Replacing dvd with second hard drive
  • davg
    • Sep 2008
    • 536
    I am using a Toshiba portege a600 and installed a hard drive tray and hdd now the computer is giving me a cd rom error and is not recognizing the drive immediately but will pick it up in time until i shut down then I have to wait for it to recognize it again. Is there something I need to change in the bios
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Replacing dvd with second hard drive
    It sounds like it.
    • davg
      • Sep 2008
      • 536
      Originally posted by diif
      It sounds like it.
      Any help on what? I did check the bios but don't see anything there related to the Rom other than in the boot priority and that is set to boot from HDD
      • diif
        • Feb 2014
        • 6978
        • England
        SATA settings ?
        • davg
          • Sep 2008
          • 536
          SATA settings ?
          Nowhere in the bios settings to make changes to sata
          • petehall347
            • Jan 2015
            • 4439
            • United Kingdom
            did you set it to slave ?
              • 31201
              toshiba bioses are fucked, a lot of stuff is hidden or hard-coded.
              i have had drive problems on several of them because of fixed ide settings
              • davg
                • Sep 2008
                • 536
                this seems to be the case here not many options to make changes in the bios so was there a solution?
                My drive works fine once it gets recognized as long as I don't shut down the laptop which is weird? Windows 10 I thought support plug and play
                  • 31201
                  windows gets drive info from the bios.
                  interestingly Linux does not - i used to run an old motherboard with a 137gig drivesize limit,
                  i used a 40gig bootdrive amd serveral big drives for storage that the bios wouldnt see!!
                  maybe you can mod the bios - it depends on the version.
                  there are some editors floating around.
                  go ask on bios-mods.com
                  • davg
                    • Sep 2008
                    • 536
                    What is most puzzling about this is the fact that it do eventually recognize the drive but about 5 min after powering up which almost suggest that the bios recognizes it as a CD Rom on POST and Windows recognize it as a drive once up and running. I tried this same setup in a Acer Laptop and that worked without an issue at all no need to change any settings bios or otherwise??
                      • 31201
                      it's possible the drive is being picked up by a background task like smart checking.
                      • federalhouse
                        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                        by federalhouse
                        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                        **Background:**
                        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                        **What I've Tried So Far:**
                        1. I accessed
                        08-01-2024, 07:03 PM
                      • tmcw
                        PC case - Hard drive rails
                        by tmcw
                        A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                        So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                        I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                        Now, the case is a CiT Gaming Case, and...
                        05-22-2022, 12:04 PM
                      • madura2010
                        DAY11AM6E0 hard disk drive and optical disk drive not detected
                        by madura2010
                        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                        i checked the connectivity of ribbon=good communication with hard and motherboard
                        changed hard disk and checked=3f0 error persist
                        sata power=+5v available
                        Then checked data capacitors=all good
                        Then checked data lines path connectivity to pch=all good
                        reflashed...
                        03-12-2023, 09:09 AM
                      • ash91
                        Hp pavilion 15 not detect hard drive
                        by ash91
                        Hello gentelmen .... this is my first post and sorry for my bad english,
                        so my proplem is my laptop keep losing hard drive even if i but the
                        hard disk in the cady (the box that can replace the dvd rom with hard disk)
                        when i turn the laptop on the massage that said no boot media found pop on
                        the hard disk is fine and to be sure i try another hard
                        i also update my bios to the last update
                        the 5 volt is present on the hard connector on the motherboard
                        the dvd rom work fine when i but a windows dvd in it
                        also when i boot from flash...
                        06-07-2023, 01:45 PM
                      • karto95
                        Repairing a Seagate hard drive with damaged logic board
                        by karto95
                        I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                        I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                        If anyone has any suggestions or experience with this...
                        03-21-2023, 04:05 AM
