I am using a Toshiba portege a600 and installed a hard drive tray and hdd now the computer is giving me a cd rom error and is not recognizing the drive immediately but will pick it up in time until i shut down then I have to wait for it to recognize it again. Is there something I need to change in the bios
Replacing dvd with second hard drive
Re: Replacing dvd with second hard drive
My drive works fine once it gets recognized as long as I don't shut down the laptop which is weird? Windows 10 I thought support plug and playLast edited by davg; 10-16-2019, 05:35 AM.Comment
windows gets drive info from the bios.
interestingly Linux does not - i used to run an old motherboard with a 137gig drivesize limit,
i used a 40gig bootdrive amd serveral big drives for storage that the bios wouldnt see!!
maybe you can mod the bios - it depends on the version.
there are some editors floating around.
go ask on bios-mods.comComment
What is most puzzling about this is the fact that it do eventually recognize the drive but about 5 min after powering up which almost suggest that the bios recognizes it as a CD Rom on POST and Windows recognize it as a drive once up and running. I tried this same setup in a Acer Laptop and that worked without an issue at all no need to change any settings bios or otherwise??Comment
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by tmcwA friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
Now, the case is a CiT Gaming Case, and...-
by madura2010Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
i checked the connectivity of ribbon=good communication with hard and motherboard
changed hard disk and checked=3f0 error persist
sata power=+5v available
Then checked data capacitors=all good
Then checked data lines path connectivity to pch=all good
reflashed... -
by ash91Hello gentelmen .... this is my first post and sorry for my bad english,
so my proplem is my laptop keep losing hard drive even if i but the
hard disk in the cady (the box that can replace the dvd rom with hard disk)
when i turn the laptop on the massage that said no boot media found pop on
the hard disk is fine and to be sure i try another hard
i also update my bios to the last update
the 5 volt is present on the hard connector on the motherboard
the dvd rom work fine when i but a windows dvd in it
also when i boot from flash... -
i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...-
- Loading...
