Flaky Boot
  • weirdlookinguy
    • Sep 2007
    • 1638
    Flaky Boot
    On my new to me/used Intel D915GEV board, sometimes when booting cold, everything will power on and fans will run full blast, but it won't POST. It'll just sit there. No amount of messing with the power button will get it to POST, I have to unplug it from AC power and let it sit for about thirty seconds, then plug it back in. After that, it will work just fine.
    I blamed this on the shitty Codegen PSU it was running before, but it's doing it with the nice new AcBel I just put in there.
    Any thoughts?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Flaky Boot
    check the small 85°C caps around the chipset.. (and the other ones too while you're at it..)
    had quite a lot of intel boards with those caps baked dry causing all sorts of flakyness..
    edit: w00t... post #600
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      Re: Flaky Boot
      Well I guess we ruled out the power supply.
      My P45 based board would do something similar. It would post, but just sit there at the post screen with the hard drive light on. To avoid a book, I'll just cut to the solution. The board was undervolting the chipset. As I am running 400FSB, sometimes it would detect the HD correctly, sometimes not. It was kind of marginal. Adding +.075v to the chipset fixed it. I would start by checking voltages, and comparing them to design specs. Something probably just needs a little voltage bump.
      A man convinced against his will is of the same opinion still.
      • Krankshaft
        • Jan 2007
        • 2328
        Re: Flaky Boot
        My original Intel D945GTP did that too. Fans full blast no post and it was intermittent as well.
        I RMAd it back to Intel and got a replacement and no more problems I'm using that board now.
        I did buy the original board in 04 maybe it had a bad batch of Nichicon caps on it. None of them were bulged though and I didn't have an ESR meter at the time so I didn't check them.
        • weirdlookinguy
          • Sep 2007
          • 1638
          Re: Flaky Boot
          I bought a used board to get something decent without spending a whole lot of money, and I got this crap instead. A new C2D/board combo for $250 sounds a hell of a lot more appealing than a never ending repair job with this board .
          I'm game for a simple repair, but tracking an intermittent problem is just not worth it to me. Fuck the headaches.
          If it's not too bad, I will run it for a few months and at least get my 75 dollar's worth out of it. Thank god the RAM/PSU can go into a new board. It hadn't done it for over a week, but then it did it last night and again this morning.
          How do you boost the power to the chipset? And where might I check these voltages?
          • weirdlookinguy
            • Sep 2007
            • 1638
            Re: Flaky Boot
            How does this look?
            http://www.newegg.com/Product/ComboD...t=Combo.208873
            Thing is, I don't have $300 laying around right now.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3113
              Re: Flaky Boot
              You can find much better combos than that.
              If you want a AMD Quad core Phenom II:
              http://www.newegg.com/Product/ComboD...t=Combo.211941
              http://www.newegg.com/Product/ComboD...t=Combo.213865
              http://www.newegg.com/Product/ComboD...t=Combo.211658
              Seems that what you linked is about the best intel proc/mobo combo deal.
              • acstech
                GrumpyModerator
                • Jul 2007
                • 1432
                Re: Flaky Boot
                The answer to both questions is usually in the BIOS. I don't know if it'll be there on your board or not, as I haven't messed with Intel Desktop Boards since about 2001.
                If we're shopping, here's what I would recommend:
                http://www.newegg.com/Product/Produc...82E16813138128
                and...
                http://www.newegg.com/Product/Produc...82E16819103680
                Then unlock it to a quad core. The odds appear to be in your favor:
                http://www.hardforum.com/showthread.php?t=1426852
                • weirdlookinguy
                  • Sep 2007
                  • 1638
                  Re: Flaky Boot
                  I'd rather go Intel. This is gonna sound like a stupid reason, but I've always ran Intel and I just don't get that warm, fuzzy feeling with AMD. Sometimes you just gotta do what feels right, you know?
                  I wasn't able to find anything regarding chipset voltage in the BIOS :/.
