best cheap/free scores 1.1
This is a sticky topic.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #3721
    Re: best cheap/free scores 1.1
    Oh, and don't forget about that Antec PSU
    Originally posted by Topcat
    I got around to it today. It was loaded with capxon and fukkyou caps. None bloated, but all way out of tolerance.
    <snip>
    Just a refresher, this was something Ratdude picked up at the goodwill store.
    Awesomesauce!
    • Dan81
      SNES-powered
      • Oct 2013
      • 1865
      • Romania
      #3722
      Been looking for parts for a i3 build.
      So far, I did some replacements to the i3 540 combo - I replaced the MOSFETs with P70N02LDG (original burnt ones were NTD4906).
      While at it, I've found three Samsung drives - a 320GB, a 500GB one, a 160GB one, and a 80GB one.
      For the PSU - I'm currently doing a Franken-PSU - it consists of a CWT ISO PCB using a Yate Loon fan, all thrown together in a Frontier DR-8460BTX casing. Also added a fan controller from a scrapped 315W FSP.
      More pictures coming in a separate thread.
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        • Romania
        #3723
        Scored a Winfast K8M890M2MA-RS2H mobo w/ Sempron 3000+ AM2 and about 768MB of RAM (1x256 and 1x512 DDR2 sticks).
        Posts fine, but the VRM low caps are probably kaput (Samyoung NXC - aren't these crappier than KZG/KZJ?) as they get fiery hot, something that shouldn't even happen with a Sempron 3000+.
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          #3724
          I’d say they’re equally bad, but the lower voltage parts on the VRM output (2200uF 6.3V, 1500uF 6.3V, and 3300uF 6.3V, etc) or those scattered amongst the board (1000uF 6.3V in NXC’s case and 820uF 6.3V in the case of KZG) seem to be at a greater risk of failure than the higher voltage parts (1500uF 16V, 1000uF 16V, 1800uF 16V, etc). The higher voltage parts seem to do better so long as they’re not under thermal duress.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            • Romania
            #3725
            Originally posted by Wester547
            I'd say they're equally bad, but the lower voltage parts on the VRM output (2200uF 6.3V, 1500uF 6.3V, and 3300uF 6.3V, etc) or those scattered amongst the board (1000uF 6.3V in NXC's case and 820uF 6.3V in the case of KZG) seem to be at a greater risk of failure than the higher voltage parts (1500uF 16V, 1000uF 16V, 1800uF 16V, etc). The higher voltage parts seem to do better so long as they're not under thermal duress.
            They're the only NXC on that board. Rest is OST RLX for the 1000uF and Rubycon amBZ for the VRM high.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16955
              Today's freebie was a custom-built P4 system @ 3.8GHz (Pentium 670), 2gb RAM, NVS 280 GPU, 80GB HDD on an Intel D915GAG in a mint condition beige mATX case. I coulnt seem to figure out who made the case, but its built like a tank. Heavy gauge steel, no sharp edges, very nicely made. System works. It was a controller for a plotter from the county recorders office. The plotter died and they bought a new one.... Whoever did the plotter replacement took the old plotter, but left this PC....so the called me to come get it.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                #3727
                16 pieces of 8G PC3-10600 ECC. And, 14 2T SAS drives.
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3264
                  • Singapore
                  #3728
                  wow thats nice. pretty astonishing the fastest and also the hottest single core p4 chip ever made is still working on the board its installed on. i guess intel must have used good caps on their boards. what caps are on the intel d915gag board anyway? must be really good jap caps to last 15 years!
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1865
                    • Romania
                    #3729
                    Recapped the Winfast K8M890M2MA-RS2H board today. Replaced the Samyoung NXC 3300uF 6.3v caps it had with Rubycon MBZ pulls. VRM section is cold, board POSTs fine as opposed to when it had the Samyoung caps.
                    Works fine, and is pretty fast in my experience.
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16955
                      They're Nichicon HM and Rubycon MBZ. They could probably stand to be replaced, although they visibly appear ok.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ChaosLegionnaire
                        HC Overclocker
                        • Jul 2012
                        • 3264
                        • Singapore
                        #3731
                        thats an interesting dilemma then. because if the hm have the faulty datecodes which im sure u know so i wont repeat them, then they should probably be replaced if the system is to be put back into service.
                        but on the other hand, if the hm can survive 15 years being cooked by a 115w tdp cpu, then its probably fine and they arent affected by the issue. if they were affected, they'd probably have failed within a few years and wouldnt have lasted 15 years, so interesting dilemma then like i said...
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16955
                          The datecodes are all 2005. The only reason I think they're still alive is that the system probably wasn't used all that much. This post was created from it.
