best cheap/free scores 1.1
This is a sticky topic.
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    #3781
    Re: best cheap/free scores 1.1
    4 10' two-headed 16AWG power cords (for my SANs)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Originally posted by Topcat
      I was given (took in trade, sold client a newer/faster one) a mint condition Inspiron 1300 laptop with charger & Dell case. Has a single core celeron @ 1.5GHz and 512mb RAM in it. I got the max CPU (Pentium-M 780) @ 2.26GHz and 2gb RAM for it for $20, which is probably about all the system is worth....but given its pristine condition, batt is good, and it works...what the hell.
      This post created from this laptop. Maxed out CPU (Pentium-M 780 @ 2.26) and memory (2gb), and actually runs Win7 ok....not great, but ok. The biggest hangup is the 915G GPU, while I found a driver that will work (no official support past Vista, and that was sketchy to say the least), it just doesn't have the stones for Aero....even getting it to work was tricky....so I just set it up with the stellar XP-look.....and here we are from FF56.0.2.
      The one thing this one had over most laptops, CPU swap was all of 6 screws. Two that held the cover plate on, and four to remove the heatsink.....they should all be that easy!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        My latitude E6430 is four screws... as is my Asus X83V. Not common but such designs did continue to exist.
        sigpic
        (Insert witty quote here)
        • LLLlllou
          • May 2011
          • 201
          Originally posted by momaka
          I think the VooDoo3 graphics card is very likely FUBAR. What I thought was a small scratch on one of the RAM chips is actually a crack, I think. The way I checked: I used a screw driver to scratch the RAM chip in a direction perpendicular to the scratch, and I kept "feeling" the scratch no matter how deeper I went. If that's the case... only remedy would be to find some old SDRAM sticks with 16 Mbit chips... which I have NONE at all. Might put a post up in the "looking to buy" forum when I get to it and confirm if that RAM chips is bad or not. If it is, it's going to be a RAM chip replacement job + who knows what else. But for a VooDoo3 card, I think it's worthwhile.
          Got any old 40GB Maxtors laying around? Looks like they use the same Micron RAM.
          https://forums.tomshardware.com/thre...stance.674440/
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            #3785
            Got a free 486 motherboard I can't for the life of me identify (UMC UM8498F, 4x ISA, 3x VLB, 72pin SIMM) with removed cache slots (I think I have some old boards I could remove the sockets from ) and a Gigabyte H61M-S1 that appears to be dirty to all hell, and may be dead as well.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
              • 31185
              id your board here:
              https://stason.org/TULARC/pc/motherboards/
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                #3787
                It's a AEI/Chicony TK-8498F.
                I managed to get some beeps this morning, although nothing much than that. They're unusual for AMI BIOS - they're low in tone, while AMI BIOS uses a higher tone.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                  • 31185
                  touch the cache chips, often bad ram gets very hot.
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3264
                    • Singapore
                    #3789
                    could be bad caps there! i know bad caps can change the tone of the audio on amplifier and speaker systems! same thing could happen to mobo speakers...
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      #3790
                      Cache chips stay quite cold, and I've already replaced the caps (three caps lol, one 1000uF 10v and two 220uF 10v)
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                        • 31185
                        have you got a frequency counter or multimeter that can read upto the speed of the crystals?
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          #3792
                          A pair of MD3200i's. I can fill them with 300G 15K drives (i.e., ~7TB) and use them to host the "working" copies of my VMDKs (so I can put them in a different room from the ESXi servers!)
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1866
                            #3793
                            Scored a PSP model 1004 (phat) for $7. Case is quite cracked, battery for some reason won't charge on it (works on a 3004 I have tho) but otherwise it works fine. I removed the UMD drive since I don't need it (I have a 1GB MS Pro Duo stick) and cleaned the LCD.
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                              • 31185
                              is the charging socket good?
                              i had one that wouldnt charge - the center pin was missing!!
                              • Dan81
                                SNES-powered
                                • Oct 2013
                                • 1866
                                #3795
                                Yeah, it's good. Apparently the charging circuit didn't like the battery at first as the cells weren't active. Placing it into another PSP (a 3004) I have must've reactivated the cells as after letting it charge up until 50% I could then charge it using the 1004.
                                The only thing left that irks me is the wifi switch, but that may be also because of the pretty beaten up casing it has (gotta order a new one sometime)
                                Main rig:
                                Gigabyte B75M-D3H
                                16GB DDR3-1600
                                Delux MG760 case
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  #3796
                                  6 mini-SAS cables -- but, they're only 2m. I guess I'll have to keep looking...
                                  And, 15 2T, 6Gb, Dell-branded SAS drives (so, that fills another SAN shelf with a few spares)
                                  • Dan81
                                    SNES-powered
                                    • Oct 2013
                                    • 1866
                                    #3797
                                    Free ASUS P5QD Turbo - P45 chipset, J-Micron 361 + Sillicon Image SIL5723.
                                    Looks nice, was just dusty. Has EPS12V connector, a jumper named OV_CPU (which I can either describe as overclock), heatsinks for the MOSFETs.
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    16GB DDR3-1600
                                    Delux MG760 case
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      Cheap rummage sale find....I'm normally not a yard sale guy....but when driving by and I spot this:
                                      Yea, I stop!! It lights up and appears to work. I haven't fed it a signal yet though. It's all there and intact. One knob missing.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • TechGeek
                                        Computer Geek
                                        • Jan 2015
                                        • 2254
                                        Philco Predicta. Those are PITA's to service.
                                        Permanently Retired Systems:
                                        Kooky and Kool Systems
                                        sigpic
                                          • 31185
                                          that thing looks awsome - you could probably lease it to film production company's!!
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
