best cheap/free scores 1.1
This is a sticky topic.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    #3061
    Re: best cheap/free scores 1.1
    Update :
    Everything went smooth , except two technical problems :
    1 - The 4TB showed 1.6 TB in win 10 , so i had to run disk management , delete volume and convert MBR to GPT . Easily done , and now it shows 3.6 TB . Whom to blame ? .. The Martians of course ..
    2 - Yep , rumors were true , and Nvidia , starting the 1070 gt and up had cut anything called analogue . No one single adapter x to VGA could show high resolutions and any screens went off , immediately when installing the Nvidia driver .
    A small 40 cm HDMI to HDMI Cable solved the problem ..
    Whom to blame ? ..The Martians !! .. Yes ..
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      ^Yes they do have a BBU option... I used to run them, and I still have a couple 9500s-4LP's with BBUs somewhere (minus the batteries themselves, they were stolen to fix 9550's). Want them?
      Note that if these were dell OEM ones, the header for the BBU is probably missing, but the correct SMD pin header can be purchased from digikey and soldered on (as is one of mine, no issues)
      These do have the BBU connector on it, I finally remembered to check. I'll take the BBU's or the controllers if you have no other use for them. Lab ratting one in a BP6 test system.....the pci2.2 compliance thing.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        #3063
        Bought this for $26.43. Jetway J-7BXAN, 256MB RAM, P3 450MHz.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          #3064
          Originally posted by jiroy
          Update :
          MBR does not support more than 2.1TB
          https://www.badcaps.net/forum/showthread.php?t=39133
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            #3065
            Who needs partition tables? Just format the disk with your FS of choice and send it..
            Follow the white rabbit.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              Very nice!! Hardware of this era (Pentium classic through Pentium III) is my absolute favorite!
              Team : 49813
              Join in!!
              Team Stats
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                #3067
                Gifted a little Dell i7 laptop. My first (accidental!) exposure to W10.
                Yikes! What a pig! Is there some reason why folks would CHOOSE such an OS (besides lack of driver support for older/other OSs)?
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  #3068
                  ^ thats what ive been wondering. And wholy shit is it fragile! You look at it the wrong way and it breaks.
                  • brethin
                    • Dec 2008
                    • 1907
                    My Dell Presision 4300's run Winbows 10 just fine with 0 driver issues and they are fully maxed out hardware wise.
                      • 31285
                      today it works, tomorrow it could be different.
                      welcome to enforced updates!
                        master hoarder
                        • May 2008
                        • 12175
                        #3071
                        Yup.
                        Enjoy your KB4100347 update (and who knows what else is there to come).
                        Meanwhile, I'll continue to use my unsupported and "compromised" XP PCs. Maybe some of my Windows 7 rigs too, in the worst case.
                          • 31285
                          https://www.youtube.com/watch?v=VMPeTrHNX1U
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8710
                            The problem is that KB4100347 is a software workaround to a hardware problem, running on XP on a machine with the problem ... still has the problem.
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              #3074
                              ^ At least it would be bootable..... My new P52 is a brick on 10 because of that update.
                              • Curious.George
                                • Nov 2011
                                • 2305
                                • Unknown
                                #3075
                                Exactly. I want stability. I can LIVE with most bugs -- once I've found them and established workarounds.
                                I can't live with a system that morphs in ways that I can't control or even document -- at someone else's whims!
                                Imagine heading out to your vehicle in the morning -- only to discover the steering wheel has been replaced by a joystick, the seat faces BACKWARDS, you view the roadway through a MIRROR and the vehicle runs on ammonia (SOON to be available in your neighborhood!!)!
                                And, some bozo has a reason to justify all of these changes (though that may not be shared with you -- you should just trust to his better knowledge).
                                But, he won't guarantee that he hasn't BROKEN something (else) in the process. That's left as an exercise for the user (you!).
                                Meanwhile, the folks that you've made contractual commitments to aren't going to "adjust deadlines" or pay rates to accommodate the uncertainty injected into YOUR work tasks.
                                Yeah. Right. Where do I sign??!
                                All of the software that I run (OSs and apps) is older releases that have seen their "last updates". I.e., "this is as good as it gets". No need to worry that a new update NEXT week will change things in ways that you will have to discover (likely when you can least afford the distraction). Buy a license, put it on the shelf and wait for them to "finish" developing the product. THEN, install it.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16959
                                  Originally posted by momaka
                                  Yup.
                                  I've phased out most of my XP stuff....but Win7 and S2K12 stuff will be around a long time, long after they go EoL.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • Dan81
                                    SNES-powered
                                    • Oct 2013
                                    • 1866
                                    #3077
                                    Got more free stuff:
                                    ASRock 775i65G w/ Celeron 320 and 512MB RAM
                                    generic FX5500 128MB card (came free with the ASRock)
                                    C-Media CMI8738SX PCI sound card (also free with the ASRock, went into a C2D machine I have)
                                    Maxtor 83240D3 3.2GB - probably the OLDEST drive in this lot
                                    Western Digital WD800JB-00FMA0 - has some pretty old gems on it, should get around copying it some time
                                    Seagate ST3200822A 200GB - died during a MHDD test
                                    TP-Link TL-WR841N Wireless-N router - quite a nice upgrade over the old Tenda W306R router I had.
                                    That's about all. I might replace the Celeron 320 "housefire" (it's a Prescott) with a Celeron 420 which is Conroe based. I already bumped up the RAM with 2x 1GB sticks, and it's probably going to run XP. (although I have a HD3450 with which it could easily run Windows 7.)
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    16GB DDR3-1600
                                    Delux MG760 case
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Actually you can't. Early 775 boards didn't have a compatible VRM to run Core based chips (Netburst only). Yours is one of those:
                                      https://www.asrock.com/mb/Intel/775i65G/
                                      If it wasn't, Core 2 support would be noted. Generally (and ironically) Core 2 boards would run netburst chips, but not the other way around. You'd think with the reduced TDP it would work... but no.
                                      sigpic
                                      (Insert witty quote here)
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1866
                                        #3079
                                        Mine is a later revision - GA 2.03, which actually supports Conroe chips. It even notes on the board that FSB1066 is supported if you use a external GPU (and who in their right mind would run Intel's outdated Extreme Graphics on a MB that supports AGP?)
                                        It's this one:
                                        https://www.asrock.com/mb/Intel/775i65G%20R2.0/
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          It's this one:
                                          Ah. Most boards of that era supported PCIe... these boards were made as "budget upgrade" boards to allow one to keep their GPU (I used to have one myself actually, it was an ECS if memory serves). Some oddball ones even supported both PCIe and AGP... but this is a rare bird either way. Nice find.
                                          sigpic
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