                  Also this board has two power connectors, the usual 4 pin P4 connector, and also a standard molex connector. During all three of the failed-to-boot incidents in the week I've had it, the extra molex connector on the board had nothing plugged into it. I now have both the P4 connector and the molex plugged in.
                  You guys think the molex not being plugged in may have cause this?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: Flaky Boot
                    dont plug both in! pick one or the other! or thats how a lot of boards were. check your manual.
                    sigpic
                    (Insert witty quote here)
                    • weirdlookinguy
                      • Sep 2007
                      • 1638
                      Re: Flaky Boot
                      Won't boot with just the molex plugged in but not the P4 connector, so not one or the other.
                      Manual says only the P4 connector is needed if you have a 2x12 PSU, or that both are needed if you have a 2x10 PSU. By 2x12 they mean a PSU with all 24 pins on the ATX header, by 2x10 they mean a PSU with the old school 20 pin ATX header.
                      The AcBel is, of course, being the kickass PSU that it is, 2x12. Therefore, the molex connector isn't needed. However, it seems the molex connector is there for extra power (the manual recommends it if you are running 2x10 and using a high-power PCIe card). Shouldn't fry the board, should it?
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re: Flaky Boot
                        go ahead, try it
                        sigpic
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          Re: Flaky Boot
                          It's been running like that for close to eight hours now.
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3113
                            Re: Flaky Boot
                            The molex connectors on the board is usually for older boards to do sli they needed a bit more power. Don't know because I believe this is a board before intel chipsets could do sli and crossfire.
                            Check your manual, get your model number and search it on intel's site.
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              Re: Flaky Boot
                              Whatever floats your boat.
                              Are you opposed to overclocking? If not, here's what I would recommend:
                              http://www.newegg.com/Product/Produc...82E16813138123
                              http://www.newegg.com/Product/Produc...82E16819116072
                              Lots of bang for your buck with that combination IMO.
                              • weirdlookinguy
                                • Sep 2007
                                • 1638
                                Re: Flaky Boot
                                No overclocking for me, thanks. Just want something very sturdy and reliable.
                                Which is why I'm so upset with this machine being flaky. It's a big, lovely Intel board with all japcaps... looked pretty reliable.
                                Doesn't Biostar use OST on everything?
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3113
                                  Re: Flaky Boot
                                  OST(not that bad any more really,) on the small caps, larger caps are usually all solid or electrolytic UCC's.
                                  • acstech
                                    GrumpyModerator
                                    • Jul 2007
                                    • 1432
                                    Re: Flaky Boot
                                    The last bad OST I've seen was on an ancient board from about 2001. I think the new ones are ok. I've sold enough new Biostar boards that if they were a problem, I'd know about it.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3113
                                      Re: Flaky Boot
                                      I have two ECS RS482-M754's (one blew a mosfet out of the blue and newegg sent me a new one without needed the other) We took the OST caps off of it, it was a New Old Stock board, I got it in late 2007, its from about 2004ish era, we took the caps out and checked them with a esr meter my friend has. They checked out at .01 ESR still.
                                      • KeriJane
                                        Mac Enthusiast
                                        • Sep 2008
                                        • 681
                                        Re: Flaky Boot
                                        Hi weirdlookinguy
                                        I agree about Intel.... I've tried AMD in the past and while the systems were very "snappy" they just didn't play nice with some of my software. Probably would have been great for Gaming.
                                        Those extra Molex connectors on enthusiast boards are usually meant to provide additional power to the PCIe slots as are the 4 extra wires in the 2x12 ATX connector. It's possible other stuff could be affected so it's probably best to connect it. It not only provides additional power but an extra ground connection.
                                        That little bit of extra extra current capacity might just push something into the realm of operation.
                                        They put it there for just that reason. That board may need just a bit more power somewhere, hence the Molex. They wouldn't have bothered if the P4 and ATX connectors could handle it all under all conditions.
                                        Good Luck,
                                        Keri
                                        The More You Learn The Less You Know!
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
