best cheap/free scores 1.1
This is a sticky topic.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: best cheap/free scores 1.1
    HP Pavilion 500 (with failing 2TB Seagate) along with some Saitek flight sim gear. Blew out the password on the Winh8 install and confirmed that everything worked.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Originally posted by Topcat
      so what better than Mint!
      Until you need to do a right click
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Yea, I noticed that....... Any fix for it? When working with laptops on the bench, I alwyas plug a mouse in.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • dragos2009
          • Mar 2013
          • 110
          #5004
          Today's freebie was a Macbook 13" (model MC516LL/A). It's a C2D @ 2.4GHz, 2gb RAM and a bad 250gb hitachi HDD.
          I tossed 8gb (2x 4gb DDR3 modules) and a SSD in it. Even though it came with the original install disks, I don't really care for OSX....so what better than Mint! I've read any UEFI boot version of Windows (Win8 and newer) can also be installed on this....but I didn't try.
          Box & goodies....
          ...and up & running!!
          This post of course created from it....not sure what I'll do with this...it's not worth much....but it was fun to tinker with for a couple hours!
          you can install windows 7 64 bit on it aswell did it on one and it works wonderful, hella fast too
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            I couldn't get it to boot from the USB media, no UEFI. Might try using a DVD...just for grins.
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              You need to make it a GPT formatted stick, not MBR. Using Rufus to make the USB media, right?
              Same thing for later versions of windows... GPT sticks for UEFI installs, MBR sticks for "legacy" installs. No universal solution other than wipe and reformat the stick.
              sigpic
              (Insert witty quote here)
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Yessir, well aware...and that would do it....but as usual, shortages of USB sticks around here. I just booted off the optical media though. S2K12 R2 also runs on it. The only things I couldn't get to work were the isight thingy and the bluetooth.....two things I could care less about....and then of course the touchpad doesn't work right either in windows or mint.
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  (Semi off-topic rant on how worthless my laptops are and how expensive the "old" ones I wish I had are)
                  And after all of that, it's still probably worth more than any laptop I own... To think at one point I was going to get a 2013 gold macbook pro 15" (retina display) when "the used prices were in budget" and triple boot it to make the ultimate (for ratdude) ultrabook. LOL, WTF was I smoking... Silver ones are (finally!) down to $250 and up for one with a good display (but a broken hinge!)... I doubt a single one of my personal laptops is worth more than $150, the most valuable being my venerable Dell Latitude E6430 with a low voltage quad i7. Heck, some of these macbook pro's have lesser CPUs than that! (both are ivy bridge, FWIW).
                  Any more, the laptop on my "would like to get if I could get a good price" would be a Dell Precision M6800 with a 1080 screen... used one at work for a bit (Boss's hand-me-down "floor use" laptop, I legitimately liked working with it), but even now they're still $300+ in partially parted beat to hell shape (and the best 1080 I found is $360, and that's with no HDD/caddy or battery cover!). Apparently old Precisions hold value like macbooks apparently!
                  sigpic
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    Any fix for it?
                    https://www.cnet.com/tech/computing/...-mac-trackpad/
                    I mustn't have read past the first two methods from that link
                    Real PITA using two fingers, I'll have to check out their alternatives
                      • 31190
                      just use a $ store optical mouse.
                      i have one in every laptop bag - i cant stand touchpads
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        LED tester came in, yup, backlights toast. At least it's a cheap (enough) repair, although a bit tedious. Will go to my parents if it works out (better fit for their usage than mine).
                        LEDs came in on Saturday... repaired it yesterday and set it up at my parents' house, worked great!
                        Did a quick test at home before trucking it out:
                        ...sadly the Iris4000 GPU in my Ivy Bridge i7 can't do 4K, so that was on 1080... compared to the 480i CRT it replaced, real 4K or not it's a massive upgrade for them! Not bad for $60 in LEDs and a $5 remote.
                        sigpic
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          Good save!!
                          Team : 49813
                          Join in!!
                          Team Stats
                          • brethin
                            • Dec 2008
                            • 1907
                            Bought 2 Onn 4k devices from Walmart, they are damn good for $29 each, the remotes are kickass.��
                            • grss1982
                              • Mar 2007
                              • 225
                              • Philippines
                              #5014
                              Was just browsing YouTube and the algorithm just recommended this video:https://www.youtube.com/watch?v=iR6XFDAfLuk
                              Instantly reminded me of this thread. Still blows my mind this is a thing in U.S. Dumpster diving here in my part of the world is not going to net me the same stuff. LOL
                              CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
                              GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
                              Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                Back to this macbook...It came with OSX 10.6.3....through some experimenting, I got it to upgrade to 10.10.5, I wanted to see how well Waterfox would run on OSX. Mozilla always seems a bit wonky under Mint/Ubuntu....but I have to say, it's very nice on OSX; running Waterfox G3.2.4.1
                                Team : 49813
                                Join in!!
                                Team Stats
                                • BigTroll
                                  • Sep 2010
                                  • 1317
                                  • LAMBDA SOND
                                  #5016
                                  Nice glad you went back to OSX and I have always ran waterfox on my older macs with ublock origin and had great performance, whats so funny is recently last night I just fixed my A1342 unibody like yours. I let mine sit over a year because the battery stopped holding a charge, then 2 weeks ago I went to plug it in and the battery immediately bloated moving the trackpad up etc luckily i got it out before it deformed the case permanately and last night I just put in a new battery.
                                  The 320m is a awesome integrated gpu, you can go up to 10.13.9 high sierra on your mac if you want. glad you finally made the switch to a real computer.
                                  My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    I kicked it up to 10.12, the highest it can go without an apple account. It runs really nice actually. I brought it home today to tinker with it over the weekend....as a matter of fact, this post spawned from it!
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • BigTroll
                                      • Sep 2010
                                      • 1317
                                      • LAMBDA SOND
                                      #5018
                                      Nice! there is a cool program you can download called coconut battery, it will tell you the cycle count and health of your battery
                                        • 31190
                                        apple account??
                                        you mean it uses cloud login?
                                        if you do then fuck apple!!!
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16958
                                          Originally posted by stj
                                          apple account??
                                          Yep, pretty much. I could download the DMG files for upgrades through 10.12. Any higher, they want you to download it through their 'app store'; which of course requires an account.
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
