best cheap/free scores 1.1
This is a sticky topic.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    #4341
    Re: best cheap/free scores 1.1
    Scored more free stuff:
    - HP DV7-1080ES - no CPU, RAM, HSF and HDD, but the rest of the laptop is full. Got 4GB of DDR2 and T6600 for it.
    - HP DV6-2125SO - Turion II, 4GB DDR2, 500GB Seagate Momentus 7200 (!) - didn't POST at first. Reflowed both HD4530 and the separate IGP chipset, and it works. Replaced the cracked panel, and so far it works fine.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      #4342
      My latest score... Radeon HD4670 PCI-E for $5 to my door. I really like these older mid-range low-power PCI-E video cards from AMD. They have enough power for some older games and don't need any extra power connections. Also, HD3k and newer have audio over HDMI and DVI-D with DVI-D to HDMI adapter - good for driving a TV!
      Originally posted by Topcat
      We have one of those on this forum....but I won't mention names.
      Yes, it's me.
      IDK, RD, I think he could have meant that comment for me as well.
      I still haven't put that SM board TC sent me to good use. Feed bad when I think about it. I will build a PC with it... eventually, though.
      Some years ago, member Pentium4 here sent me 2 motherboards that he / the place where he worked were getting rid of. One was an Intel with a blown MOSFET that it took me a long time to fix (and I still don't know if I have done it properly, but it was a fun repair I leaned a lot from.) The other is an ASUS motherboard that I fully recapped and then put on the shelf for 2-3 years. Felt bad about not using that one too... but then my parents' PC needed an upgrade a few years back, and so I built a new PC for them with that. It's been in service ever since and still is. Now I'm considering to upgrade my parents' PC to something better and take that one in my next "main" PC.
      The SM from TC is pretty awesome, to say the least... and that's why I don't know if I want to build a retro gaming PC with it or a "main" PC.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        The difference is that Voodoo3 he's got is new in box in shrinkwrap....which is just absolute blasphemy that such a beautiful piece of tech goes unused. I will hound him till he sells it to me or uses it in one of his rigs....all I care about is this card being used & enjoyed!
        As for that old X5DAL, it got abused good when I had it....so take your time....I have faith you'll abuse it some more!
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          ...meanwhile, I have two of them (X5DAL) sitting. Although I did power up big mama (Main Rig V2.x)... and after having to go through the "pull half the RAM and re-enter all the BIOS settings" game I have to do half the time (both boards do it even on good batteries), it fired right up. Didn't run it long though because historically it keeps corrupting the windows install; I should probably look into USB imaging it so the next time it pukes its guts, I can just dump an image.
          Still works well for web surfing... but even as maxed out as it is (newest AGP card ever made, fastest CPUs that will run, and maxed out with 8GB of DDR2), I don't know how long that will hold. As for the other one (which has slightly slower CPUs and a less agressive GPU), haven't powered it up in over a year... never had a reason to. Maybe one of these days...
          Due to the quirks (at least from my experience), they're better suited these days for retro use. I ran one as a main system, and while it did run well at times, I've found newer SM boards to be less fickle and picky.
          It's a meh PCI Voodoo 2000... not a cream of the crop voodoo 3!
          sigpic
          (Insert witty quote here)
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            It's the best voodoo3 I could possibly get for my P-Pro build though (dual socket 8 w/ 2x overdrive 333's in it). No AGP p-pro board was ever made, and the Voodoo3 2000 was the highest PCI they made. Everything thereafter was AGP. Ironic, I thought that card was AGP all the while until your last visit here when you told me it was PCI....but I've still got a build for it.
            Team : 49813
            Join in!!
            Team Stats
            • BigTroll
              • Sep 2010
              • 1317
              • LAMBDA SOND
              #4346
              You can pass it on to your future kid one days and do a father/son/daughter retro build with it.
              My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                • Romania
                #4347
                More epic free scores!
                - Gigabyte GA-B75M-D3H + Intel Core i5-3470 3.2GHz @ 3.60GHz + EKL-AG cooler
                - Hoco E36 BT headphone
                - ADATA SU650 120GB SATA3 6.0GB/s SSD
                - Gigabyte Geforce GTX650 OC 1GB GDDR5
                - Arctic MX4 Thermal Compound
                Coming next month : Note 4 N910F, full box!