                          Team : 49813
                          Join in!!
                          Team Stats
                            master hoarder
                            • May 2008
                            • 12164
                            • Bulgaria
                            #3733
                            I have plenty of boards with 15+ year old caps that are fine.
                            It's down to the brand, but also a bit of luck.
                            Japanese caps typically have no problems making it that long at all (granted they are not some of the affected/known bad series.)
                            The CN/TW brands can make it to 15+ years, but that's the "with a bit of luck" part - some of them will be fine, some will not. Still have a Pentium III motherboard with original OST RLX caps (for CPU VRM) and Choyo (25V 330 uF GP caps scattered on the board) - all good to this day. That board puts no stress on these caps, though, so probably that's why.
                            Any board with a Pentium 4 I find tends to bake those cheaper cap brands over time (especially in a case with poor ventilation). So I suppose the load matters too.
                            Probably still quite fine.
                            Though IMO, any Nichicon HM/HN/HZ caps with 2005 datecode and 6.3V rating can be iffy. Not sure about the 10V caps, but the 16V ones rarely give problems (have plenty of socket 939 mobos with those.)
                            Thanks for posting this.
                            I have a Jetway mobo with those Sanyoung caps and a low-power X2 4800+ CPU. Been wondering whether or not to recap it, seeing that it hasn't generally had any problems. But probably I will now. It's a socket AM2 mobo with a through-hole socket! Haven't seen many of those, really.
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1865
                              • Romania
                              #3734
                              Got a free Western Digital WD1001FALS Black 1TB (Mac) that doesn't spin up - first inspection shows no burnt components other than a chipped capacitor which I might replace.
                              Also got a 2GB DDR3-1333 Apacer stick - in reality it might be OEM'd by Crucial - I have noticed that it looks awfully similar to a 2GB Crucial stick I have. I installed the heat shielding on the Apacer stick from a dead Mushkin 2GB stick that uses the same PCB.
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                                • 30937
                                sounds familiar - do a search for the last 2 months of posts with "mac" in them.
                                i suspect the firmware is waiting for a command before spinning up the drive.
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1865
                                  • Romania
                                  #3736
                                  Nothing is heating up on the PCB.
                                  Using a PCB from a WD1600AVJS will spin the drive up but will click like it's dead because of the different families both drives come from.
                                  At least I know the drive IS good, and the PCB may be dud.
                                  What would be harder is tracing down a replacement PCB, as the model I found isn't really easy to find on the market.
                                  BTW, the drive is dated 19th April 2010, so it's before Apple started locking their drives.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    heads stuck to platter?
                                    sigpic
                                    (Insert witty quote here)
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1865
                                      • Romania
                                      #3738
                                      Drive will spin with another PCB from a WD1600AVJS, so it's not that.
                                      It will click with that one though because of mismatched chipsets (both are Marvell, but one is much older than the 1TB) and amount of cache (8MB on the 160GB drive and 32MB on the 1TB drive), not to mention the AVJS is a 2008 drive while the 1TB is a 2010 drive.
                                      I will try finding a donor PCB and finally see if it's worth something. It's a Mac drive after all, I wouldn't be the slightest surprised if the drive would work fine with a PCB swap and even go as far as getting recognized by Windows.
                                      Being a freebie, I won't lose much.
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      16GB DDR3-1600
                                      Delux MG760 case
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #3739
                                        That drive supports PUIS, make sure it's not enabled:
                                        http://wdc.custhelp.com/app/answers/detail/a_id/958
                                        http://wdc.custhelp.com/app/answers/detail/a_id/5330
                                        P.S: Board swaps almost never work on modern drives, drive specific data is stored in an eeprom on the PCB.
                                        • goontron
                                          5000!
                                          • Dec 2011
                                          • 4108
                                          • US
                                          #3740
                                          But swapping EEPROMS is easy. Especially on high capacity WD. My 4tb drive uses an 8pin EEPROM.
                                          Follow the white rabbit.
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • eccerr0r
                                            Caseless Cheap Chinese electronic tools
                                            by eccerr0r
                                            "Caseless Cheap Chinese electronic tools" I mean things you get from banggood, ali, fleabay, Am-Zon, etc. like AVR-Transistortester, miscellaneous signal generators, frequency counters, (variable) power supplies, oscilloscopes, low resistance meters, etc., etc. that comes optionally with a case, or comes only with a cheap piece of plastic that barely provides protection to the PCB.
                                            Just wondering what of these (generally flimsy) tools you actually find use (almost) everyday and find indispensable for the price, compared to buying a Fluke or whatnot, if there is an expensive...
                                            11-23-2021, 03:44 PM
