it for bad sectors, errors and malware (perhaps it was internet connected or someone plugged in infected USB drive to play their tunes ?)
      It sounds like possibly the profile is damaged but it could be something else.
      https://support.microsoft.com/en-us/help/555473
        • 31200
        Re: Win XP Pro
        Originally posted by LAGun
        when trying to start it without the login info I see a splash screen with the Bingo co. logo and a menu in the bottom right corner to go to the Bios?
        that;s interesting, some megatouch quiz machines will do that if the settings in the bios dont match the expected profile for the game.
        is the date/time correct?
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Re: Win XP Pro
          Best to boot the original, keeping the clone as a copy to be used to restore the original -- in case the software has been "locked" to the drive ID (to discourage counterfeiters -- esp if the hardware is largely COTS).
            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-12-2024, 03:28 PM
          • CG2
            Janome DC3050 Sewing Machine Pedal Resistance
            by CG2
            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
            04-14-2023, 07:53 AM
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • unimatrix93
            How to stabilize AC voltage to CNC machine
            by unimatrix93
            Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
            I have a CNC machine wired to 3-phase 230V AC.
            It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
            The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
            I contacted the electricity company but they refuse to help me solve this problem.
            So I started to look around for some DIY...
            03-17-2025, 05:52 AM
          • xdever
            820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
            by xdever
            I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
            01-15-2025, 08:44 PM