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  See how easy it was to remove that shrinkwrap and let the beauty out of the box??
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5045
                    • US
                    #4349
                    I have a working Voodoo 5 5500 in storage
                    • BigTroll
                      • Sep 2010
                      • 1317
                      • LAMBDA SOND
                      #4350
                      beautiful card topcat! did it have any special voodoo smell to it?
                      • BigTroll
                        • Sep 2010
                        • 1317
                        • LAMBDA SOND
                        #4351
                        damn now thats a sweet card.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16959
                          I've got one as well, its not rotting in storage, it's in a system. If you want to part with yours since it's not in use, let me know.
                          As a matter of fact it did. That new packaged/air tight electronics smell.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5045
                            • US
                            #4353
                            I might recap it (from age, no bloated caps). Sell it. I mean, have you seen the prices on ebay of those cards used?
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16959
                              ~$350 give or take....which is retarded....but supply & demand, the American way I suppose. Something tells me I could come up with some tradebait and/or I'd get a better deal.... If you don't want to sell it, no harm no foul....but for the love of humanity and old games, put it back to use!
                              Team : 49813
                              Join in!!
                              Team Stats
                              • dmill89
                                • Dec 2011
                                • 2534
                                Yep, and sadly I remember tossing a bunch of them in the mid 2000s after 3dfx went belly up and they were basically worthless due to lack of updated drivers. If only I knew what they would be worth one day. That was likely the fate of many of these cards (and they never sold in the numbers many of the nVidia and Ati cards did to begin with) leading to the tight supply and ridiculous prices now that "retro" systems have gained popularity.
                                • Hondaman
                                  • Sep 2008
                                  • 1090
                                  Tonight, I got a Polaroid TDA-03211C from someone's trash (garbage collection in much/most/all of USA won't take electronics). 32 inch LCD TV, 16 by 9 aspect ratio, 720P, ATSC tuner, 2 HDMI ports, one 15-pin VGA port and lots of RCA jacks, and a built-in DVD player. Just as I was getting out of my car and putting it into my trunk (boot), another neighborhood junk collector pulled up in his truck. I think he saw it as well, and he was going to take it right then. I was going to wait until after dinner at a restaurant to get it, but I'm glad I decided to turn the car around and grab it immediately, or it would have been gone!
                                  "Polaroid", of course, is just a name that can be licensed. You don't know who actually made this generic unit. But it was free, and it might be an easy fix. Everyone here always gets such wonderful "free scores", and I never seem to get any good stuff. Well, this time, I got something nice. We'll see if it is an easy fix.
                                  There was strong rain in my area today, so I'm going to have to let it dry out for some time (I'm quite busy right now, so this is not a problem). I will put further updates on the repairs in the appropriate section here at badcaps (some will be needed, trust me).
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5045
                                    • US
                                    #4357
                                    Tribes is about the only game i've ever played with GLide support. It's not really that great a technology, but at the time it did beat gl/d3d because everyone thought glide/3dfx would be the future. I still remember the commercial from ~1995, at the time not knowing what 3dfx really was, as my family was lower-middle class and I didn't have anything above a 386
                                    https://www.youtube.com/watch?v=ooLO2xeyJZA
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      About 5 years ago I curbsided a nearly identical (identical?) unit. About the same size, 720P polaroid with two HDMI's and a DVD player. Bad panel cables (lines on screen), so it's still a boat anchor in my parents basement. If you want a 2nd unit for parts, it's yours.
                                      sigpic
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16959
                                        Just keep me in mind if you decide to part with it....I do have a befitting build in my 'keeper pile' that could benefit from a 5500. A very period-specific Tualatin build.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Uranium-235
                                          Comrade Glimmer
                                          • Aug 2007
                                          • 5045
                                          • US
                                          #4360
                                          I might actually do something similar. I have a 1u server with dual TT 1.4's and somewhere I have an ATX motherboard with dual 370 sockets. Probably put win2k on it
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
